02-17-2023, 07:17 PM | #1 |
Rep 2
Help please 2014 328xi "Drivetrain Malfunction"
Hi I'm at a loss my 2014 BMW 328xi has been down since 12/10/22. It's too close to my house for wheel lifting dolly, no-one will tow to shop as I cannot get car in Neutral. Any guidance is greatly appreciated! I think it might be a fuse or electrical circuit issue. Details below:
Car threw itself into neutral w/drivetrain malfunction error message. I Replaced battery w/non-AGM then w/AGM & was able to register the battery Car cranks does not turn over Following codes appeared on my OBDII: 1F01515 Valvetronic, supply voltage: Line disconnection 113027 Relay, ignition and injection system, supply voltage, fuel injection: Line disconnection 123516 Electric wastegate, activation: Line disconnection 1B5202 Terminal 15N_1, voltage supply switched by CAS/FEM, electrical: Short circuit to ground 1B5402 Terminal 15N_3, voltage supply switched by CAS/FEM, electrical: Short circuit to ground 1B5302 Terminal 15N_2, voltage supply switched by CAS/FEM, electrical: Short circuit to ground 133102 Valvetronic relay, activation: Short circuit to earth 1F4A02 Relay, ignition and fuel injectors, supply voltage to ignition: Short circuit to earth CD9010 LIN, communication (electrical coolant pump): missing 1C4110 Oil level sensor, electrical: Malfunction 201004 CBS client: output of substitute value 130002 VANOS solenoid valve, inlet activation: Short circuit to earth 130202 VANOS solenoid valve, exhaust, activation: Short circuit to earth 122002 Bypass blow-off valve, activation: Short circuit to earth 12B102 Oxygen sensor heating before catalytic converter, activation: Short circuit to earth 102A01 Hot film air mass meter, signal: electrical fault 1D2402 Map thermostat, activation: short circuit to earth 1C0202 Oil-pressure control valve, activation: short circuit to earth 1F4A10 Relay, ignition and injectors, activation: Line disconnection 133104 Valvetronic relay, activation: Line disconnection 480143 SZL interface signal invalid 48279B ICM: Undervoltage in vehicle Other codes: 480A11 Brake pad wear sensor, front axle, replace brake pads CD0420 ZGW, FlexRay controller signalling fault E12C1D JBE interface (afterrunning period, terminal 30, fault-controlled, 0x3xAC) Signal invalid 801206 Blower output stage: undervoltage or overvoltage detected 801225 A/C compressor: deactivation due to underpressure in refrigerant circuit E2EC08 Interface instrument panel (distance travelled, kilometres, 0x330): Signal invalid B7F339 TCD: Undervoltage detected B7F341 Backup battery: Hardware faulty 030490 Steering wheel electronics module (LRE): Missing LIN slave 804080 Ignition on: Startability limit reached or ignition on for a long time 8040B9 Deactivation of terminal 30B: upper startability limit reached 8040BD Reset or deactiviation of terminal 30F |
