08-26-2018, 01:22 AM | #89 | |
Rep 366
Yes you're right, it's at about 8'o clock. Though its easier to see in a pic with flash than in natural ambient light.
435i Gran Coupe | ///M Sport Pkg | 430hp | MHD Stage 2+ | BMS Intake | Catless Downpipe | FMIC | Black Sapphire exterior | 9H Ceramic Coating | Black Anthracite interior | 19" Black ///M Wheels | Red ///M Brake Calipers | ///M Steering wheel | ///M Metal Pedals | Alcantara dash panel | Carbon Fiber trims and gear knob | Angel Eyes LEDs | Surround Cameras | Spoiler | Coded ///M iDrive, Mirrors, HUD |
08-31-2018, 01:26 PM | #90 |
Rep 233
Drives: '18 M2 LCI
Anyone know how far back this connecting piece should go?
'18 M2 LCI 6spd
08-31-2018, 02:10 PM | #92 |
Rep 233
Drives: '18 M2 LCI
Any tips for tucking in the bottom part without removing the airbag? Having trouble figuring out how to the wrap all the way around with that connected part. Would it be easier or better if I mad a cut in it and then trimmed the excess?
'18 M2 LCI 6spd
08-31-2018, 02:53 PM | #93 | |
Rep 121
edit: maybe you can tuck it, I will let you know. Last edited by brikabrak; 08-31-2018 at 02:58 PM.. |
09-01-2018, 11:43 AM | #94 | |
Rep 366
If you're not removing the airbag, use the plastic trim tool provided with the Mewant kit or better yet a thin screwdriver to tuck in the excess. But be advised, it's a real tight fit and you're really better off doing it proper and removing the airbag/steering cover first. EDIT: You're actually supposed to start sewing from the bottom. A 'dry fit' makes it seem the cover won't fit perfectly, but it will when you sew all the way around. But again, a perfect fit will only occur if you've removed the airbag and cover first.
trilax5991.50 |
11-30-2018, 06:53 PM | #96 |
Rep 1,827
Just cleaned mine yesterday, it was getting a bit matted and grimy. Almost as good as new. So far so good.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
11-30-2018, 09:31 PM | #97 |
Rep 270
11-30-2018, 09:51 PM | #98 |
Rep 1,827
Blank
Yeah, for sure. I originally wanted the Alcantara M Performance wheel with the flat bottom designed for the sport airbag, but the cheapest I found it was around $750. The wrap was about $50 and got me about 75-80% of the way there.
I personally really like the alcantara feel and since it's wrapped around the existing leather, it thickens the rim a good amount, which I also like. Just be warned that it'll take a good chunk of time to do it well, but for me, the 3-4 hours it took me is well worth the $700 I saved. (Side note: the M Performance wheel has grey stitching, the red stitching on the wrap I got matches my Sport Line interior). I used this video's method to remove the wheel. Couldn't for the life of me get the airbag off using the little slits. Removing the controls/trim is pretty straight forward after that. Just need a torx bit screwdriver (I think it's T20 but don't quote me on that). I personally think wheel removal is the way to go so you can stitch in a comfortable, well-lit area as opposed to the dark, cramped, awkwardly angled prospect of doing it from the driver's seat.
12-03-2018, 01:29 AM | #100 |
Rep 270
Mountain_Commando303.00 |
12-05-2018, 03:32 PM | #101 | |
Rep 1,827
haagm58810.50 |
12-06-2018, 07:21 AM | #102 |
Rep 270
Does the part between the side spoke and airbag on each side both you? It seems like the material isn’t long enough to properly tuck on the corner there?
12-06-2018, 07:39 AM | #103 | |
Rep 1,827
I mean, really for $50, it's worth a shot. Works for me, but I keep in mind that it was $50 and not $200-750. Try it, if you don't like it, drop the extra cash for a professionally wrapped wheel. I'd say, with the potential cost savings, it's at least worth the attempt. It's not a huge investment, imo.
12-06-2018, 12:32 PM | #104 | ||
Rep 59
Thanks
2013 EB 335i Xdrive, Msport package, BM3 Stage 1 93 octane, VRSF Chargepipe
12-06-2018, 06:34 PM | #105 | |||
Rep 1,827
https://m.aliexpress.com/item/328897...Q1544142777076
12-24-2018, 07:40 PM | #106 | |
Rep 270
12-24-2018, 08:28 PM | #107 | ||
Rep 1,827
12-25-2018, 08:33 AM | #108 |
Rep 16,139
Use a plastic trim removal wedge to pry up the air bag while releasing the tab. Don't over do it, lift it just enough so that the tab stays released. Leave the wedge in place, use a second wedge to repeat on the other side. When both tabs are released apply equal pressure to both wedges to remove the bag.
haagm58810.50 |
12-27-2018, 10:09 AM | #110 |
Rep 1,827
Pull it. I've done it 3 times. It's wedged in there pretty good. Just make sure the spring clip is free.
