BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Where to find Ignition +12
      12-05-2017, 10:08 AM   #1
KLez
Drives: 435d xDrive
Hello,
Does someone know where i can get the "ignition +12v" pin?
Maybe from the fuse-box at the trunk?
Some years ago the "ignition" was at Pin1 of the OBD2 socket too, but it seems as BMW has removed it?!
      12-06-2017, 01:32 PM   #2
kern417
Cheapskate
Drives: 2018 440i / 2010 X5
If you need switched power, there should be several options. You'll need to check with a multimeter.
      12-12-2017, 12:01 PM   #3
KLez
Drives: 435d xDrive
The easiest way i have found was the fuse-box in the trunk:
at fuse 148 there is "Ignition +12".
at fuse 160 there is "Battery +12".
