Bimmerpost for iPhone and Android have just been updated with a host of bug fixes. If you've ever had trouble logging into it in the past, give it a try now!
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Full U.S. BMW 3 Series (F30) Technical Data Specs for the 2012 328i and 335i
Extreme Power House
      02-02-2012, 04:38 AM   #1
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Post Full U.S. BMW 3 Series (F30) Technical Data Specs for the 2012 328i and 335i
BIMMERPOST NEWS
50
COMMENTS
Here are the complete technical data and specs for the U.S. 2012 model 328i and 335i sedans (F30), official from BMW NA.
Click image for data sheet.
      02-02-2012, 05:07 AM   #2
Nero7
Nero7's Avatar
53
Drives: F30 M-Sport 328i
Isn't the sport automatic gearbox faster than manual? I'm wondering about the time 0-60 mph in 5.9s for automatic gearbox, but is that time for sport+ mode?
/// M-Sport 328i // Packages -- Adaptive Drive-- Drive Comfort -- Function -- Visibility // 19" 403M // M-Sport Brakes // Harman Kardon // Head Up Display ///
      02-02-2012, 10:17 AM   #3
noro
noro's Avatar
Armenia
67
Drives: '91 M3, '04 E46 ZHP, '72 2002
There was a lot of weight reduction talk, but seems like not much follow-through. 3400lbs for the 328 gives no reason to go with that engine size for performance oriented folks. With less than 170lb upcharge to 335. Makes the 3280lb E46 330i look feather light.
zhpregistry.net - ZHP stats and free classifieds.
      02-02-2012, 10:28 AM   #4
Robin_NL
S0THPAW
Robin_NL's Avatar
Netherlands
1942
Drives: LBB M2+MPE
Exactly. Only 50kgs difference.(328iA vs 335i 6MT)
The EU spec 335i goes from 0-100kmh in 5.5 s(both the GMT and the 8AT) fwiw....
The US 328i 8AT in 6.3 s. That's almost ONE second difference.
Greetings from Europe
Cheers
Robin
      02-02-2012, 10:40 AM   #5
justinnum1
Drives: 2015 328i Msport 6mt
Cheers
Robin
Your not saying the F30 328 auto will do 0-60 in 6.3, are you? because that is wrong.
F30 328i Alpine white/Coral red Msport 6MT, HK, Zenons, msport brakes, black grills and black side sills. mperformance exhaust
      02-02-2012, 10:53 AM   #6
Robin_NL
S0THPAW
Robin_NL's Avatar
Netherlands
1942
Drives: LBB M2+MPE
No sir.
I'm saying the 328i A US spec(on that sheet above) does 0-100kmh (62mph) in 6.3 seconds. Look at that sheet. The EU spec(www.bmw.de) 335i 6MT & 8AT do 0-100kmh(62mph) in 5.5 seconds. Which is a difference of 0.8seconds. Almost ONE second. The US spec 335i 6MT does 0-100kmh(62mph) in 5.7(0.2s slower than the EU spec 335i)
Don't confuse 0-60mph with 0-100kmh please.
Cheers
Robin(almost owner of a EU 335i 6MT, doh I'm from EU)
      02-02-2012, 11:30 AM   #7
GB///M
Drives: F30 340xi
No sir.
Cheers
You're right but BMW always plays conservative with those numbers so for sure both models will be faster than what was posted in the spec sheet. And let's not compare numbers cause in the US we can buy these cars MUCH CHEAPER than in the EU.
      02-02-2012, 11:31 AM   #8
Robin_NL
S0THPAW
Robin_NL's Avatar
Netherlands
1942
Drives: LBB M2+MPE
I know that. Would I want to move to the USA for that? No. Sorry.
EDIT: If I was from the US, I'd already be driving a F10 M5 or 991S, but on the other hand, where I live we still can drive fast, as in FAST.(I live about 45mins driving from the German border)
      02-02-2012, 11:55 AM   #9
GB///M
Drives: F30 340xi
I can drive fast here too there are several drag strips/road course tracks less than an hour from Chicago. I don't have to go to another COUNTRY to do it.
And btw my wife is from Germany so we go visit her family there at least every 3 months...I also get to enjoy parts of Germany's no speed limit autobahns
      02-02-2012, 11:55 AM   #10
SamS
SamS's Avatar
Drives: 2018 X3 M40i
Is the N55B30M0 the same as what was in the '11 E90 and '12 E92/93 335i?
      02-02-2012, 12:03 PM   #11
ShewbieDo
Drives: 08 328i
Is it interesting to anyone that the gear ratios for the 8AT are the same for the 328 & 335? Admittedly, I'm no transmission guru, but I figured there would be some tweaks for differences in power delivery.
      02-02-2012, 12:04 PM   #12
jlstyle
jlstyle's Avatar
122
Drives: 2015 X5 Msports
So tires are square set up now?
      02-02-2012, 12:09 PM   #13
runnerx
runnerx's Avatar
Drives: 06 M roadster; 06 330i 6spd
225 square setup for fuel efficiency. man, that wheelbase is not attracting at all.
2009 BMW X5 4.8i
2006 BMW ///M Roadster 6spd manual
2006 BMW 330i 6spd manual - gone
https://lh5.googleusercontent.com/--bIgrh8ES_s/TxSUCvOmDUI/AAAAAAAAPh0/OOjwrRZtta0/s912/z4mcomparo.jpg
      02-02-2012, 12:11 PM   #14
speedfan
speedfan's Avatar
Vietnam
86
Couldnt help it but noticing the size of the 3series now is actually the e39 5series.
E39 5series / F30 3series
Wheelbase 2,830 mm (111.4 in) / 2,810 mm (110.6 in)
Length 4,775 mm (188.0 in) / 4,636 mm (182.5 in)
Width 1,801 mm (70.9 in) / 1,811 mm (71.3 in)
Height 1,435 mm (56.5 in) / 1,429 mm (56.3 in)
1,415 mm (55.7 in) (2000-03 540i saloon)
1,440 mm (56.7 in) (1997-99 estate)
1,417 mm (55.8 in) (1997-99 540i saloon)
1,486 mm (58.5 in) (2000-03 estate)
(source http://en.wikipedia.org/wiki/BMW_5_Series_(E39))
My e90
Frozen Grey. Dry CF Roof. Vorsteiner Double Sided CF Boot Lid. OSS. BMW Performance Aero Kit. BMW Performance CF Diffuser Cover. BMW Performance CF Trim. Robson Design Steering Wheel. Advan RS. Michelin PSS. H&R Touring Cup Kit. BMW Performance Brakes. Eisenmann Race Rear Muffler. ESS Directflash
      02-02-2012, 12:21 PM   #15
justinnum1
Yea, which is why its so impressive that reviews i have read are saying the F30 feels lighter and more nimble than the e90. Cant wait to finally drive this thing
      02-02-2012, 12:26 PM   #16
CaptChaos
CaptChaos's Avatar
Drives: 2017 M2 - Mineral Grey
The final drive ratio is different. Perhaps the torque graphs are so similar they decided to keep the gear ratios the same and just use a different final drive.
      02-02-2012, 12:36 PM   #17
AW128i
AW128i's Avatar
Drives: E82 N51
Send a message via AIM to AW128i
Cheers
Robin
Huh?? The spec sheet above quotes the 328iA at 0-60 in 5.9 seconds (manual at 5.7 seconds). I just looked at the BMW UK site and they quote the 335i at 0-62 in 5.5 seconds (which seems to line up nicely with the above quote of 0-60 in 5.4). Point being, I'm only seeing a maximum of a .4 second difference between the two cars. Doesn't really matter, because historically the German car manufacturers have understated power and acceleration figures. I wouldn't be surprised if the 328i does the 0-60 run in what BMW is quoting for the 335i, and the 335i probably does it in 5 seconds.
The final drive is the same for both the 328iA and the 335iA. I think that's why ShewieDo found it odd. I, too, find this odd as I would expect at least the final drives to be different. The manual transmissions are completely different, gear-wise. Clearly BMW is going for fuel economy with the 328i because the manual has two overdrive gears.
      02-02-2012, 12:53 PM   #18
BH_Fanaticos77
BH_Fanaticos77's Avatar
Drives: 2008 BMW M3
Final drive is the same for AT for both 328 and 335
2008 M3 coupe - DCT & EDC, AA
      02-02-2012, 01:03 PM   #19
wagz0627
Drives: 2015 435xi Gran Coupe
Correct me if I'm wrong but I believe the 19" Style 401 wheels are 225 front/255 rear. At least that's what my dealer told me when I ordered them.
      02-02-2012, 01:07 PM   #20
R12ax7
R12ax7's Avatar
44
Drives: 2011 328i M-sport 6MT
2011 328i  [0.00]
I have to hope this doesnt reflect the "Sport Line" or M Sport equipment.
I notice the track is 5-6mm wider for the 335 - the extra weight? I cant imagine they would do that just for appearance.
      02-02-2012, 01:17 PM   #21
DrivenByE30
DrivenByE30's Avatar
France
316
Drives: '12 F30 Lux 335i 6MT
Yes and They should also be Run Flat Tires as with the 18".
      02-02-2012, 01:20 PM   #22
Mahzari
Iran
22
Drives: poorly
Why do you want a staggered setup...?
2015 328i Sport Line
3 series f30, 3 series f30 0-60, 3 series f30 forum, 3 series forum, 328i f30 0-60, 328i f30 weight, 335i f30 0-60, 335i f30 weight, bmw 3 series forum, bmw 3-series f30, bmw f30, bmw f30 3-series, f30 0-60, f30 0-60mph, f30 3 series 0-60, f30 3 series weight, f30 3-series, f30 3-series forum, f30 328i 0-60, f30 328i weight, f30 335i 0-60, f30 335i weight, f30 acceleration, f30 forum, f30 forums, f30 performance, f30 performance specs, f30 tech data, f30 tech specs, f30 technical data, f30 technical specs, f30 weight, technical data f30, technical specs f30
