08-20-2008, 03:04 PM | #2 |
Rep 14,393
Never heard of a no drill version. Mine has 3 wood screws on each end. It pops out real easy to use on the two lower brackets for push ups. You can always fill the holes with caulk.
Crazy Diamond
08-20-2008, 03:08 PM | #4 |
Rep 634
I have this... "Everlast Multi Function Chinning Bar"
http://www.amazon.com/Everlast-Multi...9262239&sr=8-3 I like this thing, I can do pull ups, and chin ups with all different grips, and I use it for push ups occasionally. (Using it for crunches is bad though... then again, you should probably be doing them with your legs up*.) ***Then again, I'm really light, so if you're a 250lb+ dude hanging off something mounted in a doorway might not be the best option.
ED & PCD = DONE & DONE! 08' AW/Coral 335i coupe 6-speed (Premium Pkg, Sports Pkg, Heated Seats) *European Delivery
08-20-2008, 03:09 PM | #5 |
Optometrist Prime
24
Rep 516
i have one and i like it. as long as your door frame is very sturdy. it may leave some dents in the wood where it rests on one side.
08-20-2008, 03:12 PM | #6 |
Rep 634
Ha, same here... I uses it on a wood frame, got small dents. But I usually use it on a metal frame door; works fine.
08-20-2008, 03:58 PM | #7 |
Rep 2,900
On all wood frames I've seen they start separating.
08-20-2008, 04:06 PM | #8 |
555
Rep 6,169
I got one of those door hanging one, it works...my friend who is 200+ have no problem using it...very sturdy, got it for 29 bucks at Sports Authority
MKIV 6spd 1000hp Club |
08-20-2008, 04:16 PM | #9 |
Rep 26,878
Drives: 2-325 330 2-335 2-Z4 2-135 X5d
The ones without screws usually unscrew in the middle to expand
08-20-2008, 04:32 PM | #10 |
Rep 1,352
Not bad in a pinch. I personally don't care for them because I'm around 6'5'' with shoes on and it forces me to bend at the knee too much as I would hit the ground with my legs extended. Something to think about.
