BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > Off-Topic Discussions Board > Video + PC Gaming / Computing > Laptop DVD Drive problem; need geek/nerd
Vorsteiner
      06-06-2011, 01:02 PM   #1
infinitekidM2
infinitekidM2's Avatar
Drives: don't own a car
So my dvd/cdr drive on my laptop was not working right; so i found out that that metal/gold ribbon thing that attaches the dvd drive to the computer had a long crack in it. What happened was that when the dvd drive slides out..that ribbon kind of hangs a bit underneat the bottom and apaprently when i slid the dvd drive back into the computer, it got caught a bit between the computer and dvd drive, got pinched and put a crack in it.
Question: What is that ribbbon called? And is it something i can replace easily or is it gonna be computer specific?
      06-06-2011, 01:16 PM   #2
infinitekidM2
the IT guy here says its a power data cable and i should be able to order from toshiba...thoughts?
      06-06-2011, 02:34 PM   #3
GordonShumway
Alien
GordonShumway's Avatar
Drives: 2007 330i
Order a power/data cable from Toshiba.
      06-06-2011, 02:44 PM   #4
infinitekidM2
lol "thanks"
      06-06-2011, 05:27 PM   #5
GordonShumway
Alien
Drives: 2007 330i
lol "thanks"
What you can do is find the hardware manual for your Toshiba laptop, and you should be able to identify the cable that you cracked. Are there broken traces in this cable ? If so, that is most likely your problem.
Good Luck.
      06-06-2011, 05:40 PM   #6
infinitekidM2
Thanks; can't find it
Here's my computer:
toshiba u405 2826
Looking for the data ribbon cable that connects dvd/cdr drive to computer
      06-06-2011, 07:06 PM   #7
GordonShumway
Alien
Drives: 2007 330i
Here's my computer:
toshiba u405 2826
Look up the manuals for the U400 series. Perhaps you'll find something that covers the U405.
      06-08-2011, 06:03 PM   #8
ABQ325i
ABQ325i's Avatar
Drives: 08 E60 535i + 06 E90 330i
2008 535i  [0.00]
2006 330i  [0.00]
Take the old cable out - there should be a Toshiba part number on it - will read something like A000023120
Search for that number because different companies call it by different names or abbreviations. I would call it an optical drive cable.
Good luck.
