BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > M Button Retrofit
      05-12-2019, 08:39 PM   #1
EVEda235i
Mr. Clutch
EVEda235i's Avatar
Drives: 2015 M235i
2011 BMW 335i  [9.50]
Hi guys. I've looked far and wide, but it seems no one has attempted this. I was looking to see how feasible it is to buy the M1 and M2 buttons and install them where the blanks currently sit. Pics of buttons below
EDIT: Buttons installed! And they definitely press like the others. But have not doen any wiring. So for now they just look cool.
Obviously you would need the M-Sport wheel WITHOUT the active cruise control. Reason i ask is if i can get the button cover to physically press like the rest than I could theoretically sauder into the circuit board behind the bottons and wire that to a remote that controls an aftermarket exhaust valve or meth kit.
If u have ideas or have seen someone already attempt this please share.
Cheers
Quiet M235i
      05-13-2019, 02:14 AM   #2
knyghtryda
Drives: 2018 M240i M Performance Ed.
I have thought about doing the same thing, and have looked up what it would cost to buy a spare set of M Sport buttons to cut up and rewire. I'm pretty sure at this point that cutting and rewiring won't be necessary. From the look of the pinouts it should be as simple as popping off the blanks, put in the M buttons, then attempt to tap the LIN port off the steering wheel controller or just tap the CAN BUS of the steering controller. CAN bus would give you more info, but LIN bus guarantees you that the signal absolutely coming from the steering wheel buttons.
      05-13-2019, 11:15 PM   #3
EVEda235i
Mr. Clutch
EVEda235i's Avatar
Drives: 2015 M235i
Gotta be honest dome of that sounded like Mandarin to me. But i took apart the wheel/button assembly today and you are right. Putting in the M buttons would be as simple as popping out the blanks and clipping in the buttons.
I see what you mean as well with regard to the signal and power wires coming out of the circuit board. Do you happen to know with ones are lin bus and witch ones are can bus?
Quiet M235i
      05-25-2019, 11:48 AM   #4
doumyouji
doumyouji's Avatar
Drives: 435I GC
Obviously you would need the M-Sport wheel WITHOUT the active cruise control. Reason i ask is if i can get the button cover to physically press like the rest than I could theoretically put a button behind it (think keyboard) and wire that to a remote that controls an aftermarket exhaust valve or meth kit.
If u have ideas or have seen someone already attemot this please share.
Cheers
Actually someone in china has been doing this mod for business
they mod the M1/M2 botton for exhaust flap control unit
      05-25-2019, 11:51 AM   #5
EVEda235i
Mr. Clutch
EVEda235i's Avatar
Drives: 2015 M235i
Cheers
No way! Can u share a link? Or contact info? I coukr be their US franchise
Quiet M235i
      05-25-2019, 11:58 AM   #6
doumyouji
doumyouji's Avatar
Drives: 435I GC
this is the guy i get inquiring,although im not getting info for aliexpress
https://market.m.taobao.com/app/idle...5&forceFlush=1
      07-13-2019, 10:40 AM   #7
Jorpibe
Drives: Bmw f31
Alguna novedad?
      07-14-2019, 07:50 AM   #8
EVEda235i
Mr. Clutch
EVEda235i's Avatar
Drives: 2015 M235i
Originally Posted by Jorpibe View Post
Alguna novedad?
Good news is the M buttons can be used to replace the blank buttons! Next step is to attempt to sauder into the circuit board behind the buttons
Quiet M235i
      07-15-2019, 11:14 AM   #9
Fry-man22
Drives: 2014 335i M Sport
Looks good. Just a pedantic note, I think the word you're looking for here is "Solder". Good luck!
      07-15-2019, 04:20 PM   #10
EVEda235i
Mr. Clutch
EVEda235i's Avatar
Drives: 2015 M235i
solder* yes. Thanks i'll update soon. Hoping to connect a single wireless 2 channel remote and have a a relay for the meth kit and another for an exhaust cutout
Quiet M235i
      09-08-2019, 11:41 AM   #11
Jorpibe
Drives: Bmw f31
Genial,me gustaría poder habilitar esos 2 botones para poder usarlos,si consigue hacerlos funcionar me podría enviar un mp.gracias
      09-08-2019, 11:48 AM   #12
EVEda235i
Mr. Clutch
EVEda235i's Avatar
Drives: 2015 M235i
Quiet M235i
      09-15-2019, 02:52 AM   #13
lordloki
Drives: 328i 2015 (f30)
curious to follow this. I'm trying to figure out how to read the button presses coming from these, as well as a few things on the idrive controller. I have access to a CAN feed (tapped into CAN H and CAN L) but am having a tough time parsing the packets. Anyone know where I should go to start looking?
      09-15-2019, 09:01 AM   #14
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
Drives: BMW 316d, BMW F40 116d
Would be awesome to retrofit the Sport or Sport+ on the M buttons on non M cars.
      09-15-2019, 02:35 PM   #15
EVEda235i
Mr. Clutch
EVEda235i's Avatar
Drives: 2015 M235i
I'm hoping to introduce an outside circuit into the stem to control components that aren't oem. Could u elaborate a bit on the CAN access?
Quiet M235i
      09-15-2019, 02:37 PM   #16
EVEda235i
Mr. Clutch
EVEda235i's Avatar
Drives: 2015 M235i
That's next level. Not entirely sure how u could do that yet. Aiming for the meth and exhaust cutout control first
Quiet M235i
      09-16-2019, 03:31 AM   #17
Techno 9000
Drives: 435D Estoril Blue
Indeed. That would be ideal, one press of the thumb to take you into SPORT without taking your hand off the wheel.
Or even replicating the function of the Driving Experience rocker on the Steering wheel would be a step forward for non-M cars. So the top blank for modes toward Sport and Sport + and the bottoms blank toward Comfort and Eco Pro. Almost running the buttons in parallel with the Driving Experience rocker.
Could that be possible?
      09-16-2019, 03:56 AM   #18
rlmesq
Drives: 2018 440i M Sport
If you have adaptive cruise control, those are the buttons to adjust closer/farther following distance.
      09-16-2019, 04:51 AM   #19
EVEda235i
Mr. Clutch
EVEda235i's Avatar
Drives: 2015 M235i
Correct. In that case this wouldn't work for you
Quiet M235i
      09-16-2019, 04:56 AM   #20
EVEda235i
Mr. Clutch
EVEda235i's Avatar
Drives: 2015 M235i
Anything is "possible", but unless you can run a cable all the way to the rocker switch (not ideal) you'd need to run a wireless setup. Probably along the lines of what i want to do with the cutout/meth.
This is the remote/relay setup I'm going with.
eMylo DC 12V 1CH RF Relay... https://www.amazon.com/dp/B01A6VOH9W...p_mob_ap_share
Quiet M235i
      09-16-2019, 07:24 AM   #21
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
I think it would, but would need more than just replacing buttons.
Finding which cable does activate the drive modus up or down for instance.
      09-16-2019, 02:04 PM   #22
rlmesq
You could probably replace the stock buttons with M buttons, but that would seem silly.
I wonder if the wiring for ACC is there in cars without it... kind of like the rear fog light switch you can enable by breaking a couple of tabs. That might make it easier to tap into existing wiring and use it for another purpose, instead of running wires as some have suggested.
