BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Welcome lights coding
      05-02-2022, 01:35 PM   #1
Frs4l
Frs4l's Avatar
Drives: BMW F30
Exclamation
Hi bimmers !
i have a little problem that been bothering me for a couple of days now with my welcome lights.
recently i did retrofit power folding mirrors and had to code VO then FEM coding so i weirdly lost all my coding, i was able to code everything back easy but not the welcome lights
so my actual coding when unlocking the car the lights goes on (Angel eyes, xenon) day 'n night, so i coded only in dark but in the day my DRL doesnt light up, before when unlocking the car in daylight the DRL & fog light lights up sosftly and in night time (foglight, angel eyes, xenon + door handles) lights up i cant put it back as it is
please can someone tell me whats the proper coding for that,
i tried some previous treads but no luck, thank you in advance
[COLOR="DarkRed"]apparently it's another option called I guess (coming home/leaving home) which lights up the cabin and the headlight for you before and after you quit the car, it seems that I lost this option from my NBT anyone with coding for it please thanks [/COLOR]
Newby to the Bimmers world
      05-02-2022, 03:33 PM   #2
TheNine90
Drives: bmw
This is the code for DRL part of welcome light
MAPPING_TAGFAHRL_V_L_PART_OF_WL
MAPPING_TAGFAHRL_V_R_PART_OF_WL
      05-02-2022, 03:49 PM   #3
Frs4l
Frs4l's Avatar
Drives: BMW F30
In fact they're on, I just need to know what to code to get that day (DRL) and night (DRL & Xenon) like get the car to distinguish between the day 'night & thanks for your reply
      05-02-2022, 04:06 PM   #4
TheNine90
Drives: bmw
Dont know how to change individually for night and day. Never seen that option. Maybe someone else knows.
      05-02-2022, 04:09 PM   #5
Frs4l
Frs4l's Avatar
Drives: BMW F30
Thank you anyway ! Someone told me to code tfl_Modus idk maybe its what am looking about, I'll give it a try
      05-02-2022, 04:36 PM   #6
4x4kiwi
Drives: 2012 BMW Active Hybrid 3
I believe tfl_Modus decides which positions of the light switch DRL's operate i.e. tfl_s is in off and Auto posn. David
      05-02-2022, 04:49 PM   #7
Frs4l
Frs4l's Avatar
Drives: BMW F30
Thank you for your reply, well I was told to put TFL_Modus in DRL_S, I went to the car now and this is what I found
      05-03-2022, 04:55 AM   #8
Frs4l
Frs4l's Avatar
Drives: BMW F30
Originally Posted by Frs4l View Post
Hi bimmers !
Anyway I came to conclusion that what I need it's not welcome lights it's (follow me home or coming/leaving home) option 😓 my bad guys any help coding those please the option disparues from my HU
      05-03-2022, 02:24 PM   #9
4x4kiwi
Drl_s enables the DRL's in the Park posn of the light switch, as well as Off and Auto
I think what you are after is Headlamp courtesy delay feature
(from the manual)
The low beams stay lit for a short while if the
headlamp flasher is switched on after the ignition
is switched off.
Setting the duration
1. "Settings"
2. "Lighting"
3. "Pathway light.: s"
4. Set the duration.
The setting is stored for the remote control currently
in use.
      05-03-2022, 10:44 PM   #10
Frs4l
Frs4l's Avatar
Drives: BMW F30
(from the manual)
is switched off.
1. "Settings"
2. "Lighting"
in use.
Unfortunately I lost the option when I flashed my nbt evo 🤦🏻*♂️ so if there's something I can code for that I'll appreciate it
      05-05-2022, 08:36 PM   #11
4x4kiwi
Do you have the welcome lights selection in that menu
      05-06-2022, 03:50 AM   #12
Frs4l
Frs4l's Avatar
Drives: BMW F30
Yes sir, i have the welcome light in light settings, the checkbox to activate/deactivate and duration settings
angel eye, e-sys, f30, f30 2013, led, xenon headlights
