06-11-2020, 07:11 PM | #1 |
Rep 7
Engine still stops despite ASS disabled
I’ve got a 2015 F36 and despite having ASS turned off and being in Sport + mode, the engine will sometimes turn off when put in park or neutral. It doesn’t happen every time.
Has anyone seen this behavior before? Any remedies? As of right now, I am coded to remember last setting so since it’s turned off, it remains off. |
06-11-2020, 08:57 PM | #3 |
Rep 7
Yes I have and strangely, I got the opposite behavior where ASS was always on so I would have to manually turn it off every time I started the car. So I turned the feature back off.
06-11-2020, 09:22 PM | #4 |
Rep 16,195
Since ASS only turns the engine off when it's in Drive it may not be the problem. You need to look for fault codes with an OBD diagnostic tool.
06-12-2020, 12:11 AM | #6 |
Rep 2,499
Are you sure you're interpreting the light correctly? If the light is ON, that means ASS is OFF. If the light is OFF that means ASS is ON. You want the light to be on at all times.
The only reason I ask is because you said you hard-coded it off but it turns on every time you start the car. I think you're just misinterpreting what the light means by the ignition button. |
06-12-2020, 10:03 AM | #7 |
Rep 1,045
does your engine shut off to "Ready" or "off" state ? It's on your tachometer, if it drops to ready then it is ASS related, if it goes off, then it's something else.
Mods: Dinan Tuned, Intake, Catless DP
06-12-2020, 11:01 AM | #8 |
Rep 7
06-12-2020, 11:52 AM | #9 |
Rep 259
It is, the reason u see that sign when the light is off, it's because the engine hasn't warmed up yet properly. ASS only works after the engine is at operating temperature
Light on the button HAS to be ON for ASS to be disabled |
Lance_Goodthrust4.50 |
06-12-2020, 12:26 PM | #10 |
Car Hypochondriac
336
Rep 904
06-12-2020, 05:16 PM | #11 |
Rep 844
Well I went to look at mine...
And I cannot turn it on...I turned it off years ago, just tried it, light over start button will NOT turn off. Engine is at operating temp. I mean, I won’t spend a nickel to fix it...but mine doesn’t work right either. |
06-12-2020, 05:32 PM | #12 | |
Rep 7
Because ASS didn’t work I’ve always thought that the light off meant ASS was off. It makes sense now that sometimes when I put it in park or neutral, it decides to shut off the motor. I’m not sure I’m going to burn any time or money trying to fix it unless there’s and issue where I actually have it disabled. This is BMW number 6 for me but the first with ASS. I guess I’ll just run it with the light on and see if it gives me any grief. Thank you to everyone who chimed in! |
06-12-2020, 07:03 PM | #13 |
Rep 367
I haven't coded anything, but the ASS in my car turns on about once a week. As soon as it does its thing I just press the button again (light turns on = off - for me) and ignore it for a week.
06-13-2020, 12:01 AM | #14 | |
Rep 2,499
06-15-2020, 01:30 PM | #15 |
Rep 7
That is certainly plausible. I haven't seen any indication that my battery isn't up to snuff but I should probably get it tested to verify for certain.
06-16-2020, 07:49 AM | #16 | |
Rep 848
Drives: BMW 435i
ASS is always off in my car, but the few times I've played with it in the summer I noticed the engine would start on it's own if I was stopped and the A/C needed to come on due to the car interior getting too hot.
06-17-2020, 09:04 AM | #17 | |
Rep 884
As others have mentioned, there are several scenarios under which ASS will not turn off the motor; including battery state, HVAC requirements etc. |
ass, auto start stop |
