BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > JB Weld (Glass) to attach dash cam to windshield?
      01-03-2018, 03:54 AM   #1
37psi
37psi's Avatar
Drives: F32 - 435d X Drive M Sport AT
Fed up with my BMW advanced car eye cam falling from the screen every month. Bought the strongest offering from 3M adhesives and no joy.
JB weld two pack did cross my mind but I think they have a few products for glass as well.
Anyone attempted a semi permanent bond for their dash cam to the screen?
Any alternatives to the rubbish 3M VHB adhesives?
Thanks
      01-03-2018, 01:01 PM   #2
Orion4
I'd be cautious about using JB Weld. You may never get it off. I use the standard 2 part for a myriad of repairs and it never fails and can not separate it without breaking the attached piece(s).
My Blackvue 650GW camera system came with adhesive tabs that are very good. Never had one fail in the FL heat over the 3 years I've had it. Not sure if they have the size you need, but you could check their site: https://www.blackvue.com/product-cat...sories/page/3/
Here is their UK distributor link: https://www.blackvue.uk/
Good luck
      01-03-2018, 01:14 PM   #3
37psi
37psi's Avatar
The weight of the cam is the issue. It weighs in at 230g.
I ordered a Blackvue adhesive pad at great expense but that failed too due to the weight of the cam.
I don't mind going permanent with it but it didn't come with additional plastic mounting brackets. It is some Korean cam anyway with the BMW logo emblazoned on it according to a few forum members.
Cannot recall which particular model but if I find it then I shall order a spare bracket should it go wrong.
      01-03-2018, 07:24 PM   #4
hardparker
BMX3er
52
Drives: 2014 X3 M Sport
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
Glass etching cream and windshield button mount cement. Etch a spot to mount for the adhesive to adhere to the glass, then cement whatever mount you have.
I've mounted a Gentex mirror with just that setup and it never fell off over the course of several years.
That, or see if BlendMount has something that will work.
F25 X3 35i M Sport | Pure Stage 2 turbo + inlet | UR catted DP | Phoenix FMIC (Poo! VRSF Race to come soon.) | FTP full pipes | BM3 PTF tuned | E30 mix | Custom big boy oil cooler
      01-04-2018, 03:35 AM   #5
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
622
Drives: 340 6MT
JB Weld! Now we are talking. You need to prep the surface. Scuff it up, maybe take a drill?
      01-04-2018, 03:51 AM   #6
37psi
37psi's Avatar
Yeh the etching sounds like a good plan. I will drill a tiny spot.
