BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Need help: Will Z4 rims fit on a 428i (F36)
      06-24-2019, 11:59 AM   #1
socajam
Drives: BMW 428i
Need some help with this. Does anyone know if 2004 Z4 rims will fit on a 2016 428i (Gran Coupe) F36?
I know the bolt pattern on both is 5x120 and the center bore is 72.6mm, but is there anything else I need to be concerned about?
Reason I am asking is that someone is selling a nice set of rims/tires that were bought for a 2004 Z4 and I thought they might be nice on my 428i. The rims are 20" and the tires are 225/30/20. I have 18" on my car right now (225/45/18). I used a couple of websites to do a tire size comparison, and these 20" are about .7" smaller in diameter than what I have on (width is exact). I think that is quite signifcant, so if I were to buy these, I would have to take the current tires off and put something closer in size (diameter) to what I have.
Any comments/suggestions would be appreciated...
      06-24-2019, 05:34 PM   #2
Korvo
Respect My Authoritah
Korvo's Avatar
Drives: 2014 335i M-Sport
You need to watch the wheel offsets. That's what'll be different.
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
      06-24-2019, 06:07 PM   #3
upsidedownfunnel
Drives: 2014 335i
2014 BMW 335i  [0.00]
If the offset is larger than your stock wheels, you can always just add spacers to compensate.
The offset for F30 20" wheels are +34 for square setup and +36 front and +47 rear for staggered. It looks like 2004 Z4 wheels have a +47 offset for a square setup and +47 front / +50 rear offsets for stock 18" wheels of the same width (8"/8.5") as the staggered F30 setup. So assuming the 20" wheels have a similar offset as the stock size, they would probably be fine if you just add a 12-15mm spacer on the fronts and left the rears alone.
4 series, 428i, f36, gran coupe
