E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > NCS-Expert - COAPI-1000 Error - After using Dension programmer to enable CD Changer
Reply
      04-17-2011, 12:01 PM   #1
HomeBrew
Drives: 2017 BMW M3
2017 BMW M3  [0.00]
2006 BMW 330i  [0.00]
Two days ago I coded several options (Digital Speed, Corner Delete, etc) on my 2006 E90 330i.
However, after installing a Dension Gateway 500 and using their programmer (OBD-II) to enable the cd changer controls, I now get a COAPI-1000 error when attempting to back up from choosing chassis and 'CAS'.
I put the dension in service mode and used the programmer to remove the changes, but I still get a COAPI-1000 error. So I'm stuck.
Now that I'm back inside I can't find a log file which has the details.
I'm using NCS Exper 3.1.0, COAPI 3.5.1B (so daten can't be an issue since it worked before?) and I've tried clearing the man file. I've also tried a entirely new profile w/o any luck.
Any ideas?
Thanks.
2017 BMW M3 - Tanzanite Blue with Full Silverstone Interior
      04-17-2011, 03:23 PM   #2
HomeBrew
Drives: 2017 BMW M3
2017 BMW M3  [0.00]
I've now tried updating the daten files and drivers found in this thread:
http://www.e90post.com/forums/showthread.php?t=480261
Still no luck.
UPDATE::
I'm thinking that the Dension programmer added/modified the VO, but didn't remove some prep code so now it's conflicting? Everything works as expected from the Dension, all previous coding I did is still in place. Just can't get passed the COAPI-1000 error to do anything new.
      04-18-2011, 05:49 PM   #3
HomeBrew
Drives: 2017 BMW M3
2017 BMW M3  [0.00]
I have a backup TRC (taken during the DIY) of the entire car.
Is there someway to reload this even though this error is occurring?
      04-19-2011, 11:22 AM   #4
The_DDub
Mmmm torque
The_DDub's Avatar
Drives: Like a Boss, hard and fast
2007 328i Sedan  [0.00]
You have an 06 and the base NCSEXPERT/EDIABAS is fully supported with all your modules.
Try this. Rename your existing EDIABAS folder and restore the original from the zip file.
Then try coding the car. I've run into a few situations where the daten updates broke access to modules on older cars, NFRM for example.
Monaco Blue E90 328i with Nav, Sport, Premium and Comfort Access packages, 6FL with iPod cable
SAE spec Depo with HIDs and HID fogs
Depo AE replacement Album
      04-19-2011, 01:55 PM   #5
HomeBrew
Drives: 2017 BMW M3
2017 BMW M3  [0.00]
Tried clearing the work folder, still no luck.
Tried replacing the EDIABAS folder with the original from zip file, no luck either.
Error Msgs from ERROR.LOG:
Error! Modul: CVT_PROC.C ProcNr: 02, LineNr: 10, ErrorNr: 106
Jugend_Forscht
Error! Module: COAPI.CPP, Proc: coapiGetFswFswFromAsw, LineNr: 02, ErrorNr: 1000
COAPI-1000: error
I have two guides (attached) for changing the VO, one says to use the delete key on the keyboard to remove an option. I tried this and didn't see any change?
I don't see how to delete an option from the VO, only add? Regardless, part of the process is 'F6' to go back, which is what fails. So how can I do this?
The retrofit kit code (IPOD) was added, but the prep code ($694) was not removed. Could this be the problem?
FA.TRC
E90_#0306&KAB4%0A34*VB33
$1CA
$226 (SPORTS SUSPENSION SETTINGS)
$249 (MULTIFUNCTION F STEERING WHEEL)
$255 (SPORTS LEATHER STEERING WHEEL)
$2AB (BMW LA WHEEL ELLIPSOID SPOKE 162)
$322 (COMFORT ACCESS)
$354 (GREEN WINDSCREEN, GREEN SHADE BAND)
$403 (GLASS ROOF, ELECTRICAL)
$441 (SMOKER PACKAGE)
$459 (SEAT ADJUSTMENT, ELECTRIC, WITH MEMORY)
$481 (SPORTS SEAT)
$494 (SEAT HEATING DRIVER/PASSENGER)
$497 (CENTRE ARMREST, REAR)
$4AC (FINE WOOD TRIM POPLAR WOODGRAIN)
$520 (FOG LIGHTS)
$521 (RAIN SENSOR)
$522 (XENON LIGHT)
$524 (ADAPTIVE HEADLIGHTS)
$534 (AUTOMATIC AIR CONDITIONING)
$544 (CRUISE CONTROL WITH BRAKE FUNCTION)
$563 (LIGHT PACKAGE)
$609 (NAVIGATION SYSTEM, PROFESSIONAL)
$620 (VOICE CONTROL)
$640 (PREPARATION F TEL.INSTALLATION UNIVERSAL)
$645 (BMW US RADIO)
$677 (HIFI SYSTEM PROFESSIONAL DSP)
$694 (PROVISIONS FOR BMW 6 CD CHANGER) <- should this have been removed?
$818 (BATTERY MASTER SWITCH)
$823 (HOT-CLIMATE VERSION) <- what?
$840 (OMISSION OF REMOTE CONTROL FOR RADIO)
$845 (ACOUSTIC FASTEN SEAT BELT REMINDER)
$850 (ADDITIONAL EXPORT TANK FILLING)
$853 (LANGUAGE VERSION, ENGLISH)
$876 (RADIO FREQUENCY 315 MHZ)
$925 (DISPATCH PROTECTION PACK)
$313 (fold-in mirrors, which I retrofitted)
$633 (PREP., TELEPHONE SIEMENS HANDSET, FRONT)
-B090
-EHHS (not sure what this is?)
+K302 (alarm system retrofit, retrofitted once i bought the car used, by the dealer)
+IPOD <- added by the Dension Gateway Enabler Tool - is this correct?
      04-20-2011, 01:46 PM   #6
HomeBrew
Drives: 2017 BMW M3
2017 BMW M3  [0.00]
Ok, so I've taken the Dension off the MOST ring and removed the IPOD retrofit code using the Dension programmer. So everything is as it was.
The error still appears in NCS.
Any ideas?
      04-28-2011, 03:17 AM   #7
jadleb
Drives: E92
having the exactly same problem with my E60 2005 ... did you resolved ???
      04-28-2011, 02:12 PM   #8
HomeBrew
Drives: 2017 BMW M3
2017 BMW M3  [0.00]
Nope, no resolution yet.
      04-28-2013, 05:05 AM   #9
Najt
Drives: e92 325D 2008
Hi, so yesterday I've tried to install Dension 500s BT. First I have tried to code the car. But I got error
COAPI-1141: FSW faulty
MP3_CHAMP
so I've code car without this option. We've connected the Dension and everything works fine but I am not sure why I got the error. Is it necessary to have this attribute in MASK?
Reply
e90post
