BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Replace DRL bulb?
      02-07-2012, 11:24 PM   #1
justinnum1
Drives: 2015 328i Msport 6mt
Replace DRL bulb?
So, how easy would it be to change those 2 bulbs to something more bule/white looking? ANy ideas on what would be involved(how to get to the bulbs?)
So, here is a picture of the car non xenons DRL, its like the bottom half of the inner circles...
F30 328i Alpine white/Coral red Msport 6MT, HK, Zenons, msport brakes, black grills and black side sills. mperformance exhaust
      02-08-2012, 02:24 AM   #2
JoeyO
Drives: silver car
My guess is those are just halogen bulbs, most likely found any any auto parts store like Auto Zone. Sylvania makes regular oem halogen bulbs, but they also make upgrade bulbs which are brighter/whiter for a higher price (ie; Cool Blue and Silverstar). The downside to those brighter/whiter bulbs is they burn at a higher temp and therefore their lifespans aren't as long as the oem bulbs. I used to install those brighter/whiter bulbs but I got tired of changing them when they burned out. Unfortunately they only lasted 1/2 the time of the oem bulbs. Sometimes they lasted only several months.
So yea, you can probably put whiter and bluer bulbs in there. Just be prepared to change them considerably a lot more often then the OEM bulbs.
      02-08-2012, 04:00 AM   #3
E90Fleet
South Africa
1065
Its a 6W Halogen bulb in the non-Xenons DRL
They dont give the bulb type for this one but should probably be easy to change
EDIT: Looking at the wrong lamp, Its a 24W PW24W bulb in the DRL
BMW if you are reading, I need a job, Please.
      02-08-2012, 09:24 AM   #4
justinnum1
Hmm, sounds good, will just need to find out how to access the bulbs(hopfully its easy and doesnt involve removing the front bumper or anything crazy lol) Maybe i can open the hood and it will be easily accessible
      02-08-2012, 09:48 AM   #5
Xcution
Xcution's Avatar
Drives: 2011 135i mSport
I would just try and fork over the extra 900 bucks for the Xenons. After market will cost more, probably and xenons not only look better but are safer.
      02-08-2012, 10:49 AM   #6
justinnum1
Thats not an option, you have to get ZPP...im not paying 3grand just to have zenons lol
      02-08-2012, 11:04 AM   #7
pcbrew
pcbrew's Avatar
24
Drives: 2012 335i 6MT
RTFM (literally) - starting on p. 280.
DRL is a 24W bulb
      02-08-2012, 11:11 AM   #8
justinnum1
DRL is a 24W bulb
Good find, just checked it out, looks doable
      02-08-2012, 11:18 AM   #9
justinnum1
Looks like i can get 24watt led lights and put replace the regular DRL with some leds, should be cool looking
      02-08-2012, 04:31 PM   #10
simonh100
Drives: BMW 318d
Looking at other pictures of new F30 without the Xenon headlights, they still have the angle eyes or halo lights as per E92 model.
As far as I can tell with Xenon headlights the angel eyes are LED and presumably halogen for cars without Xenon
      02-08-2012, 04:51 PM   #11
unintelligible
Computer Janitor
unintelligible's Avatar
Drives: '12 F30 328i
Dude, the car in your picture has Xenons. The one in the pictures from justinnum1 has halogens. Halogen cars don't have corona rings.
      02-08-2012, 04:54 PM   #12
justinnum1
That car is xenons^....non xenon cars have no type of (rings) just a halogen bulb drl, bottom half of the inner rings
And i think it will look cool replacing the halogen DRL with a led
      02-08-2012, 05:06 PM   #13
simonh100
Drives: BMW 318d
Cheers all,
Must have been more than 1 white car used in the collection of pictures.
      04-21-2012, 01:18 PM   #14
bcl0328
Drives: 2012 328i
you ever replace it?
      04-21-2012, 01:45 PM   #15
sr5959
Drives: 428GC M-Sport
That sounds like a great easy upgrade, post some pics when you do it!
      04-21-2012, 10:43 PM   #16
SCBimmerKid
SCBimmerKid's Avatar
Drives: Mineral Grey F30
Have you considered an LED bulb replacement? That would last longer and you could get different hues of white and blue. I usually use VLED's. They have good stuff.
*NO LONGER ON ORDER* '12 328i Mineral Grey Metallic w/black leather/aluminum&black gloss trim/ZSL/ZPP/Xenons
      04-21-2012, 10:48 PM   #17
bcl0328
Drives: 2012 328i
do they even have 24w LEDs?
      04-21-2012, 10:56 PM   #18
SCBimmerKid
I'm not sure. I'll check out the website and see what I can come up with.
      04-22-2012, 10:50 AM   #19
Elk
Drives: 2012 335i
The LED wattage will be lower than incandescent bulbs. What you need are LEDs with the proper base and roughly the equivalent lumen output.
      04-22-2012, 11:57 AM   #20
SCBimmerKid
Yea, I couldn't find anything.
      04-22-2012, 12:06 PM   #21
Elk
Drives: 2012 335i
Just pull the bulb and look at the stamping. I think you need PY24W such as these:
http://www.highperformancebulbs.com/bmwpy5ulhipo.html
      04-22-2012, 12:10 PM   #22
SCBimmerKid
Yep, those are the ones. Just make sure it's from a reputable distributor. I've purchased some that didn't haave good enough heat sinking and they died in just a month or two. (Waste of 60 bucks ) Happy Bulb hunting
