E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > 335 owners - misfire at idle?
Reply
      01-09-2007, 10:00 AM   #1
therealm3
Drives: F30 340 MSport
Hey guys, I wanted to see if others are experiencing a similar thing with the 335. I don’t think this is the “cold start idle” issue because it happens when the car is warmed up and driven for awhile. Basically I come to a stop at a light and the idle goes to 600 per normal operation and then randomly there is a miss. Very noticeable as the whole car kind of shakes once. No surging or oscillating rpm afterwards just 600 rpm again. It is quick so there is no drop in rpm either. I have this happen pretty regularly but no check engine light. I hooked up the OBD2 scan tool and there are no stored codes either. Any one else having the same thing?
I am hesitant to take it into the dealer after the disaster I had with my E46 idle issues. 7 different trips to the dealer, weeks of total time in the shop and in the end I got a pat on the butt and told by BMW field engineer that the idle problems I documented very well using OBD2 Data logging were “normal”.
      01-09-2007, 10:32 AM   #2
Aeroav8r
Drives: '11 535i
Yes, I wont say it's a misfire, but a definite one time 'shudder' about 10-15 sec. after coming to a stop in Drive or Sport.
335i Sedan, Step, 1700 miles
      01-09-2007, 11:20 AM   #3
therealm3
Exactly. If not a misfire (lack of spark, lack of fuel, etc.), then what would create this kind of situation?
      01-09-2007, 11:26 AM   #4
Aeroav8r
Drives: '11 535i
It feels as if something is being switched over - may be the exhaust flapper valve doing its thing.
      01-09-2007, 11:35 AM   #5
JEllis
JEllis's Avatar
532
Drives: E36 M3, E92 M3
If your A/C is on then that is most likely the culprit...
Jason
http://www.m3post.com/forums/signaturepics/sigpic14547_7.gif
Instagram: jellismotorwerks
      01-09-2007, 05:20 PM   #6
therealm3
Jason
nah. I don't use the AC unless its really hot outside.
I would not be surprised if it turns out to be slightly imperfect code due to first year production....
      01-10-2007, 09:10 AM   #7
sdiver68
Expert Road Racer
59
Drives: 07 335i e90, 09 335i e93
Mine does not do what you describe, outside of the cold start time window.
      01-10-2007, 11:43 AM   #8
SROC3
The limit of adhesion is my home.
SROC3's Avatar
Drives: Like a Boss.
used to happen to me too and i solved it by doing the following:
- at start I idle for approx 1 minute to let the oil circulate around the engine
- I drive off after but DO NOT go over 3800 rpm until the engine has reached near normal operation temp of 210 (200 is fine).
The above has worked for me very well. Hope this helps
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
      01-10-2007, 12:15 PM   #9
Aeroav8r
Drives: '11 535i
This is something different, it happens about 15-30 sec. after coming to a stop, indifferent to hot or cold oil, engine or air temp. Did it to me this morning at Jack in the Box - foot on the brake, in Drive, it's a slight dip in the idle and it makes the car rock side to side ever so slightly.
      01-10-2007, 12:24 PM   #10
grkm3
Drives: m3
try a different gas station
      01-11-2007, 01:22 PM   #11
therealm3
What would that do?
The car has enough miles and tanks of gas (all 91CA) with the problem there to eliminate low octane or bad gas. Oil temp is not an issue either: 230 and it will still do it.
      01-11-2007, 01:24 PM   #12
Ryan(e92)
Drives: SG M6 coupe
Mine has a quick blip during cold start up. Doesnt happen all the time. Ive got a 6 speed.
      01-11-2007, 03:35 PM   #13
Aeroav8r
Drives: '11 535i
It's the exhaust valve flap on mine, confirmed it yesterday.
      01-12-2007, 03:11 AM   #14
Jay@ATP
Drives: 02 S2k, 06 EVO IX
+1
Dont buy gas from no-name stations. Only use Chevron, Shell, 76, etc.
Not saying this will fix the problem, but every turbo owner should use higher quality gas.
      01-12-2007, 09:36 AM   #15
tigger184
Drives: 2007 335i sedan
How did you come to the conclusion it was the exhaust flap causing the problem?
      01-12-2007, 09:57 AM   #16
Aeroav8r
Drives: '11 535i
Drove the car for 30 min., parked the car, engine running in Park. I exited the car, walked to the back of vehicle, 30 sec. later heard a loud sound that is the valve closing ('clasp' sound), car shuddered for a millisecond at the time the valve closed.
Try it.
      01-12-2007, 10:58 AM   #17
tigger184
Would it be safe to assume replacing the exhaust system will solve the issue? Is there a design flaw in the BMW exhaust system?
      01-12-2007, 11:15 AM   #18
Aeroav8r
Drives: '11 535i
Golf tee.
      01-12-2007, 11:28 AM   #19
ICALL
ICALL's Avatar
Drives: 2011 550i Carbon Black M Sport
I believe I read someone else stopped the valve from closing in the "Under the Hood (NA-Engine) / Drivetrain / Exhaust Modifications
Everything engine and drivetrain related" forum area and they said the car's performance deteriorated. Explaination was the closing of the exhaust increased torque at lower levels.
Replacing the exhaust system shouldn't be a problem, but anyone looking to just stop the valve from closing may have a problem
Disclaimer: I know NOTHING about this stuff. Only trying to reiterate what I read on another post. People with more knowledge, feel free to chime in.
      01-12-2007, 11:31 AM   #20
Aeroav8r
Drives: '11 535i
That's why I'm leaving mine as is: it's not a problem to me, and the golf tee remedy will not be employed.
      01-12-2007, 12:57 PM   #21
RiXst3r
RiXst3r's Avatar
274
Drives: M235i
I think the change in backpreasure from the valve closing causes this, I noticed it more when i was using BP gas, I switched to shell, and it doesnt do it any more...
Reply
e90post
