BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Fuel Additive for Petrol F30 N20 engine?
Vorsteiner
      01-02-2018, 03:37 PM   #1
satish_141
Drives: F30 320i
Question Fuel Additive for Petrol F30 N20 engine?
Hi,
Could someone please suggest a good Fuel Additive for Petrol F30 N20 engine? Also my car is only 2.5 years old still under manufacturers warranty so putting a fuel additive does this invalidate my warranty if something goes wrong? please advise?
Regards,
Satish
      01-02-2018, 04:05 PM   #2
HighlandPete
Drives: BMW F11 535i Touring
Originally Posted by satish_141 View Post
Hi,
Regards,
Satish
BMW's own approved cleaning additive.
83 19 2 183 738 BMW Group Petrol additive.
      01-02-2018, 06:57 PM   #3
satish_141
Drives: F30 320i
using this doesn't void warranty?
      01-02-2018, 07:59 PM   #4
bavarianride
Drives: bimmer
Chevron Techron Fuel System Cleaner is used on my N26.
37psi1564.50
      01-03-2018, 01:39 AM   #5
sspade
sspade's Avatar
Drives: 2014 328i
+1 on the Techron. Use a bottle in the last tank leading up to my 5k oil service. Obviously using BMW brand wouldn't be a bad option. Would have to assume they have similar formulas, but who knows.
328 | Orion Silver | BMS catch can | OBX strut brace | aFe scoop w/ K&N filter | NGK laser iridium | DWS06 on Black 237s
      01-03-2018, 02:51 AM   #6
satish_141
Drives: F30 320i
thank you, will get this today
what about warranty?
      01-03-2018, 03:55 AM   #7
37psi
37psi's Avatar
Drives: F32 - 435d X Drive M Sport AT
+1 for Techron
      01-03-2018, 04:27 AM   #8
HighlandPete
BMW's additive is a fully approved product, so no warranty issues.
      01-03-2018, 07:49 AM   #9
satish_141
Drives: F30 320i
Thank you HighlandPete I will try to get the BMW's additive.
      01-03-2018, 09:54 AM   #10
Billfitz
Drives: '15 328iX GT
I'd bet that the BMW additive has the same ingredients as Techron, it may even be re-labeled Techron, at 3 times the price.
      01-03-2018, 11:04 AM   #11
enjoythemusic
enjoythemusic's Avatar
232
Drives: 2014 BMW 435i Dinan Stage 4
Techron every 3k to 5k miles.
Enjoy the Drive,
Steven
2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+ & Mich PS4S.
      01-03-2018, 11:30 AM   #12
ooshnoo
ooshnoo's Avatar
Drives: 2014 428i
2014 GMC Acadia  [0.00]
2014 BMW 428i  [5.00]
Think about it for a moment... why would BMW make a fuel system cleaner that would void the warranty on it's own cars?
___________________
2014 F32 428i 8AT M-Sport
      01-03-2018, 12:15 PM   #13
HighlandPete
From what I've read BMW's additive contains Kerocom PIBA 03 from BASF.
      01-03-2018, 03:41 PM   #14
sspade
sspade's Avatar
Drives: 2014 328i
My thinking, exactly.
      01-04-2018, 05:49 AM   #15
satish_141
Drives: F30 320i
true agreed, any best place to get a this online?
      01-04-2018, 01:01 PM   #16
bavarianride
Drives: bimmer
That is logical, but some posters may object.
E.g. a thread in the other forum says (now discontinued) Castrol rebranded BMW High Performance 5W30 does not meet BMW's own LL01 spec.
      01-04-2018, 01:02 PM   #17
bavarianride
Drives: bimmer
getbmwparts.com has it, P/N 82140413341
      01-04-2018, 01:18 PM   #18
Billfitz
Maybe not now, as BWM has moved on to a different supplier, Shell the last I knew. BMW doesn't own a refinery, nor AFAIK a petrochemical plant, so just because it has the BMW label on the container doesn't mean BMW makes it. They source it, and as with all things sourced it can be found under a different name from the original manufacturer, most likely at a lower price. Caveat Emptor.
      01-04-2018, 02:31 PM   #19
sspade
sspade's Avatar
Drives: 2014 328i
Would you guys agree that the LL01 specification is only relevant if you are running long durations between oil changes?
Another way put, if you are religiously changing oil every 5k then the LL01 factor would not come into play?
I am using Mobil 1 0W-40 as recommended by owners manual which must be LL01... just wondering what you guys thought otherwise?
      01-04-2018, 02:44 PM   #20
bavarianride
Drives: bimmer
Since LL01 is available at local Walmart, there is no reason not to grab one.
Having said that, latest M1 FS 0W-40(GTL) does not have LL01, but it has MB 229.5, which goes toe to toe(closely) with even LL01FE!
So, say, for $22-$25 5 Qt, go grab a jug with LL01 + MB229.5, if not available, then grab a MB229.5(those are available off the shelf here).
      01-04-2018, 03:27 PM   #21
Orion4
Same size, shape and color container. Appears to be just relabeled Chevron Techron under BMW Label. Been using Techron in my BMWs for years without issue and clean injectors, etc at substantial savings.
37psi1564.50
      01-04-2018, 05:00 PM   #22
John in VA
Drives: '13 328i xDrive
To the original poster - why do you feel you need a fuel treatment? If you're using top-tier gasoline you shouldn't need an additive.
_______________________________________________
2013 BMW 328i xDrive in Orion Silver/Venetian Beige - Premium & Cold Weather Packages, Navigation System
wrickem469.50
