BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Eibach Pro-kit or the H&R Sport
03-10-2006, 01:54 AM | #1 |
Rep 4,163
I'm stuck between the Eibach Pro-kit and the H&R Sport.
The Eibach is 1.2 and 1.0 the H&R is 1.3 and 1.2 I'm looking for a drop that will make my car look more aggressive, but not having to worry about rubbing issues, since im keeping the stock non-zsp shocks for now w/ 18x8 wheels and 235/40 tires. I was thinking the H&R at first, but the Eibach has larger contrast in front and back, and i was thinking 2 things, the larger ratio will give the car a more wedge shape (more aggressive) and also if i seat 2 adults in the back thats .2 more inches i have before any potential rubbing. But assuming neither will have rub, which will be the winner; aggressive-look-wise. Thanks!
'06 bsm e90 330xi : 18" VMR CSL : KW V3 : GruppeM Rep Intake : UUC/Corsa Catback : Hartge Lip : ACS Roof Spoiler
OEM CF Trunk Spoiler : CF Emblems. Pillars. Mirror. Grille : LUXER12 led plate : V1 Hardwired : OG.longtran e90post sticker! circa 2005 |
03-10-2006, 02:22 AM | #2 |
missing two turbos.
577
Rep 4,859
Drives: fast around corners.
you are comparing two apples. thats why you can't find out which one is better.
Reading all the reviews from sport/prokit owners, and seeing all the pics.. they are pretty much the same. Drop looks similar, and ride quality also seems to be very similar. wait for tein s-techs! start a group buy!!
06 AW E90 330i ZPP/ZSP/Step/Expired Warranty : Prior Design Front : ACS Rear : ACS Roof : BlackLines : Simota Intake : Carbon Fiber Interior Trim : : MTEC V3 : 24% Charcoal : V1 Hardwired : Solaris Invisibulbs/LED interior : |
03-10-2006, 11:30 AM | #3 |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
The more agressive one is the H&R sport. Either one your not gonna rub with a carload of people unless your 18" rims have a crazy offset, you know sticking out alot.
Regardless, of the above, I had Eibachs before and they sagged overtime. I went with H&R's this time. Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
03-10-2006, 11:43 AM | #4 |
Rep 4,163
thx guys, without rubbing issues, H&R ftw
03-10-2006, 01:24 PM | #5 |
missing two turbos.
577
Rep 4,859
yeah like what danny said. i had eibach pro kit and h&r race on my previous cars.
people say h&r is stiffer, but eibach sucks just as bad imo.
03-13-2006, 12:39 PM | #6 |
Moderator
497
Rep 27,441
i had eibachs and koni's on my e34, and i really liked the set up. i didn't have any problems with sagging.
so i'm debating which to go for this time, eibach pro-kit, h&r sport, or tein s-tech (need more info). i'm currently leaning towards h&r since i've read quite a few good reviews from e90 owners.
03-14-2006, 12:25 PM | #7 |
Rep 1,329
I'm re-posting this from the other thread:
i've used eibach [PROKIT] on my prelude and did have the opportunity for h&r at the time. in those cars, a lot of my friends with h&r did "bounce" more. but that could also be that h&r tend to be lower. Eibach was great though in this car I'm going H&R for a more aggressive drop. Eibach [prokit] my handling improved a lot and it felt stock. Both are good companies. If you want more comfort, the eibach may do that, better handling, h&r. |
03-14-2006, 01:10 PM | #8 |
Rep 29,202
Check out this test of Eibach and H&R from tirerack
http://www.tirerack.com/suspension/t...bach_hr_rd.jsp As you can see they get the same score combined |
03-14-2006, 01:23 PM | #9 |
missing two turbos.
577
Rep 4,859
thank you for the site!!
03-16-2006, 11:39 PM | #10 |
Rep 4,163
which do u guys think has less sagging if i were to use stock xi shocks.
also, i always thought that the H&R sport lowered the e90 more than the eibach pro-kit based on the specs. but in the review, they said it was the ebiach that lowered more in the front and back. while it wasnt an e90 in the review but a 1999 328i, does anyone know for sure which is lower on the e90?
OEM CF Trunk Spoiler : CF Emblems. Pillars. Mirror. Grille : LUXER12 led plate : V1 Hardwired : OG.longtran e90post sticker! circa 2005 Last edited by uhaulball; 03-17-2006 at 12:15 AM.. |
03-17-2006, 12:57 AM | #11 | |
Rep 6,750
03-17-2006, 11:18 AM | #12 | |
Moderator
497
Rep 27,441
1.3" / 1.2" --> H&R Sport Springs (part # 50490) looks like the h&r's will be a tiny bit lower.
03-17-2006, 07:58 PM | #13 | |
Rep 4,163
04-18-2006, 04:27 PM | #14 |
Rep 10
from my past expericence, H&R wears out the stock shocks a lot faster. Eibach pro-kit is easier on the stock shock and a bit nicer ride.
H&R have a little better performance, but is suggusted to repalce aftermarket shocks and struts. Eibach works fine with stock struts and shocks, but of course replacing shocks and struts is always better. |
04-18-2006, 06:31 PM | #15 | |
Rep 1,329
if this is true, that it does not wear the stock shocks as quickly as h&r, I would go h&r. The fact that it doesn't wear it out as much could be due to the fact that the h&r is more aggressive though, no?
04-29-2006, 03:06 PM | #16 |
Rep 4,094
Drives: F30 328i
my bm gots HR springs with 19" with no szpackage and its awesome..
05-17-2006, 05:02 PM | #17 |
Rep 138
Prokit with sport chassis. Works great, very satisfied.
Bmw 325i -06 "Slush o' matic"
20" Hartge classics with Falken 245/30 and 285/25*Eisenmann race 2x76mm*K&N Euro cone filter*H&R Cupkit race*Oem Front and Rear spoiler* Xenon led rings*Blacklines* |
