BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 2013 335 Oil Pan Heater
Evolution of Speed
      01-03-2018, 01:44 PM   #1
Docks
Drives: 2013 335Xi
I'm in Winnipeg and its quite cold here over winter, currently about -21C, and want to change out my oil pan heater to larger sized one.
Currently im looking at the wolverine model 40.https://wolverineheater.com/pages/wo...z-sizing-chart
The only problem is that the size is 5"x7" and i'm not sure if this will fit on my oil pan.
Does anyone know the proper dimensions of the 335 oilpan and if this would fit?
      01-03-2018, 02:52 PM   #2
Billfitz
Drives: '15 328iX GT
I'd be inclined to add a coolant heater, which not only keeps the engine warm but also greatly reduces the time it takes for the heat to come up. The temperature here hasn't broken -18C with night time drops to -24C for the last two weeks and my car hasn't had any problem starting, it just takes longer than usual to get heat. I do keep it on a battery tender, though.
      01-03-2018, 03:14 PM   #3
37psi
37psi's Avatar
Drives: F32 - 435d X Drive M Sport AT
Stick a webasto heater on it with a divert to the engine. Can set the timer/turn on from an app off your phone. There are also options to heat the fuel a little.
https://www.webasto.com/gb/markets-p...s230300350400/
