08-19-2019, 03:40 PM | #1 |
Rep 263
High Beam Assist (FLA) retrofit kit: mirror with FLA camera, steering wheel column...
I´m selling a complete HBA retrofit kit as have a new F34 with stock HBA. I have retroffited with these parts HBA in my former 2016 F34. It should fit F30, F32, F33, F34, F36 as far as I´m informed. Please check the below listed part numbers to be on the safe side. As you also can see at the pictures following parts are included: - rear view mirror with FLA camera (+ electrochrom, alarm) 51169345368 - plastic covering for mirror/camera 51169275006 - orig. BMW connector with self made harness - steering wheel column switch cluster with switch for FLA (+ BC, rain sensor) 61319351145 The parts are like new. Price new at BMW approx. 1300 Euro for all parts. I´m selling everything for only 300 Euro firm. Located in Germany. Shipping possible. Last edited by TePee; 08-19-2019 at 04:05 PM.. |
11-05-2019, 04:45 AM | #5 |
No 55mph
1623
Rep 8,479
If your car has Steering Wheel Heating you would need P/N 61319351146 Steering Column Switch instead of OP version listed - all other options being equal as described
And the Rearview Mirror is for following Options: Rearview mirror EC / LED / FLA 1 51169345368 For vehicles with
So if your car has factory Alarm - this mirror will not work...
xxxjecxxx2153.00 |
11-27-2019, 11:22 AM | #6 |
Rep 8
I am ready to retrofit HBA on my 2013 328i MSport with Xenon Adaptive light.
i just purchased review mirror with FLA camera. Can i just retrofit wires and coding without steering column with HBA button? Also need help with coding please.... |
11-27-2019, 01:34 PM | #7 | |
E36fiend
286
Rep 637
Drives: 2014 435i xDrive
What help do you need with coding? I imagine you'll need to inject CAFD for the FLA module after you've installed it, then after you've added the 5AC option code to your FA (and removed 8S4 to enable VLD since you have adaptive headlights) you will VO code the FLA module along with FEM_BODY. |
12-08-2019, 11:06 AM | #8 |
Rep 8
Need suggestion
After replaced my steering column with HBA assist switch, my exiting steering wheel heater no longer work and HBA assist switch will not turn on.
this is my 1st retrofit, i am still waiting for FLA wire retrofit since my ordered parts are on the way.Also i haven't code the car yet. Please help?? |
01-18-2020, 05:11 PM | #9 |
Rep 263
Hi & sorry, I haven‘t been here for longer time.
Roxxor has written here a great FIY for HBA retrofit. There you should find all necessary info: https://f30.bimmerpost.com/forums/sh....php?t=1252786 If someone is interested the steering wheel column switch cluster is sold, but I still have the mirror with FLA camera etc. |
02-26-2020, 05:01 PM | #10 |
Rep 263
The complete set is available again. I have another steering wheel column switch, it is the new LCI one and besides HBA/FLA even suitable for heated steering wheel. Part number 6833359.
Offer for 300 the complete set. |
07-30-2020, 03:22 AM | #11 |
Rep 4
Is it also possible to retrofit the fla into an f20? I am asking do to the fact that I am owner of an f20 LCI with Halogen and I would like to retrofit the LED headlights with fla oder inkluding Kafas and the adaptive led headlights. Due to the costs I prefer the normal Led headlights with fla.
I am living in Germany as well |
09-10-2020, 02:33 AM | #12 |
Rep 9
Hello everybody,
is it possible to retrofit LDW (lane departure warning) if you have FLA (high beam assist) camera (the one bulit in rear view mirror) and not KAFAS camera (the one behind windshield)? I already have steering wheel with vibro motor inside. I heard it can be done with KAFAS camera and module, but that is not an option as I am not willing to change my windshiled just for this retrofit. So I am asking if it can be done with FLA camera. Thank you! |
09-26-2020, 03:59 PM | #13 | |
Rep 742
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
10-26-2020, 05:40 PM | #14 |
Rep 12
Hello guys,
I want to retrofit high beam assist on my f30 lci. I already have the kafas camera with lane departure warning. Do I need to change my mirror? Or is the kafas camera enough for that? And what I will be needing (parts) for this retrofit? Thanks in advance |
10-27-2020, 04:23 PM | #15 | |
Rep 742
https://f10.m5post.com/forums/attach...1&d=1356048234
Alimaala6.00 |
10-27-2020, 04:30 PM | #16 | ||
Rep 12
How about the coding? Dose anyone know how to do it? And can it be done with bimmercode? And do you have a part number? I have rain sensor and lane departure warning with steering vibration |
10-03-2022, 09:57 AM | #19 |
Rep 1,177
lmao this ad was years ago. I'd assume things are gone by now.
2020 X3 M40i
2015 328i - Sold @ 104,000 miles |
fla, hba, high beam assist |
