04-29-2019, 06:17 AM | #1 |
Rep 49
5AC HBA Activation on KAFAS2
Hi,
Could anyone perhaps provide the required FDL codes for activating HBA on a F20? I have only found info about this for the F10 with FRM. I want to avoid VO Coding because of the loss of other codings already made The car is equipped with Kafas2 and FLE lights. I guess it would be something in FEM_BODY, KOMBI & KAFAS2? Any help is appreciated, thanks! |
05-09-2019, 01:17 AM | #2 | |
Rep 49
05-09-2019, 01:37 AM | #3 |
Rep 27
Have you also the HBA switch at the cluster steering column? Because without that, you can't make it get to work (as far as I know).
Previous bimmers: E30 318, E34 524TD, couple of E32 750i, E38 750i
05-09-2019, 07:47 AM | #4 | |
Rep 49
The only thing is it won't work when you start the car in Auto mode when it's already dark, then you will have to flip the switch back and forth for it to enable Do you know the parameters to change? |
05-10-2019, 12:28 PM | #5 |
Rep 27
Again, as far as I know, you need the stalk with the hba switch in order to make it work on a f3x. Maybe read this:
https://www.bimmerfest.com/forums/sh...644297?page=11 |
05-14-2019, 01:24 AM | #6 | |
Rep 49
04-20-2021, 12:44 AM | #7 |
Rep 32
5ac, f20, hba, high beam assist, kafas |
