01-28-2020, 03:24 PM | #1 |
Rep 8
A/C Harness
I have a 2012 F30 and wanted to do a LCI Radio trim panel change but while doing it found out that the clip for radio/AC trim is struck and will not come out so tried to do it with a knife (THIC F30 Trick) but it did not came out and in the process i broke the clip alittle but everything is still working but I m just check how easy is it to replace the harness or the corrector for the A/C if I break it as I m trying to install apple carplay in my car soon.
Thanks |
01-28-2020, 11:35 PM | #2 | |
Rep 10,473
01-29-2020, 10:36 PM | #3 |
Rep 8
01-29-2020, 10:56 PM | #4 | |
Rep 10,473
That said, perhaps this link will help you discover your answer as I can make no logic of what you are asking. https://www.realoem.com/bmw/enUS/par...335i&mg=61 |
01-30-2020, 07:04 AM | #5 |
Rep 16,200
If you break a connector chances are what you'll break is the tiny latch that keeps it in place. The connectors are a real PITA because they make the latch releases pretty much invisible to the naked eye. If you break the latch the only potential problem is that the connector could vibrate loose, so secure it with a bit of electrical tape.
f30 3 series, harness, radio trim |
