BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Digital Fuel Gauge Problem
      12-07-2017, 05:43 PM   #1
ROCKO86
Hungary
Drives: 2017 440xi Gran Coupé
Exclamation Digital Fuel Gauge Problem
Dear Friends!
My digital fuel gauge (or I don't what's the name of the panel below the speedometer...) doesn't shown, as you can see on the example picture I attached.
I don't think it went wrong (the car is pretty new, it has only 5.500 km), more likely I changed something in the setup menu.
Do you have any tips or ideas?
Thanks in advance!
      12-07-2017, 06:04 PM   #2
stormlv
Human
Switzerland
201
Drives: Yes
Don't mean to be mean, but have you tried reading the manual?
2018 BMW M4 (F82) DCT / ZCP| 450HP / 550Nm with CF drive shaft | Sakhir Orange | Photo album
Sold 2014 BMW 435d xDrive Coupe MSport Stage 1 | 360HP / 710Nm | Estoril Blue | Photo album
Sold 2011 Volvo S60 T6 AWD | 304 HP / 440Nm | Ember Black | Photo album
      12-07-2017, 07:00 PM   #3
HighlandPete
Drives: BMW F11 535i Touring
Do you simply mean the displays which are accessed by cycling through the BC button sequence? (mpg, mph, range, etc.)
If so, just cycle through the functions, until you get what you want displayed.
      12-07-2017, 07:25 PM   #4
COKen
COKen's Avatar
Drives: 2014 435i / 2002 M Roadster
The BC button is on the end of the turn stalk.
2014 435i M-Sport, Mineral Gray, Black Dakota Leather, Driver Asst Pkg, Prem Pkg, Tech Pkg, 8 Spd Sport AT, Heated Front Seats, ACC, BMW M Perf Tune w/MPE, BMW LSD, BBS CH.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Steel Gray Metailic HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C.
      12-07-2017, 10:44 PM   #5
tex2670
Assistant to the Traveling Secretary
tex2670's Avatar
Drives: '14 328xi Sport Line
There isn't any display under the speedometer. Extended Contents display only is under the Tach. Your fuel gauge is on the left, in analog.
2014 328i xDrive | Black Sapphire / Black Red Dakota | Sport Line | Premium Pkg | Lighting Pkg | Cold Weather Pkg | Driver Assistance | Nav | Sport Automatic Transmission
      12-08-2017, 02:48 PM   #6
ROCKO86
Hungary
Maybe I wasn't express myself in a correct way. I didn't mean the board computer's display, but - as I mention - the digital fuel gauge(? - or range display...? I don't know its exact name...).
The BC button don't do anything with it, I suppose.
And yes, there is a display:
I tried to look after it in the owner's manual, but I couldn't find any helpful information.
So after all, any more tips would be appreciated.
Thanks in advance!
      12-08-2017, 03:48 PM   #7
tex2670
tex2670's Avatar
Thanks in advance!
Those 2 pics are not depicting the same IP:
Top pic-- typical F30 analog display, with no contents under the speedo.
Bottom pic-- either a digital dash, or not an F30 (maybe 5-Series https://paultan.org/2012/05/14/new-e...rom-july-2012/).
OP had a pic of the analog display. Which has no info below the speedo.
Refer to this BMW instructional video:
And also this IP test video that shows all the indicator lights and IP display areas:
      12-08-2017, 05:15 PM   #8
COKen
COKen's Avatar
If you are talking about the miles to empty as shown below (which is showing 100 miles until empty) then using the button on the end of the turn signal stalk will cycle through the options which can be displayed. If this isn't your question, then I'm not sure what you are asking about. If you google "bmw 440i instrument cluster" and then click on images maybe you can find an image showing what you are trying to display.
      12-08-2017, 05:20 PM   #9
jeffc83
Drives: 2015 328i XDrive Luxury Line
The above two statements should answer your question OP and I was one that got pretty pissed off when I saw a "blank" there instead of a screen. (would've been a nice feature as I show speed versus DTE) Save your money and go with the digital cluster retrofit ($1600 USD) which will give you exactly what you want and a whole lot more!
Originally Posted by jmg
That seat was meant to be used, are you going to deny it's purpose in life?
      12-08-2017, 05:22 PM   #10
jeffc83
Was this your car when new? Not to be a PITA but I sure hope you got a full tank of gas with it!
      12-08-2017, 07:18 PM   #11
COKen
COKen's Avatar
Not mine. Found it with a google search.
I did get mine with a full tank.
      12-08-2017, 07:31 PM   #12
jeffc83
Good because I was going to say if he didn't get a full tank of gas, just think of what he actually paid for the car LMAO
      12-09-2017, 12:05 AM   #13
Wires
Drives: 2016 340i xDrive
There is nothing on the left side on the F30. You're "estimated economy" is shown under the right dial (from battery to fuel consumed).
The MPH / l/100km will show in the center section if you cycle through the BC stalk.
The left side might show miles/km's to empty if you reach critical fuel levels (not sure though).
      12-09-2017, 04:54 AM   #14
marcu
marcu's Avatar
Netherlands
Drives: 440i Coupe 2018
If you get the digital dash, the range is shown under the speedo, but not on the regular dash.
Even if you get the extended cluster, that part remains black.
2018 BMW 440i Coupe, High-Exec, MPPSK, HUD, Dig dash, touch-nav
2014 BMW 335, High-Exec, MPPK, MPE, HUD
2009 Alfa 159
2005 Alfa 156
digital, fuel, gauge
