07-25-2008, 01:48 PM | #1 |
Rep 218
Anyone just upgrade subs with sws-8? without upgrading amp?
I have the individual audio, and I was wondering if anyone tried upgrading the subs underneath the seat to sws-8 without upgrading the amp.
I've read on e90post that a few have tried it and got slightly better bass response, and thats all i'm looking for, but i'm not sure if our amp is the same as the logic 7. I rather not upgrade the amp because I dont want to have warranty issues with the dealership later on if anything happen with the onboard electronics. I'm not looking for huge bass response, just slightly better than stock.
07-27-2008, 07:13 AM | #2 | |
Rep 12,997
With all that said, you could replace the OEM subs with SWS-8 and probably it will sound a little better depending of the quality of the OEM subs and the power input, however you should check either by yourself (remove one OEM sub and simply look at it) or with the dealer about the specs of the OEM subs, as the SWS-8 comes now in 2 and 4 ohms versions. You want to keep the impedance the same to avoid overheating the OEM amp (if you lower the impedance) or further reducing the bass output (if you increase the impedance). FYI: you cannot replace the OEM amp in the Individual Audio even if you want it to, so don't worry about any warranty issues. You could add another amp, though. |
07-27-2008, 02:33 PM | #3 | |
Rep 218
Thanks for the help, I'll be sure to find out what ohms the sub is before I purchase the sws-8 to make sure i get the right version.
