BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Changing run flats- spare tyre required?
      10-06-2017, 03:31 PM   #1
Adespin99
Drives: X3
Dear forum members,
Thank you for all your assistance in the past. My boy is looking to change the run flats on his f30 320d m sport.
Regarding a spare wheel what size of wheel and tyre does he need as currently he has a staggered set up
Fronts 225/45/18
Rears 255/40/18.
Do bmw sell a space saver and what size is it?
Could he buy a spare rear wheel and tyre and will that fit the front as well as the rear to get him home in the same way as a space saver?
If anyone has a suggestion I would appreciate it.
Many thanks,
Ade
      10-06-2017, 06:08 PM   #2
awd2510
awd2510's Avatar
Drives: 328i modern
Mine didn't have the staggered set up but I have changed to Non RFT and just purchased a BMW emergency tyre inflation kit. Got a brand new one off ebay for £30.00. http://www.ebay.co.uk/itm/2015-BMW-1...oAAOSw8OJZw6xT
I also keep a Dynaplug system in the car.
      10-07-2017, 02:50 AM   #3
Rbrown
Drives: 330d xdrive msport touring
Interesting - did you use the seller in your link? They are asking for £50, wondered if they accepted £30?
Thanks
      10-07-2017, 03:02 AM   #4
mssond
Drives: on order
http://f30.bimmerpost.com/forums/sho...d.php?t=911455
Gives an idea of what to get, spacers only needed if you have m sport brakes
      10-07-2017, 03:23 AM   #5
Rbrown
Wondering if this is an alternative to the branded BMW kit?
https://www.amazon.co.uk/AirMan-ResQ.../dp/B00BP5E7KI
      10-07-2017, 03:46 AM   #6
Adespin99
Drives: X3
Thanks to all who took the time to reply.
I have managed to buy a spare 255/40/18 wheel and tyre. With an aim to carrying this as a spare.
Can someone confirm this wheel will fit the front and would okay to be used in an emergency (max 50mph) as a space saver alternative?
      10-07-2017, 05:42 AM   #7
teaston
teaston's Avatar
Drives: 335d M Sport Plus
Where on earth are you going to carry a spare wheel?! Just get a slime kit, and a cheap as chips RAC membership for the absolute worst case scenario.
Current: LCI F30 335d M Sport Plus in BSM/CR
      10-07-2017, 07:11 AM   #8
Rbrown
Got to agree.
      10-07-2017, 07:24 AM   #9
HighlandPete
Drives: BMW F11 535i Touring
You'd normally have a front sized spare wheel, even for a staggered setup. Then you don't have a speed/safety issue.
Plus with the 255 section, you have an even larger volume of wheel to fit in the boot.
      10-07-2017, 07:30 AM   #10
HighlandPete
May want the added security of getting home/to destination as quickly as possible.
I used to carry a full sized spare in my 330d, when away from my own area. Simply for that reason, lowest risk of being stranded away from home.
I also carried a slime kit, that was always aboard, spare wheel or not. Belt and braces!
      10-07-2017, 07:56 AM   #11
teaston
teaston's Avatar
I just don?t know why people are so worried about getting a puncture, I?ve only had 2 in 18 years of driving an average of 20k miles per year!
      10-07-2017, 08:38 AM   #12
Adespin99
Drives: X3
Unfortunately my boy had 2 punctures, both were nails in the tread, on 2 rear run flats. Both had only recently been fitted and cost him £245 per tyre, as they couldn't be repaired this has pushed him into purchasing 'normal' tyres.
      10-07-2017, 10:53 AM   #13
AndyTo
Drives: F31 335d M Sport
On a staggered setup a rear 255 tyre will rub on the shock when you steer, not so much to damamge the shock but after a couple of turns the tyre will be ruined.
When fitting my summers i somehome fitted a rear to the front, could have been the drink from the night before, early start or talking to my neighbour when doing it, but when i reversed off my drive i heard the rubbing & the steering felt weird.
Noticed what i'd done and turned the air blue, tyre was OK but i'd taken a bit of rubber off the inside wall and removed paint from the shock. Wouldn't have wanted to drive a 255 on the front at speed!
      10-07-2017, 12:30 PM   #14
awd2510
awd2510's Avatar
Drives: 328i modern
Thanks
No it was just one I found as an example of the kit I purchased.
      10-07-2017, 01:37 PM   #15
Adespin99
Drives: X3
Thanks for all the replies.
Andyto could I get a spare 225/45/18 and use that to cover the front and back?
      10-07-2017, 02:19 PM   #16
rosstin
rosstin's Avatar
Drives: 340i saloon
Tyre weld vs Slime? Any recommendations?
      10-07-2017, 02:28 PM   #17
Rbrown
I have Tyreweld. Not yet used....hope I donít have to.
      10-07-2017, 04:25 PM   #18
dazwhite
dazwhite's Avatar
England
Drives: F32 428i M Sport
Your lucky I've had one every couple of years.
      10-07-2017, 06:15 PM   #19
teaston
teaston's Avatar
Slime, I asked my local tyre fitters and they said they wonít repair a tyre with tyre weld because itís to difficult to clean off the tyre. Slime just washes off with water apparently.
