Login
12-10-2011, 08:52 AM | #201 |
Rep 1,247
Drives: fat cars are still boats
Location: compensating a fat car with horsepower is like giving an alcoholic cocaine to sober him up.
12-10-2011, 09:02 AM | #202 |
Rep 1,247
12-11-2011, 02:08 AM | #204 | |
![]() 24
Rep 1,135
Huge mistake. That badge just kills the whole image of the car. Subie has the upper hand in this. |
12-11-2011, 05:02 PM | #207 |
RWD only.
![]() 435
Rep 12,435
Very much like the 911 vids; it's all about the driver. He's got skills. The only way to wring this thing out into a prolonged drift would be a massive flick or a wet road.
Past:'08 E92 335i|ZPP|ZSP|6AT|four (4) HPFPs
![]() Present:'15 Mustang GT|401A|PP|6MT|Recaros Sig pic unrelated. I like to go sideways and stuff. |
12-11-2011, 08:42 PM | #208 | |
Rep 1,247
But you have to ask yourself one simple question... why do the the most popular and successful 911s (available to the general public) were, are and always will be the all-wheel drive variants since the introduction of the 959 through the 964, 993 and all the models that followed?! Let me help you to find the answer... BECAUSE THEY ARE SAFER TO DRIVE FAST! Why?! Here's why... Unbalanced car - engine behind the rear axle - 911: ![]() Balanced car - 53:47 front-to-rear weight distribution - Toyobaru: ![]() You you can't deny physics... but you can wave your hand to the crowd while you are driving a Toyobaru sideways - that's how balanced it is! ![]() Last edited by GoingTooFast; 12-12-2011 at 06:29 AM. |
12-12-2011, 12:50 AM | #209 |
RWD only.
![]() 435
Rep 12,435
I really just made that comment to stoke some unnecessary conflict; I understand how weight distribution (and there's so much more to it than that) works man. I just like giving you a hard time.
12-12-2011, 06:32 AM | #210 |
Rep 1,247
12-12-2011, 07:38 AM | #211 | |
Rep 1,247
But if you are a badge snob you'll be better of buying a 911. ![]() |
12-12-2011, 11:00 AM | #212 | |
![]() ![]() ![]() 1224
Rep 6,506
Drives: My wife's car
Ideally this current run of the BRZ/FRS/86 would have had a 45/55 or similar weight balance, allowing the future blown versions to not tip towards being nose heavy, which they likely will. It would also create a little more appeal to the "base" car in that it would retain slightly better handling and braking results than the blown cars. |
12-12-2011, 01:43 PM | #213 |
There is No Substitute
![]() -82
Rep 1,186
'13 Audi A6
'07 Porsche GT3 RS '08 BMW E90 335i ![]() |
12-12-2011, 01:52 PM | #214 |
![]() ![]() ![]() ![]() 78
Rep 855
If only it would be turbo and awd. So sexy
2014 335i M Sport
![]() 2010 328i M Sport 2007 Z4MC #1019/1815 (Sold) 1997 M3 (Sold) 1991 325i |
12-12-2011, 02:26 PM | #215 | |
Rep 1,247
The BIG advantage of having the engine in the middle of the car (between both front and rear axles) is initial turn-in. It's like the car would be perfectly able to rotate around an imaginary vertical axis passing through its center of gravity between the driver and passenger seats. However, due to the absence of the weight of the engine on the front wheels, once you start applying the throttle and the weight shifts to the rear, provided you don't have enough power to break the rear wheels traction, you will start to understeer. Thus, you loose some of the capacity to use the throttle to corner despite the fact that you are actually carrying more speed into the corner in virtue of the better turn-in. So, another concept has to be accounted for - car's dynamic weight distribution. With Toyobaru's less than ideal weight distribution at 53/47 front to rear, the weight distribution shifts rearward under acceleration and becomes dead even at near-perfect 50/50 balance despite of the initial understeer due to a worse turn-in ability. This means you can get back on the throttle earlier allowing the car to accelerate with neutral weight distribution. The car's balance prowess lays on the right amount of rotation you get from the transition between braking and getting back on the gas. And, if things are done right you can essentially use the throttle to corner and the steering wheel to initially turn-in and opposite lock. ![]() That's the reason why drifting cars are front-engined rwd. That's the difference between effectiveness and fun! ![]() Last edited by GoingTooFast; 12-12-2011 at 02:38 PM. |
12-12-2011, 02:46 PM | #216 |
Rep 1,247
12-12-2011, 03:11 PM | #217 | |
Rep 6,506
12-12-2011, 03:15 PM | #218 |
Rep 6,506
I drive a Z3 M Coupe, the very definition of hoonage. I've also tracked a few Exiges/Elises that didn't have an over abundance of power or a capability to rotate under off-peak power very well, but they really didn't exhibit power-on understeer and were certainly capable of getting into the power earlier than any front engine car I've driven.
The one cautionary thing I have to say about the Lotii is that they had awful throttle response from a Toyota n/a engine, so hopefully the Toyota part of this engine is offset by the Subaru parts. I've tracked STi's too that had better throttle response than many modern drive by wire n/a engines. |
12-12-2011, 07:05 PM | #219 |
Rep 6,506
12-12-2011, 11:19 PM | #220 | ||
Rep 1,247
If you drive a Z3 M Coupe you should know what I'm talking about... |
