Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
  E90Post
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > E90 owners check your tire pressure !!!
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
Reply
      07-25-2005, 06:16 AM   #1
egtlover74
Photographer
egtlover74's Avatar
40
Drives: 335is Coupe
Yes, check your tire pressure. There was a thread about how dealers don't check the tire pressure. I ignored it for the first night and then checked it the next day cuz I thought the ride was a little choppy. All 4 tires' pressure was 35 psi !!! So naturally I reduced them to 29.5 for fronts and 32.5 for rears since it was getting a bit hot. Now, it rides like a dream Perfect road feel and handling
      07-25-2005, 06:27 AM   #2
onesixeight
Drives: F82 M4/i8
Yup...I did some driving on some of my favorite mountain roads this weekend. I found raising the front pressure 3-4 psi helps to dial out some of the understeer.
      07-25-2005, 06:50 AM   #3
jammy
jammy's Avatar
Drives: E90 325i
I checked mine after reading the thread last week - all about 4psi over the recommended. Can't say I've noticed much difference though
Here's a question:- If I inflate a tyre to say 35psi on a hot summer's day, on a freezing winter's morning will the pressure be much lower (i think it would) and does this mean I should seasonally check and adjust tyre pressure?
      07-25-2005, 07:30 AM   #4
carl_d
carl_d's Avatar
Drives: E90 335i M-Sport N55 6SP Nov10
jammy
Yes - its bet to check you tried monthly! Every 10C change in temp is about 1 BAR or 1.5 psi. So a 30C change form winter to summer will be 3 BAR or 4.5 psi - enough to make a signicant difference to the way a car drives.
      07-25-2005, 08:16 AM   #5
Spaceman
Spaceman's Avatar
Drives: 2006 325i
Mine was 36psi all around. Took the extra pressure off the tires and it drives and handles 10X better.
check out http://www.corrinnemay.com
2006 325i Blk Sapphire Metallic, Beige Lthr, ZPP, nav, sat, xenon, fold-down seats and premium hi-fi.
      07-25-2005, 08:51 AM   #6
anthony_h
anthony_h's Avatar
Drives: E90 325i 6spd
I completely agree!!
I had to get my front left tire changed because I got a flat. The dealership left the tire at 44psi!!!!!! it was at 47 when hot.
the others were at 34psi when cool. so I had to lower the pressure but yes, check your tire pressure!!!!!!!
I left all the tires at 34psi. is that too hight?
      07-25-2005, 08:54 AM   #7
egtlover74
Photographer
egtlover74's Avatar
40
Drives: 335is Coupe
Open the driver's side door and look at the frame. It will say 29 fronts and 32 on rears. Yes, they are too high.
      07-25-2005, 02:26 PM   #8
Airboy
Drives: Some Subaru
Originally Posted by carl_d
jammy
Think you are 10x off the BAR to psi conversion. 1 BAR~15psi
      07-25-2005, 02:55 PM   #9
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
The dealer may check the tire pressure in their workshop which is usually much cooler (A/C running all the time) than the outside, so that might be a reason for higher than normal pressure upon delivery.
10 degree change in temp = approx 1 lb psi.
      07-25-2005, 08:08 PM   #10
CC 330i
CC 330i's Avatar
44
Drives: 330i SG/Blk/Alum
I think there are different recommended pressures for different speed ranges. If you plan to drive up to 100mph there is one recommended set of pressures, and slightly greater for 100mph and over if I am not mistaken. I think I am at 32 and 35 right now, but maybe I will drop them down a little bit. It's best to do the pressure measurements at about room temperature if you can (60-75 degrees F) and when the car has not been driven for several hours.
      07-25-2005, 08:19 PM   #11
RichReg
RichReg's Avatar
Drives: 2015 435Xi GC & 2000 323Ci.
Nope...that's just about right.
I got a slow leak from running over a nail...patched with no problems (yet). But it sure was one helluva wake up call!
      07-26-2005, 05:37 AM   #12
egtlover74
Photographer
egtlover74's Avatar
40
Drives: 335is Coupe
That is very true. 29 psi fronts and 32 rears is only true for 325i with sprot pkg. 330i non sport for some reason has much higher rear psi recommended. I believe 32 front and 39 rear or something like that. 330i sport pkg has similar to 325i sport pkg but I think only 1 psi higher thatn 325i sport
      07-28-2005, 08:49 AM   #13
matrix
Drives: 2006 330i
I have a 330i W/Sports pack, and the posted recommendation (in the door jam) says 38 Front and 45 Rear which seems high.
      07-28-2005, 09:02 AM   #14
egtlover74
Photographer
egtlover74's Avatar
40
Drives: 335is Coupe
I believe you looked at the pressure for maximum load and speed.
Normal driving conditions and light load for everyday driving is much lower. It is on owner's manual. Yes, I read it.
      08-02-2005, 03:38 PM   #15
zippo
zippo's Avatar
Drives: 2006 325i
My car was delivered with tire pressures all over the place, not inspiring confidence in my friendly dealer.
Yes, we've got to check the pressure manually periodically because of the way the car determines a problem with tire pressure....unlike some other cars (and other, more expensive BMW's) pressure problems with the tires are not picked up via a pressure sensor but rather they're inferred from a detected difference in rotational speed of one of the tires.
So as the manual points out, a slow degradation of tire pressure on ALL four tires will not be detected (to be expected with all tires over time). As per the manual.
      08-03-2005, 07:58 AM   #16
DHC
Drives: 2006 BMW E90 325i
My car was delivered with 38psi all around. Changed to 29/32 pursuant to the manual.
2006 E90 325i
TiAg; Black Leather; 6-Speed Manual; Sport Package; Heated Seats; Sat. Prep; modified CDV (Zeckhausen); Rogue SSK
      06-24-2006, 06:46 PM   #17
Richwm
Richwm's Avatar
Drives: 06 E90 330i 6MT, 01 E46 330i
Mine is the same all I have is this one sticker but my production date was 3/05
      06-24-2006, 08:08 PM   #18
ward
Drives: F
I've found the fronts need to be at least in the 35 psi range or the car will plow like crazy
      06-24-2006, 11:35 PM   #19
gos
Drives: E90 330xi
Agreed.
Sticker for me says 32/36, or 35/41 for high speed.
I'm currently running 35/38 and like the feel.
--gos
330xi SG/Terra/Burl -- ZPP, ZSP, ZCW, CA, Sirius, PDC
      06-25-2006, 05:10 PM   #20
flipmde786
Drives: 330xi
The manual says 32/36 up to 100mph and up to max load, 32/35 including speeds above 100 but not full load, and 35/41 or something for 100+ and full load for 330xi.
2006 330xi
[TiAg] [Black Leather] [Aluminum] [STEP] [ZPP] [ZSP] [ZCW] [CA] [35% tint] [Blacklines] [OEM Strut Bar] [OEM Spoiler]
      06-25-2006, 06:47 PM   #21
mds82
mds82's Avatar
364
Drives: 2006 325xi
Now what do you do if you have differet wheels and tires on the car. For instace i have a set of 19 Goodyear Eagle F1's on my 325xi - What pressure should i use??
      06-28-2006, 07:58 PM   #22
mds82
mds82's Avatar
364
Drives: 2006 325xi
bump above Q
Reply
e90post
