BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > VTG Coding question
Studio RSR
      04-13-2019, 01:01 PM   #1
djones206
Drives: 2015 328d xdrive wagon
VTG Coding question
Hello, I've searched to see if anyone has had the same issue before, apologies if the answer is already posted and I missed it.
I replaced the VTG (transfer case control module) on my 328d wagon and I think I need to encode it to the car. I am using ISTA+ version 4.1. I can now see the VTG in ISTA+ and go through the replacement steps but still get an encoding error and cannot complete the VTG calibration because of the error.
Also, I get a "test failed" message when running the vehicle test in ISTA+ but can still acess all the control modules and rear/clear error messages.
Should I be using a different program to encode the new VTG.
-Possible helpful extra info
- Cable I am using
-The new module is used from Ebay
-The old module was completely dead and I could not read anything off of it.
-Couple pics of the car, picked it up from Copart over in Tulsa, my first wagon!
sspade2476.50
      04-15-2019, 06:25 AM   #2
88tuning.id
88tuning.id's Avatar
Indonesia
39
Drives: E39 520i Msport
try to code the module via esys.
or i can help you to code those module if you want.
T
Instagram: @tafikhulafaa & @88tuning.id
      04-15-2019, 06:54 PM   #3
djones206
Thanks! I'll start working on figuring out and setting up ESYS.
      04-19-2019, 01:10 PM   #4
djones206
I'm working on getting ESYS setup. With replacing a module like I did with the VTG motor, I am not sure if I can get away with psdzdata lite or full quite yet.
      04-21-2019, 06:49 AM   #5
88tuning.id
Indonesia
39
pm me your email, i'll send you the link.
      04-22-2019, 07:54 AM   #6
djones206
pm'd thanks!
      03-27-2023, 10:30 AM   #7
Issadirtymax
Drives: 2013 F30 M Sport, 2020 Duramax
T
Hey 88tuning.id, any chance you could help me with coding Vtg module in Esys? I have Ista+ and Icom but I can’t figure it out. I just rebuilt transfer case, Vtg needs calibrated, ecu functions says it’s responding correctly, I do the replace control unit function before attempting calibration, go to calibrate and it says I need to run replace control unit function first which I just did, tried over and over, and even tried a second used Vtg, tcase classification has been done and also no change. When I test either Vtg in servomotor ecu functions it fails after a second of spinning, I’m at my wits end with it and all I can think is perhaps the Vtg itself needs coded. Only dash light I have is traction control/chassis stabilization, no dsc codes in ista. Any information is a huge help, thanks.
      03-27-2023, 12:02 PM   #8
TheNine90
Drives: bmw
Is there any fault code relating to coding for VTG? I can help you code the module if its missing coding data.
      04-02-2023, 07:59 PM   #9
Issadirtymax
Yes, in Ista+ the error codes for Vtg are: 021908 (encoding: data invalid), 02190B (encoding: transmission failed), 440105 (transfer box Vtg: calibration faulty), in the test plan it says to replace the control unit, I have a spare but it’s coded for another car, I took the car to Bmw over the weekend, they want 2999.00 to replace with new Vtg. I obviously picked the car up that day and said thanks for trying. So I believe the next step is to try to code either the original or new used Vtg module to the vin of the car and then calibrate.
      04-03-2023, 01:13 AM   #10
TheNine90
Drives: bmw
Try to code then calibrate.
      04-03-2023, 03:00 PM   #11
Issadirtymax
I have tried to run the repair procedure then calibrate 50+ times in Ista+, if you’re referring to coding the Vtg itself to the car with some other program like esys or ncs expert I don’t know how to do that nor do I have esys. Could I pay you to do it remotely?
      04-03-2023, 03:02 PM   #12
TheNine90
Drives: bmw
Pm me i can help you do it remotely using enet cable
      04-03-2023, 03:07 PM   #13
Issadirtymax
Okay thank you, pm’d
      11-01-2023, 05:50 PM   #14
Albert1976
Drives: Bmw f30
I have the same problem with my recently bought used VTG module which I wasn’t able to code. Could you help me as well?
