BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > O2 Spacer That Works!
      08-04-2023, 08:27 PM   #1
armenh7
Drives: 2017 340i
I shared this in some Facebook groups but felt it's worth posting here too. This benefits people that don't want a tune OR are in a state that can detect modified tunes and so that person is forced to flash back to stock. I've had multiple FXX B58 owners use this same spacer and it worked for them too. Unfortunately, I don't have data for GXX B58 cars. I've done over 1000 miles with various types of driving. I've also accidentally reset codes while coding the car and monitors set within 1-2 drive cycles.
1. Doesn't cost $300+
2. Tunes don't pass emissions in some states and/or can be flagged as modified. Visual part is easy to find an inspector that doesn't care.
3. For people that find stock power adequate and throw a downpipe on for sound and don't want a check engine.
The straight O2 spacer worked on my car. 2017 340i with catless downpipe and stock tune. Be sure to REMOVE the mini-cat (don't reinstall the cap) that comes in the spacer otherwise it can trigger delayed rich to lean response codes. The spacer needs to be 55mm in length.
https://s.click.aliexpress.com/e/_DFkErmn
***If you are using a catted downpipe and it sets a cat efficiency code, you can still use a spacer but it needs to be a short one. It needs to be 32mm in length.
Here is a link to one that worked. https://s.click.aliexpress.com/e/_DCFwrh1
      08-07-2023, 08:04 AM   #2
XxThe_RemedyXx
XxThe_RemedyXx's Avatar
967
Drives: 2016 340i xDrive
Interesting. So I live in NY and run catless and always have an issue passing inspection. I always have to revert back to the stock cat, flash back to stock tune and lock the DME to get it to pass. With this, would I be able to leave my Stage 2 tune in place and just drive it to the inspection and pass because all the monitors are ready?
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Sutphin Custom Tune - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI - Dinan Midpipe
      08-07-2023, 11:42 AM   #3
armenh7
Drives: 2017 340i
I believe stage 2 disables the cat monitor so that won't work. Of course you can simply check and see if that's true or not with any OBD scanner.
I'm not sure if locking your DME would be necessary either but just flashing back to stock and using the spacer should be enough.
      08-07-2023, 12:28 PM   #4
XxThe_RemedyXx
967
That's easy enough if true and would make life much easier.
      08-07-2023, 02:50 PM   #5
5w20
@_sunbish
5w20's Avatar
294
Drives: Bmw 435i & 340i
It will work if you don't select the cat disabled check box. The whole point of that spacer is to emulate the catalytic converter.
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5
      08-07-2023, 03:19 PM   #6
XxThe_RemedyXx
967
OK, so I'll try leaving the Stage 2 tune ON and remove the option to disable the CEL and see if it clears up and gets ready for inspection. What about Cold Start CAT heating? I currently have that set to OFF because it's not necesarry, but does it need to be on OEM to run through it's standard process?
      08-08-2023, 10:41 AM   #7
yupetc
Drives: 2015 X535i
I'd just skip all this headache and go for the GESI-cat-integrated DP. It's worth every penny when you're able to safely stay clear of O2 faults plus the car won't smell like skunk fart all the time.
2015 X535i - CP Piston, Manley Rod, ACL/King bearings, MILVs VRSF full charge Pipe, Wagner FMIC, Hybrid Turbo, MHD2+ VRSF DP, UR Front/Rear Sway Bars, Eibach springs, Bilstein B6
2015 MINI COOPER - Mahle Pistons, Max Rods, BMS intake, CTS charge pipe, Wagner Intercooler, ByteTronik Tune, VRSF DP
2017 540i - MHD2+, VRSF DP, TU Pump
      08-08-2023, 11:36 AM   #8
armenh7
Drives: 2017 340i
That shouldn't affect the monitor
      08-08-2023, 11:37 AM   #9
armenh7
Drives: 2017 340i
That invalidates point #1
      08-08-2023, 09:14 PM   #10
yupetc
Drives: 2015 X535i
You're in a phase that I've gone through from my earlier days tinkering with different combo's of spacers to trick that O2 sensor circuit. At the end of the endeavor, I've spent more than the $300 benchmark and got nowhere close unless I simply go for a tune which enables a catless DP circuitry. Anyway, you may get lucky, but I'm more than sure that once you've out-grown the amount of trouble you'd go through, you'll likely go straight to the viable options, albeit defeating point #1. I praise your perseverance, happy motoring, bro.
      08-09-2023, 06:45 AM   #11
armenh7
Drives: 2017 340i
Maybe reread the post. This is tried and true.
      08-09-2023, 09:15 AM   #12
yupetc
Drives: 2015 X535i
All good, if it works well for you, it's a blast. I now have grown too old to accept a premium car arriving at stops with that skunky smell exhaust in the back side. Happy motoring anyway, pal.
      08-09-2023, 09:16 AM   #13
armenh7
Drives: 2017 340i
Gotcha, your second sentence made it all make sense
      08-09-2023, 11:59 AM   #14
XxThe_RemedyXx
967
I'm 43 and love the smell of my catless 340
      08-09-2023, 12:40 PM   #15
yupetc
Drives: 2015 X535i
I'm 44, with this impeccable math logic, you got less than a year to start disliking that catless smell, LOL.
I fitted a GESI cat in between the two O2 sensors, no smell, no fault code. That cat is rated for 500-850 horsepower, and I can say I'm also very happy with the catless-like performance but without the smell; although the cat itself is about 750 bucks, I also paid 150 bucks for a metal fabrication shop to custom fit it in, moved the O2 bungs a bit, etc..
      08-09-2023, 01:41 PM   #16
5w20
@_sunbish
5w20's Avatar
294
The gasoline smell is pretty stout, I prefer the smell of ethanol.
      08-09-2023, 01:52 PM   #17
XxThe_RemedyXx
967
Well you’re a pretentious fuck if you think everyone should like what you like.
      08-09-2023, 03:41 PM   #18
yupetc
Drives: 2015 X535i
Woa, didn't see that one coming. I'm so glad I'm not a pretentious fuck then. You do you, homes; and have at it.
      08-09-2023, 10:29 PM   #19
E90lova
Drives: F30 335xdrive
Active Autowerks and Fabspeed for 335 N55 cars.
      08-09-2023, 10:30 PM   #20
E90lova
UMM HMM
With a tad bit of Remi Martin go mix on the rocks
5w20294.00
      08-09-2023, 10:32 PM   #21
E90lova
15 YEARS and emission doesn't need exhaust to past.
      05-10-2024, 02:50 PM   #22
armenh7
Drives: 2017 340i
Updated post with information regarding aftermarket catted downpipes.
