BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Brake Line Leak
      05-03-2024, 04:26 PM   #1
mastat89
Drives: 2015 BMW 320iXDrive
Brake Line Leak
Recently replaced my Master cylinder and vacuum pump and brake were working fine, then I noticed a leak on the line for my abs. Is there an easy way to fix this other than replacing the line and re-flaring?
      05-20-2024, 05:30 PM   #2
Wires
Drives: 2016 340i xDrive
A lot of times, I've found that if you loosen the nut, and then push the line back in until it bottoms out, and then tighten the nut again, that fixes that.
When I get issues on those types of fittings, it's when I start the nut, and just try to tighten it down without making sure the the line is seated into the mating fitting first. it ends up a bit crooked and leaks.
