04-09-2019, 09:41 PM | #1 |
Rep 1
18X10.5 squared on F30 RWD help
I'm looking to buy a new set of summer wheels as winter is pretty much at an end. Through my long searches I've found a set that I think I fell in love with but unfortunately its a squared set up and not the usual staggered.
The rims I found that I want are 18x10.5 all around. I had 10.5's in the rear before and it used to rub slightly on bumps but those were 20's. I'm sure the back should be ok as the tires have a slight stretch. The fronts however I'm not 100% sure. This wouldn't be an issue if the guy would let me just test fit one rim on the front so I can make sure they clearance is alright but the guy will not let me put a wheel on my car unless I buy the whole set :S I'm just worried that I'm going to bring them home to a disaster of a fitment. The wheels are currently on a E90 sedan. The guy insists they will fit fine. Any help would be greatly appreciated. |
04-10-2019, 07:12 AM | #2 |
A family of bimmers
2757
Rep 7,743
I do not believe you can fit a 10.5 up front on the f30. people have made 9.5s "work" but it requires stretched tires and camber. Imagine trying to cram another inch of width under there.
04-10-2019, 01:01 PM | #3 |
Rep 272
A part of me just died inside seeing those Enkei caps on XXRs.
Those are +20 offset. IDK your suspension setup but I personally wouldn't spend the money or effort to just fit some XXRs. I think you would have to go beyond a roll and pull the body line of the fender |
04-12-2019, 07:43 AM | #4 |
Rep 100
Those tires have a helluva lot more than a "slight" stretch.
Even with that stretch, they won't fit. There's a reason he won't let you test fit them. |
10-31-2020, 08:55 AM | #5 | |
Rep 11
10-31-2020, 02:53 PM | #6 |
Rep 4,380
camber, fitment, problems, rims, setup, squared, stagger, wheels |
