BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Spacers making knocking noise
Vorsteiner
      11-25-2017, 12:47 AM   #1
Estoril Al
Drives: 2017 BMW 340iX Manual
Hey guys, so I have BMS spacers installed on my car. 12mm in front and 15 in back. Every time I make a right turn and then straighten the wheel I hear a single knock noise from the right rear of the car. The reason I think it might be the spacers is because it never made this noise while they weren't installed. Any advice/info? Thanks in advance!
Update: I removed all four spacers and it still makes that noise, probably going to just bring it into service and see what they say.
Edit: I finally got around to bringing the car to service and apparently the front right axle boot was leaking. Got it replaced under warranty and I thought that would solve it. Nope, no change whatsoever. Still makes the same noise when straightening the car after making a right turn. I'm really pissed and am gonna give it to my service advisor when I see him monday. Anyone have any advice?
      11-25-2017, 01:01 AM   #2
HFW003
HFW003's Avatar
Australia
882
Drives: MY16 MG F10 528
I can’t imagine how they could make any noise, providing of course they are installed correctly.
There is nowhere for them to move, the sit flush between the hub and the back face of the wheel.
      11-25-2017, 01:03 AM   #3
Estoril Al
I'm thinking the same thing, the only possibility is that maybe when I got my new tires put on the spacers were reinstalled incorrectly? Haven't been able to check for myself yet.
      11-25-2017, 01:16 AM   #4
kern417
Cheapskate
Drives: 2018 440i / 2010 X5
make sure your lugs are torqued down
      11-30-2017, 12:07 AM   #5
Estoril Al
Alright so update: I made sure all the lugs are tightened down yet it's still making that noise. Honestly I don't care if it's just a small creak as long as the car is still safe to drive/mod.
      11-30-2017, 09:05 AM   #6
COKen
COKen's Avatar
Drives: 2014 435i / 2002 M Roadster
How about taking the spacer off and see if you can still hear the noise. That would eliminate the spacer from the equation or not.
2014 435i M-Sport, Mineral Gray, Black Dakota Leather, Driver Asst Pkg, Prem Pkg, Tech Pkg, 8 Spd Sport AT, Heated Front Seats, ACC, BMW M Perf Tune w/MPE, BMW LSD, BBS CH.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Steel Gray Metailic HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C.
jnecr85.50
      11-30-2017, 09:54 AM   #7
jnecr
Drives: 2014 328d
This guy sciences.
2014 328d
      12-01-2017, 10:03 PM   #8
Wires
Drives: 2016 340i xDrive
Tire rubbing?
      12-06-2017, 12:31 PM   #9
Estoril Al
Originally Posted by Wires View Post
Tire rubbing?
Not that I can see, just took the spacers off though and it's still making the noise :/
      12-09-2017, 12:00 AM   #10
Wires
Sounds like a sway bar or sway link issue. I had the link break on my truck and it would "thump" in a situation like you are describing.
      12-10-2017, 04:59 PM   #11
TumblingPanda
Drives: F30 335i
I'm assuming you got longer lug bolts for all four wheels. Did you make sure they are of the right spec and that the thread on them looks fine? I hope you are not using the stock lug bolts with 12 mm and 15 mm spacers.
      12-10-2017, 07:51 PM   #12
COKen
COKen's Avatar
He took the spaces off and the sound is still there, so not an issue with bolts.
      03-19-2018, 11:44 PM   #13
Estoril Al
Still making the same noise, brought it into service and they couldn't replicate the noise and even looked under the car and said everything was fine
      03-20-2018, 12:00 AM   #14
Calvin36
Calvin36's Avatar
Drives: F30 335i M Sport
Of course. That always happens when you bring it in for a diagnostic.
Mine: BSM F30 335i M Sport
Hers: AW F30 328i M Sport
      03-20-2018, 12:58 AM   #15
El Conquistador
Drives: 14 XD 335 - 6M as god intended
If there were female service advisors, I would have married one to assure my car always ran without any faults.
      03-20-2018, 10:23 AM   #16
Estoril Al
Lol exactly
      03-20-2018, 03:16 PM   #17
IAmATeaf
Drives: 335i
Steering rack? Is known to make a noise like this, I had mine changed as it was making a knocking sound.
      03-20-2018, 03:20 PM   #18
Estoril Al
Actually the steering rack was replaced a few thousand miles ago paid for by insurance so that may be the issue. Although it seems like the noise is coming from the back of the car, not the front.
      03-20-2018, 09:27 PM   #19
2000Z3M
Drives: 2016 435i ZHP
this. i had 3 snap on a jeep, wheel almost feel off
