BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Lights leveling issue
      11-06-2023, 10:58 AM   #1
pieciozord
Drives: BMW F30 318D
Hi. I have BMW F30 318D 2018 with LED standard lights. I have issue with front light leveling after I activated the foglight cornering then the scroll wheel control doesn't work. Looks like it doesnt work permamently as i disabled foglight cornering and the problem still exists. I using Veepek Adapter and Bimmercode app for Android.Any advice ? Thanks
      11-06-2023, 11:19 AM   #2
cjn
Drives: 2021 F40 M135iX
If you can look at the Expert Mode coding, check the FEM_BODY ECU.
3073 C_BLC_ENA should be set to not active (F30/F20 disable). If set to enable it will prevent the manual control working.
      11-08-2023, 04:01 PM   #3
pieciozord
Thanks it helps me!
