BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > 10.25 Android Headunits
      01-27-2018, 11:15 AM   #1
madmunky
Drives: F31 335d
As requested moving this out of the Avin build thread for anyone who wants to talk about modifying their head unit be it the Avin unit and loading unofficial firmware or anything else.
awmenard142.00
      01-27-2018, 11:17 AM   #2
madmunky
Drives: F31 335d
Originally Posted by madmunky View Post
That's fine I understand the risk's the units are pretty hard to brick even if the firmware is no good (Though I'm 99% sure all the units use the same firmware from the factories they are all just different resellers) it should be possible to use the manual method to reload the old firmware back again.
I’ve just loaded the firmware update posted, of course if you decide to do this also it’s at your own risk. That out the way it seems to work fine no issues so far I’m not sure what’s new/fixed I can only see the new Mercedes Benz UI option which is horrible btw also if anyone tries this do not go into the factory setup touch screen settings as it can mess up the touch screen area and it’s really had to reset it back again
I’ll update again if I find anything new/fixed
      01-27-2018, 11:19 AM   #3
madmunky
Drives: F31 335d
Originally Posted by auxvoix View Post
That last part looks new as well. What exactly are those Touchkeys?
I'm not sure I couldn't get them to change, I hoped they would allow me to map other buttons to do more things but it doesn't seem like it.
Also never go into the 'Touch Area' part as it will shrink the screen size making it hard to click on anything to set it back.
      01-27-2018, 11:20 AM   #4
madmunky
Drives: F31 335d
Link to the firmware which I loaded thanks to raays
Originally Posted by raays View Post
hey guys !!
here is the january update for 10.25 android
you can give a try,but i don`t know if it`s working for all 10.25 devices
      01-27-2018, 12:15 PM   #5
auxvoix
Special Ops 💀
Drives: F10 528i, E46 325i
I'm pretty sure these units come from one same manufacturer but oh well.
I'm running the same software for my F10 unit lol.
So apart from a few additional options (non-functional ones), no real noticeable improvements?
Raays's link is no longer public.
      01-27-2018, 12:47 PM   #6
Ravijordan
Drives: Bmw x5
Hey guys is there any way I can download the new firmware ?
      01-27-2018, 01:09 PM   #7
madmunky
Drives: F31 335d
I'll see if I can upload it to any free upload sites
      01-27-2018, 01:53 PM   #8
madmunky
Drives: F31 335d
try this
https://files.fm/f/scgk4je3
      01-27-2018, 03:51 PM   #9
notsec
Drives: BMW F30
Do you know how to use the voice assistant? When I click on it, it says "no device".
      01-27-2018, 06:11 PM   #10
plikmuny
plikmuny's Avatar
Drives: BMW 320d, 330D(2019)
Is this unit bought from aliexpress? If yes can I flash it without worrying about the bricking problem?
      01-27-2018, 07:18 PM   #11
raays
Japan
Drives: x6 e71 2012
Mine is bought from Aliexpress and has no problem even with avin update or January update
If u brick ur device u can go back anytime with the old one , there is from August to November
(In case u want to go back with avin october update)
      01-27-2018, 07:34 PM   #12
raays
Japan
Drives: x6 e71 2012
Thanks for moving this thread
By the way how is the update for you?
      01-28-2018, 01:19 AM   #13
plikmuny
plikmuny's Avatar
Thanks a lot. I will flash it today itself...
Update: I am not able to choose the new evo menu... Can you guide me please...
      01-28-2018, 03:03 AM   #14
madmunky
Drives: F31 335d
My unit is from Avin, the update works fine for me so far, no doubt Avin will release the same update when they are able
      01-28-2018, 03:05 AM   #15
madmunky
Drives: F31 335d
So far its worked fine you just have to watch out for that touch area screen. I will give it a good test today as I have a 3-hour trip.
Just now need an updated CarPlay (PhoneMirror) application the Avin one crashes each startup and the one someone else posted gets stuck in a loop at boot asking for USB access.
Does anyone know of any applications where you can set the screen brightness based on the time of day?
      01-28-2018, 03:19 AM   #16
ddigian
Danilo
Italy
Drives: bmw 318d
[QUOTE=madmunky;22705949]I’ve just loaded the firmware update posted, of course if you decide to do this also it’s at your own risk. That out the way it seems to work fine no issues so far I’m not sure what’s new/fixed I can only see the new Mercedes Benz UI option which is horrible btw also if anyone tries this do not go into the factory setup touch screen settings as it can mess up the touch screen area and it’s really had to reset it back again
But is your unit Gen1?
      01-28-2018, 08:00 AM   #17
Kc7ryd
Drives: 2011 328xi
On your screenshots, what is the difference between “BMW EVO NEW and BMW ID6”?
Has anyone played with the “touch key” settings?
I also see part of a Dashboard menu... is there now a way to change to gallons and MPH on the dashboard screen?
      01-28-2018, 01:20 PM   #18
madmunky
Drives: F31 335d
Mines a Gen2 unit
      01-28-2018, 01:22 PM   #19
madmunky
Drives: F31 335d
I believe the 'Evo New' was the old tile mode and should be in the old firmware but ill test it out.
Touch Key I could not get to do anything.
      01-28-2018, 01:31 PM   #20
Kc7ryd
Drives: 2011 328xi
If possible post screen shots of everything, and please check the Dashboard to see if readouts can change to mph and gallons.
      01-28-2018, 01:31 PM   #21
CleanKM
SQUEAKY
CleanKM's Avatar
Drives: 2014 328d
I'm in the same boat with the carplay app. The old version from Avin crashes but any newer/updated ones ask for USB permissions everytime it boots/starts.
      01-28-2018, 01:34 PM   #22
CleanKM
SQUEAKY
CleanKM's Avatar
Drives: 2014 328d
Did you get the update from the reseller? I'm really hoping that there is a centralized place where we can all go and get them, instead of this one person is able to get one here and there kind of thing.
