01-26-2007, 12:34 AM | #1 |
Rep 1,075
lets talk m button
okay... i did my searching at m5 board...people say that the m5's m button does not make the car from v8-v10 raising the horse power to 507... (for now lets leave the suspension etc. out of it to keep this thread simple)
but top gear bbc's show stated that it does make it go from v8-v10... so does anybody know the concrete answer and i will believe them :rocks: now to deal with the e92 m3... you guys think it will be a part of it? or is it now m dynamics...
ZzZzZ'er |
01-26-2007, 01:21 AM | #2 |
Rep 10,407
hp reduce/increase
I would bet that you will not be able to reduce/increase the hp on the new M3. It will probably have a sport mode that remaps the throttle response like the E46 M3 though. The M3 is supposed to be the sportiest model in the BMW line up. The M5 is damn fast but more luxury oriented and with that much hp having it default with 400 hp is a bit safer and probably better for the typical M5 driver.
01-26-2007, 01:26 AM | #3 | |
Rep 1,075
it would be nice to have it less hp when driving normally.. save the power for wen its needed
ZzZzZ'er |
01-26-2007, 03:44 AM | #4 | |
Moderator / European Editor
1494
Rep 6,755
As I said some time ago, the preference of settings is programmable and can be switched with the M-button on the steering wheel. Best regards, south |
01-26-2007, 05:31 AM | #5 |
Rep 580
How will flexray really improve things?
I can see how flexray would improve manufacturing efficiency and even repairability, but I really do not see how flexray will actually give drivers more performance. Taking the M5 as an example, it has no flexray, but the EDC, DSC, throttle mapping, gearbox, etc all do work very well together already. There is no noticable delay in response because of the lack of a flexray bus or backbone.
How is flexray supposed to make the car better for drivers? Is flexray merely a technological acheivement for BMW to brag about, without a measurable performance benefit? |
01-26-2007, 12:05 PM | #6 | ||
Rep 1,096
For these automotive applications to become commonplace, a number of protocol requirements must exist. Enter FlexRay. FlexRay is a communication system developed by a consortium founded in 2000 by BMW, DaimlerChrysler, Motorola, and Philips Semiconductors. In 2001, Robert Bosch GmbH and General Motors joined the consortium. So did Ford Motor Company this past June. The consortium members realized that despite the numerous automotive communications protocols out on the market—most from Europe, most in or just out of development—none would fulfill future automotive control requirements. Even the computer communications protocols don't suffice. "None of them are automotive qualified," explains Andreas Both, business and technology manager overseeing FlexRay for the Semiconductor Products Sector of Motorola (Munich, Germany). That is, they are not qualified for automotive operating temperatures and electromagnetic compatibility requirements. (Remember hearing spark plugs fire through your aftermarket AM radio?) FlexRay is an open, common, scalable electronic architecture for automotive applications. It can operate in single- or dual-channel mode, providing redundancy where needed. It allows both synchronous and asynchronous data transmissions. With the former, other nodes on the network receive time-triggered messages in a predefined latency time. With the latter, messages get to their destinations quickly or slowly, depending on their priority. Currently, FlexRay can handle communications at 10 Mbps—the speed of your typical low-end home-computing local area network. Motorola's Both is quick to add that this standard doesn't mean that 10 Mbps is enough forevermore. Instead, it is fast enough for the foreseeable future, given the applications automakers have envisioned thus far. Last, FlexRay's clock synchronization mechanism aptly handles cheap clock oscillators, namely those made out of quartz. And that synchronization, as with all of FlexRay, is fault tolerant. For example, FlexRay automatically and digitally compensates for the differences in the variety of quartz clocks running on the network, as well as in their slight changes in clock frequencies. This clock synchronization is a distributed mechanism; there's no master timekeeper here. So if one node fails or for some reason is taken off the network, the other nodes will continue to operate in synchrony. (Insofar as the fault tolerance of motors and sensors, the normal rules of reliable systems design applies. For example, in a steer-by-wire system, the sensor system in the steering wheel will be a redundant array, with two or three sensors providing the same signal. A judging algorithm in the electronics will then determine the validity of the signals; that is, it will determine whether all three sensors are providing the same information, or at least two of the three.) IMHO: best, clearest and most detailed info here: http://www.autofieldguide.com/articles/090205.html Quote:
It will offer some measurable benefits; but for now ('08/'09) not in the ways most of us interpret a performance benefit. |
01-26-2007, 12:30 PM | #7 |
Rep 580
Thanks for the info Norsk. I understand that Flexray speeds transmission of data. I agree that for now the benefits are going to be limited. I read somewhere that Flexray will not be fully implemented by BMW until the new 7er debuts. That is well after the M3 is lauched.
01-31-2007, 08:55 PM | #8 | |
Rep 95
I can confirm that on the M5 it is always a V-10. The button can be set in the I-drive menu. You can choose your power (P400, P500, P500S), you can choose your suspension settings (EDC), DSC on, off or MDM and lastly you can choose which mode you want your SMG (D1-D5 or S1-S6). You can also set your HUD and active seat bolsters too. I have my M button set to P500S, EDC II, DSC off, S6.:rocks: But I doubt that they will have this system in the M3. |
01-31-2007, 09:46 PM | #10 | |
Rep 1,075
but i guess they were wrong because m5board stated that they always use 10 cylinders so no need to confuse urself. ``
ZzZzZ'er |
01-31-2007, 09:58 PM | #11 |
Rep 10,407
Cylinder fuel shut off
Some vehicles can obtain greater fuel economy by literally shutting down the fuel supply to some of the cylinders during lower power driving. Old Cadillacs from the 80's even had this technology with a 4/6/8 light to tell you how many cylinders are actually working. GM recently brought this feature back into production and some of their SUVs it. Honda, Toyota, DC and have similar systems. They work pretty well. I would definitely support this kind of feature even in a sports/GT car if you could totally disable it. Would be nice to have much better mpg, avoid gas guzzler tax and even have a greener car (ugh did I just say that...).
01-31-2007, 10:51 PM | #12 | |
Rep 1,507
Can I take over your waitlist spot? haha |
02-01-2007, 02:06 AM | #13 |
Rep 6,968
02-01-2007, 03:50 PM | #14 |
Rep 10,407
Funny
Last, bobbo: You guys are funny!
I do have some seemingly contradictory interests. Love big hp, fast cars (heck even 5000 hp nitro burning drag cars that can not turn). However, I also feel the environment is one of the most serious long term issues facing the planet. If I can have an E92 M3 with 30 mpg (unlikely/impossible) with DGI and cylinder fuel cut off I would like that! bobbo: Forum member here replicat has his drives as "40MPG", just like you. Cheers |
02-02-2007, 01:19 AM | #15 |
Rep 689
I hope not. The sport mode in the E46 ruins the throttle response if you are trying to drive the car fast.
02-02-2007, 01:42 AM | #16 |
Rep 10,407
Where have you been?
02-02-2007, 01:50 AM | #17 |
Rep 689
Work has been crazy, got a video game to write, and had a project to finish for the local BMW club.
I am back to being bored at work so everyone should brace themselves for my normal ranting again. |
02-02-2007, 02:26 PM | #18 | |
Rep 689
Bigs cars are the exact opposite of sporty cars. We actually call them pigs or boats. I drove an M6, its a pig. Sure its got a lot of hp but its not fun to drive. Performance and sportiness is all about weight, tire/weight, and hp/weight. |
02-03-2007, 01:27 PM | #21 |
Rep 6
Hey there Ebuyuk. Anyway back to the question. The M5 is V10 all the time. It is the settings that can be changed that lets the engine produce 400 vs 507 Hp. I think if it is set at 507 Hp the whole time, you would get like 8 Mi to a Gal.
02-03-2007, 05:38 PM | #22 |
Commander-In-Chief
2101
Rep 8,911
Drives: 2023 M2 Coupe, 2020 GLE 450
In terms of "sportiness", I think the term generally factors in size and weight, in addition to power. I would rank from most to least: MZ4, M3, M6, M5. The new M3 will undoubtedly outperform the current MZ4, but will still be a heavier 4-seater, so that order is debatable.
