12-31-2021, 07:24 AM | #1 |
Rep 39
Upcoming EGR cooler recall
I had my oil changed yesterday (12/30/21) and the BMW service person said there's going to be an EGR cooler recall coming soon. He didn't know when it would arrive (nothing shows up when I run my VIN), but here are the details from my paperwork:
Defect Code: 0011280600 Defect Description: B110921 Recall: EGR Cooler - N47T High Temperature Bulletin Number: B11 09 21 Recall Number: 21V-907 Campaign Status: 00-Open He also suggested that I replace the EGR when they do the cooler as it would just be the price of the part (no extra labor). I haven't dug into what that means yet, but I figured I'd pass the information along to this group.
2014 328d XDrive Sedan, M-Sport Estoril Blue
Former: 1999 F250 7.3L, 2000 Jetta TDI, 2009 Jetta TDI |
12-31-2021, 09:33 AM | #2 |
Rep 906
Yep, word is getting out.
I think your SA was referring to the EGR valve, which bolts right on to the cooler. Considering the part itself is around $150-200, that's not a bad idea at all to do some preventative maintenance. The procedure to remove the EGR cooler also calls for a coolant drain and fill. This is another plus for preventative maintenance as well.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
12-31-2021, 10:05 AM | #3 | |
Rep 39
01-13-2022, 05:05 AM | #4 |
Rep 2
Hi, I'm from Poland and I have a problem. I have a car from the USA bmw f30 328d. There is a service action for my car No. 0011280600
BMW Service cannot do it because they don't have details. What parts to order and what needs to be done. I get an error looking for this information. Can someone help me? |
04-13-2022, 08:37 AM | #6 |
Rep 39
No, not yet. They cancelled my appointment because the parts aren't available. I checked with the dealer last week and there's still no ETA.
05-13-2022, 01:58 PM | #8 | |
Rep 163
Thanks! |
05-16-2022, 10:19 AM | #9 |
Dr Drei
71
Rep 245
EGR valve part# 11717810871.
But good luck finding them online. Most places I've looked don't have any in stock.
GLK 250 // 126xxx miles // 36 MPG // Mobil1 ESP 5w30
05-16-2022, 03:30 PM | #10 | |
Rep 163
06-17-2022, 06:54 AM | #11 |
Rep 39
EGR Recall complete
I was able to get my car in for the EGR recall the other day and figured I'd post the information. The recall includes an EGR valve, so I didn't have to buy one, as I originally intended to do. My intake was fine, so that was not replaced. Here are the parts and a couple of bad pictures. Enabled - looks like they put in the gaskets.
Edit - coolant was topped off, not flushed.
Former: 1999 F250 7.3L, 2000 Jetta TDI, 2009 Jetta TDI Last edited by LCornice; 06-17-2022 at 08:52 AM.. |
ssf55646.50 |
06-17-2022, 08:10 AM | #12 | |
Rep 163
06-17-2022, 08:16 AM | #13 |
Rep 39
Good question. I emailed the SA to ask. I'll update the thread when I get an answer.
06-19-2022, 07:57 PM | #14 |
Rep 163
I just dropped off my 328d for the EGR recall. I made a small mark with a sharpie on the EGR valvle to see if a new one comes with the EGR cooler. I am also going to have them do a coolant change just because I like preventative maintenance.
Will let everyone know how it goes.
06-20-2022, 01:46 AM | #15 |
Rep 906
This isn't the correct procedure. The prerequsite work to replace the EGR cooler is to drain the coolant. It's physically possible to replace the EGR cooler without completely draining the system, but the moment the cooler is removed coolant is going to drain through the ports where the cooler was. This would expose the coolant circuit to air. At minimum, the dealer needs to do a vacuum fill after the cooler is replaced.
ssf55646.50 |
06-20-2022, 07:39 AM | #16 | |
Rep 39
06-20-2022, 07:58 AM | #17 | |
Rep 163
06-20-2022, 08:04 PM | #18 |
Rep 906
It should be part of the EGR replacement procedure to drain the coolant. It's also BMW's position that coolant should never be reused. You should be getting a free drain and fill out of this recall rather than a complete flush.
06-20-2022, 09:42 PM | #19 | |
Rep 163
Thanks
06-20-2022, 10:15 PM | #20 |
Rep 906
Ask to see the repair procedures for the EGR cooler replacement. The one for the recall slightly differs from the normal procedure due to the physical differences between the old and redesigned cooler. But both should call out draining of the coolant.
I'd be OK with letting it go if and only if they vacuum filled it or bled the system. Under no circumstances should there be air in the cooling system, which this repair introduces.
06-28-2022, 07:25 PM | #21 |
Rep 51
Here's the TSB for the EGR cooler, it says they just drain the coolant ad the fill it up
https://static.nhtsa.gov/odi/tsbs/20...77615-9999.pdf |
07-20-2022, 04:06 AM | #22 | |
Rep 29
