BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > 3 and 4 Series Ordering / Pricing / Order Tracking Forum (and European Delivery) > Full 2012 BMW 3 Series (F30) Ordering Guide (All Options/Packages Configuration Info)
Evolution of Speed
      11-10-2011, 04:51 PM   #67
ManMachine
ManMachine's Avatar
Drives: 3
Originally Posted by Hound Passer View Post
It's rather ironic (and cruel) that BMW's vastly less expensive sister, Mini is going to be more customizable than an not-so entry level 3-series. One of the things BMW brags about when you take the 3 sedan factory tour is that that vast majority of cars are customer orders, i.e., not dealer stock, and that there are so many options, statistically only 5 other cars have the same color/trim/options each model year. Well that goes down the tubes now.
You are right it's going to annoy a lot of die hards, but even more so, it's going to p.o. people that actually shop different brands before buying. Hopefully BMW will rethink this "one size fits all" strategy. It's just dumb for a $40K+ car.
Actually compared to E90, with the specific lines F30 offers more cosmetic items to suit an individual's taste.
328i
      11-10-2011, 05:03 PM   #68
Zirenz2006
Zirenz2006's Avatar
Drives: X3 M40i Phytonic
Originally Posted by Weird Side Effect View Post
I really dont understand this. Kind of annoying and aggravating to be honest. Nothing against the Charger, but even the new Dodge Charger comes with rear LED tails (on all models). There is no waiting for some update years down the road.
I don't either. How many generations of the 3 series are they going to revert to standard bulbs, then add LED's at the LCI? It's friggin annoying!!
There are much less expensive cars that have led lights. BMW needs to find something else to change for the LCI
Current: G01 M40i Phytonic Blue|Black with Blue Stitching
Retired: '12 F30 328i Sport Line Sapphire Black|Black-red, '09 E90 335i M-Sport AW|Oyster, '07 E92 335i Graphite|Saddle, '05 E60 545i TiAg|Black, '01 E46 325i Jet Black|Black
      11-10-2011, 05:08 PM   #69
Zirenz2006
Zirenz2006's Avatar
Originally Posted by SD 335is View Post
These are not the only options! The Lines are only pre-configured trim levels that will be offered for less than if you created the combo yourself. This is how they'll be in stock at a dealer to make buying off the lot easier. There will still be a Standard trim level and you'll be able to order whatever exterior/interior trim combinations and packages/options that you want, just like now.
I understand that but I don't think you will be able to get Saddle without getting the luxury line. I know the UK configurator is different but if you build from a base model you have the choice of black or beige.
Maybe I'm wrong, maybe it will be different.
      11-10-2011, 05:11 PM   #70
Weird Side Effect
Side effects may include...
Weird Side Effect's Avatar
Drives: e90 M3, e46 M3
Totally agree. And think about, LED lights are something you should EXPECT to be standard on a car such as a BMW. Same goes for Xenon headlights.
      11-10-2011, 05:12 PM   #71
FrankiE90
FrankiE90's Avatar
Drives: Krooked Sk8board
Send a message via Skype™ to FrankiE90
msport in july, FTW!
-frick'n should add LSD to the msport option.
FrankiE90 AKA:.[The TANK] *CLICK THE SIG
E90s (been gone but not forgotten) KW clubsports 18" BBS GT4 // Build E30 (pending) + E46 M3 Wagon ESTORIL Blue
      11-10-2011, 05:59 PM   #72
mkoesel
Moderator
Drives: 2015 SO/CSAT F80 M3
Quite possible.
In contrast to the E90, however, you can only get these items is very specific combinations. It seems quite likely, in fact, that the total number of variations now, across all options and packages, has gotten smaller. And I think that, if so, this demonstrates the brilliance in the marketing behind these lines. They give the consumer more choices while actually reducing the individuality which would then reduce BMW's costs.
Hound Passer makes a very good point regarding Mini. If you've never done so, go to their site and spec out a car. You will see that the level of customization is almost stupefying. And there are no (well, a few, I suppose) restrictions as far as what can be had with what. It's wide open. Exterior trims, accents, interior colors, patterns, wheels, aerodynamics of all sorts, etc. can be had in nearly any combination you wish.
A gen-u-ine BMW eff-eight-zero with them tandem clutches in the transmission and that dad gum sun roof on the top-a da cawr.
      11-10-2011, 06:08 PM   #73
ManMachine
ManMachine's Avatar
Drives: 3
MINI is supposed to be a personal fun car.
BMW mainly targets a different crowd. Besides, BMW already more choices than MB or Audi.
328i
      11-10-2011, 06:09 PM   #74
mkoesel
Moderator
I understand that but I don't think you will be able to get Saddle without getting the modern line. I know the UK configurator is different but if you build from a base model you have the choice of black or beige.
No, I think you are most probably correct. That is to say that, in fact, ordering no line at all pigeon holes you into a few select choices, exactly as ordering one of the lines does. In other words, specifying no line is quite literally like specifying the "base line", and you are thus limited to two interior colors and three interior trims (I mispoke in an early post regarding trim choices - I said 2 rather than 3). You are also limited to black kidney grills, and either flat or glossy black exterior trim. Your wheels choices are also limited. This was all described by southlight in one of the past threads on the topic.
Perhaps it would be helpful to add the "base line" to the chart in the first post (well, assuming that the situation in the US end up being the same as the UK, as I suspect).
      11-10-2011, 06:12 PM   #75
mkoesel
Moderator
I'll strongly doubt that BMW would openly suggest that their cars are not fun and not personal. In fact, their marketing would have you believe the opposite. Don't know about you, but all of my BMW's have been fun, and personal too for that matter.
Oh? Have you actually enumerated all the different combinations of each? I'm not saying you are wrong, but I find it hard to believe you've proven this out. Just sayin.
      11-10-2011, 06:57 PM   #76
USC2000
USC2000's Avatar
Drives: F30 328i M Sport
Originally Posted by PaulBailey@ltbmw View Post
Are you kidding?
Yes. I'm really hoping that its going to be much higher.
The price of the new 5er was actually cheaper than the e60, so I figured there's a chance they f30 could be less then an e90.
2014 Alpine White 328i M Sport | M Performance Exhaust | M Performance Front Splitter | M Performance Carbon Fiber Spoiler | M Performance Grills | M Performance Pedals[/size]
______________________
      11-11-2011, 12:33 AM   #77
kimluk
Drives: E46/328i
What is variable sport steering (2VL) ? It is listed under optional equipment. I have EP steering in my F10 and I don't like it.
      11-11-2011, 04:23 AM   #78
MI6
The World is Not Enough
MI6's Avatar
Drives: Aston DBS-R
Questions, questions......
Many have wondered if the F30 comes with LED Corona's. Many have said no but if one looks at the pics from the F30 production line post it clearly looks like they do......
Really the craziest combo/option is potentially the Modern line with Black interior because according to the ordering guide it comes with an "oyster" dash and steering wheel yet the rest of the interior is all black..!
My whole life I've never seen a black interior with a beige dashtopper-much less a beige steering wheel.
Pretty wild.
It may just start a trend.
      11-11-2011, 12:19 PM   #79
ddmerino
Drives: Honda
I wish they offered the option for the Night vision with Pedestrian Detection as in the 5 series.
      11-11-2011, 11:17 PM   #80
pcbrew
pcbrew's Avatar
24
Drives: 2012 335i 6MT
I found the German pricing sheet and summarized the original post here with those prices added where I could find them.
Note that Euro pricing includes 19% VAT.
I computed US$ pricing by subtracting this and adding 37% for exchange rate - works out to 15% adder - and then rounded to the nearest $10.
In case of packages or groups of items, I included a simple rolled up total.
-- It will be interesting to see what the actual US pricing is along with all the option options available.
Standard Equipment in Comparison to the E90 (2710/$3120)
  • 8-Speed Automatic (ZSP) Standard with 6-Speed Manual (ZMT) as no charge option (205 - 2260/$2600)
  • 6.5" color display with iDrive Controller
  • Bluetooth Connectivity (6NH - 300/$350)
  • USB/iPod Interface (6NR - 150/$170)
  • One inch wheel upgrade (17" standard on 328, 18" standard on 335)
  • Dynamic Driving Control with ECO PRO Mode
  • Automatic Start / Stop on all engines and transmissions
  • Brake Energy Regeneration
  • Two cup holders in front of the gear lever and two bottle holders in the front doors
  • Floor Mats
** The 335i has the following features standard on the car: (4040/$4650)
  • Xenon Headlights (522 minus 502 - 710/$820) with High-Beam assist (5AC - 150/$170),
  • Wood Trim (-/$-),
  • Moonroof (403 - 1100/$1270),
  • Power Front Seats (459 - 1290/$1480) with Lumbar Support (488 - 310/$360) and
  • Anti-theft Alarm System (302 - 480/$550)
Optional Packages
Technology Package (ZTP) (3370/$3880)
  • Navigation System (609) (2390/$2750)
  • Heads Up Display (610) (980/$1130)
Parking Package (ZPK) (1530/$1760 + 3AG)
  • Rearview Camera (3AG) (only part of park assist pkg: 5DU = 3AG,507,5DP - 1490/$1710)
  • Surround View (5DL) (740/$850)
  • Park Distance Control (508) (790/$910)
Premium Sound Package (ZPS)
  • Sirius Satellite Radio (655) (US only)
  • Harmon Kardon Surround Sound System (688) (1200/$1380)
Driver Assistance (ZDA) (1080/$1240)
  • Active Blind Spot Detection (5AG) (560/$640)
  • Lane Departure Warning (5AD) (520/$600)
Cold Weather (ZCW) (1130/$1300)
  • Heated Front Seats (494) (370/$430)
  • Heated Rear Seats (496) (part or warm comfort package)
  • Heated Steering Wheel (248) (part or warm comfort package)
  • Split Folding Rear Seats (465) (490/$560)
  • Headlight Washers (502) (270/$310)
Premium Package (5860/$6740)
  • Dakaota Leather Upholstery (LC) ) (1820/$2090)
  • Power Front Seats including Driver Memory (459) (1290/$1480)
  • Lumbar Support (488) (310/$360)
  • Comfort Access (322) with new hands free trunk access (570/$660)
  • Moonroof (403) (1100/$1270)
  • Auto Dimming Rearview Mirrors (430) (590/$680)
  • Auto Dimming Interior Mirror (431) (180/$210)
  • Universal Garage Door Opener (-/$-)
Optional Equipment
  • Sport Automatic 8 Speed Transmission with Paddle Shifters and Quick Shift II Functionality (2TB) (170/$200 - delta from 8-speed auto)
  • Adaptive M Suspension (2VF) (1100/$1270)
  • Variable Sport Steering (2VL) (200/$230)
  • Parking Assistance (5DP) (only available in park assist pkg 5DU - /$)
  • Speed Limit Information (8TH) (320/$370)
  • 19" Light Alloy Wheels (2A4) -- 335i only! (1550/$1780 without a line, 900/$1040 with Modern,Lux,Sport)
      11-12-2011, 01:01 PM   #81
justinnum1
Drives: 2015 328i Msport 6mt
  • Floor Mats
  • Wood Trim (-/$-),
Optional Packages
Optional Equipment
Those $ conversions dont seem right...the premium pckg cant be more than 3000
F30 328i Alpine white/Coral red Msport 6MT, HK, Zenons, msport brakes, black grills and black side sills. mperformance exhaust
      11-12-2011, 02:22 PM   #82
pcbrew
pcbrew's Avatar
24
I agree, package prices will be lower. As I said, I just added up the prices for the individual options. This gives an idea of the cost of the package vs. cost of options if added individually.
      11-12-2011, 04:02 PM   #83
Dave4501
Drives: F10, E70, E64, and E60
I find the ordering guide to not be very helpful. Like others have posted, it looks like BMW is really limiting the options and colors most would want with certain cars.
I want the sport car and 18" sport rims on the 328i but it appears I will be required to take black mirrors, aluminum trim, and gray or black interior which I do not want. I would probably want tan with wood which may kick me out of the sport steering wheel and rims options.
I'm do not find the non-sport 18" rims to be very attractive.
I would also want the upgraded stereo, heated seats, sunroof (premium pkg), and possibly the paddle shifters. The price for those will most likely be within my price expectation so I'm okay there.
I hope BMW adds some additional options so some like me won't look to older cars or other makes. I may end up with a used F10 instead of a new F30
'12 535i,
'12 X5,
'15 Boxster
RETIRED: '08 650i, '07 530i, '06 330i, '00 323ciC
      11-12-2011, 05:21 PM   #84
liang
liang's Avatar
Drives: E92 335i
Too bad there is no option for ventilated seats...
Will to be easy to change the incandescent to LED by yourself?Has anyone done this for their e90?
      11-12-2011, 06:41 PM   #85
Weird Side Effect
Color choices?
Any word on what colors will be available?
      11-15-2011, 12:48 PM   #86
jtuds
Drives: 335rwd Dinan S2
BMW and Merc gouge people so badly on options packages, it is ridiculous.
      11-15-2011, 01:57 PM   #87
SoonerJohnInDallas
Drives: F30 335i - ED scheduled 3/1/12
Please explain why it is 'ridiculous' to allow people to choose the items they want to pay for and to not pay for the items they don't want???
      11-15-2011, 02:21 PM   #88
alex2364
alex2364's Avatar
Drives: 2017 M4 ZCP
2017 BMW M4  [0.00]
Because when you want everything, it's $10k+ more than other similar cars.
2012 3 series m sport, 2012 3 series order guide, 2012 3 series order info, 2012 3 series ordering guide, 2012 3 series ordering info, 2012 3-series, 2012 bmw 3-series, 2013 3 series m sport, 2013 3-series, 2013 bmw 3-series, 2014 3 series, 3 series f30, 3 series forum, 3 series forums, bmw 3 series forum, bmw 3 series forums, bmw f30, bmw f30 forum, bmw f30 forums, f30 3-series, f30 bmw, f30 equipment, f30 forum, f30 forums, f30 m sport, f30 optioning, f30 options, f30 order, f30 ordering, f30 ordering guide, f30 packages, m sport f30, ordering f30
