BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Close Look at F30 328i Suspension by Insideline!
      02-15-2012, 01:14 PM   #23
remmib
remmib's Avatar
Norway
823
Drives: 2013 F10 520d M-Sport
Great info on the F30 suspension, thanks for sharing.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      02-15-2012, 01:49 PM   #24
Park828
Drives: f10 535i msprt e60 550i msprt
the front suspension looks almost identical to the e90... even the aluminum components
rear looks pretty similar too except the shock is directly mounted to the large link on bottom.. where as on the e90 there was a huge soft bushing
2011 F10 535i
07 e90 AW Terra Manual, Brushed Aluminium, ZCW, ZPP, ZSP, comfort access, power rear shades, manual side windows shades, PDC, NAV, HD radio, Sirius, 6FL Ipod, 6UH RTTI
97 e36 techno v M3 coupe manual
      02-15-2012, 03:42 PM   #25
KSERGEI-BY
KSERGEI-BY's Avatar
Belarus
Drives: x1 f48
I was hoping they will get rid of this separate parking brake stuff, but they have wired habbit to keep it. I like everything in this car, really, with some normal single padded brakes (like mercs and others have), this will be just perfect.
Now you probably ask whats wrong with this one... well just try to have a car a bit more then its worranty millage and you'll know how it brakes someware on the motorway. This never happends if you don't have this "enhancement".
      02-15-2012, 04:16 PM   #26
E90Fleet
South Africa
766
Originally Posted by E90 Skye View Post
is that optional?
No, front 4 piston calipers are standard on the 335i
BMW if you are reading, I need a job, Please.
      02-16-2012, 02:17 AM   #27
sourphish
Drives: '07 335i E92
I wonder if a BBK for the e9x would fit on the F30
2007 E92 335i, 6MT, Sparking Graphite, ZPP, ZSP, Nav, Logic7
      02-16-2012, 03:17 AM   #28
accel
Drives: e90 328i MT ZSP
It's not really clear to me whAt's the real everyday anvantage for me as a driver in this double pivot front suspension setup in both e90 and f30...
I would preffer double wishbond.
      02-17-2012, 12:27 AM   #29
rideontwo
Drives: 2008 E92
Amen to that homie! I would prefer a double wishbone suspension in the front as well, just as long as BMW's execution isn't as bad as the new 5er (F10 chassis).
On a separate note. I am getting the impression that BMW is going soft in the suspension department in general. 1st-This new car is longer, 2nd-It still has the crappy run flats, 3rd-Essentially the same suspension as the E90, 4th-Steel stamped components in the rear. Seems like we are really getting less but paying more and BMW is laughing all way to the bank.
      02-17-2012, 12:55 AM   #30
CirrusSR22
BMW has always carried over suspension. They used the same basic front suspension design on the E30, E36 and E46 - that spans 1982 through 2006. The E36 and E46 share the same rear suspension design, they even share some of the exact same parts. The E90 took the front and rear suspension from the E8X 1 Series - they share every single part I believe.
Same with the current cars. The F30 uses the exact same set of suspension arms (front & rear) as the F20 1 series.
      02-17-2012, 11:19 PM   #31
rideontwo
Drives: 2008 E92
Same basic front strut setup yes. However components have changed from E46 to E9x.
      01-10-2013, 10:30 AM   #32
nano10
nano10's Avatar
99
Drives: 2013 335i aka Kal-El
Originally Posted by speedfan View Post
*bookmarked*
GREAT INFO. Thanks for taking time to do this.
+1 thanks for doing this, great way to learn and understand
2013 335i Estoril Blue M Sport/ Coral Red Interior/ M Performance Red Brakes/ Enhanced Bluetooth/ Premium Audio/Performance Grills/BBS CX-R
      01-10-2013, 12:40 PM   #33
sean10mm
sean10mm's Avatar
Drives: '13 335i xDrive 6MT ZDH
That must be why the F30 328i sport line on all season RFTs puts up the same cornering numbers as the E46 330i ZHP on staggered summers per Car & Driver's test numbers.
      01-10-2013, 01:29 PM   #34
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
and that's why BMW charged me so much for a suspension install...that ARB is TUCKED THE HELL IN!
SOLD: 2012 335i Mineral Gray
3 series f30, 3 series f30 forum, 3 series f30 suspension, 3 series forum, 328i f30 suspension, 328i suspension, bmw 3 series forum, bmw 3-series f30, bmw f30, bmw f30 3-series, f30 3 series suspension, f30 3-series, f30 3-series forum, f30 328i suspension, f30 forum, f30 forums, f30 suspension
