BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > First F30 335i (N55) Dyno Results Are In. Also Underrated From Factory.
      02-22-2012, 03:08 PM   #1
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Thumbs up First F30 335i (N55) Dyno Results Are In. Also Underrated From Factory.
BIMMERPOST NEWS
108
COMMENTS
We bring you the first dyno results from a 2012 335i (F30) sedan, performed by Challenge Mfg. USA (GTM_Challenge) on their recently delivered 335i. The F30 335i is powered by the N55 6-cylinder TwinPower twinscroll turbo engine and its factory quoted power figures are 300hp / 300lb-ft.
The 335i N55 dyno run resulted in 270whp and 273lb-ft torque. Note that the dyno was performed on a AWD Dynojet with linked AWD rollers. On a normal rear-roller-only system the numbers would be slightly higher (probably 5-10hp) given the less roller weight that would need to be moved.
What does this translate to in terms of crank HP (for comparison to the factory quoted figures)? Taking 275whp and 278lb-ft as the starting point and assuming a 15% drivetrain loss, it would mean that this 335i outputted approximately 324hp / 327lb-ft torque at the crank (or +24hp / +27lb-ft over the factory quoted numbers).
Like the F30 328i with its N20 engine (dyno results), it's safe to say that the F30 335i and its N55 engine are also underrated from the factory (no surprise).
Check out the dyno run video and graph below.
      02-22-2012, 04:56 PM   #2
UdubBadger
Drives: '04 330i ZHP
2004 BMW 330i ZHP  [4.75]
2011 135i  [3.73]
2008 328xi  [4.38]
isn't rwd drivetrain loss more like 10-12% and awd closer to 20%?
      02-22-2012, 04:56 PM   #3
M3_WC
Drives: M3
Not exactly ground breaking news. The N55 is just a carry over.
Looks in line with past N55 dyno numbers.
      02-22-2012, 04:59 PM   #4
coolchu001
coolchu001's Avatar
Drives: 09 BMW 335d
Send a message via AIM to coolchu001
the gap between 328i and 335i is much smaller now...
      02-22-2012, 05:04 PM   #5
bmrm396
Drives: 2016 F80 M3
good news!
Formerly addicted to e46fanatics
Formerly addicted to e90post
      02-22-2012, 05:06 PM   #6
E92LNGCGY
Drives: F82/F25
Nothing new here. I think we can safely assume that all maufacturers under rate power figures. The N55 is a great engine none the less.
      02-22-2012, 05:13 PM   #7
DaveJ
DaveJ's Avatar
South Africa
Drives: 2008 335iM
I agree..no great guns, it is a carry over.
      02-22-2012, 05:16 PM   #8
mookie45
mookie45's Avatar
447
Drives: 2017 AW 340i M-Sport
I bet they will bump the hp up even more when the f32 comes out next year.
      02-22-2012, 05:17 PM   #9
yomny
yomny's Avatar
Drives: '13 335is 6spd
I could be mistaken but if that big fan behind the car would be in front of it, the car could definitely see a few extra horses.
      02-22-2012, 05:17 PM   #10
catalyst
Drives: X1
I can see it now -- F32 - 340i
....or something
      02-22-2012, 05:25 PM   #11
GTM_Challenge
GTM_Challenge's Avatar
Drives: E92 M3,X5M,F30 335
Send a message via AIM to GTM_Challenge
There were actually 2 smaller higher velocity ones aimed right up front as well keeping her cool
      02-22-2012, 05:30 PM   #12
cstavaru
cstavaru's Avatar
180
Drives: 2009 335i M Sport Sedan 6MT
It's well known that on any Dynojet the N55/335i outputs about 270whp.
      02-22-2012, 05:32 PM   #13
Q4P
Q4P's Avatar
Drives: Too Much
I had a friend dyno his on a dynojet with a 6AT tranny in early 2011... the result was 270 WHP dead, so it looks like nothing has really changed.
2jZ + RB26 + 4G63 + LS9 + N54 =
      02-22-2012, 05:34 PM   #14
335iJWC
Drives: JB 335i-M3
2008 BMW 335i  [4.50]
only about 40-50 more horses than a 328.
with the weight and balance differences it make the 335i less tempting
      02-22-2012, 05:43 PM   #15
Diver
Diver's Avatar
Drives: Black '12 135i - Sold
No surprise as 2011 N55 dyno results are similar.
      02-22-2012, 05:47 PM   #16
atlharry
South Korea
-10
Drives: 2011 335i Coupe
Not to say that this isn't true, but I would just love to see the run done on the same dyno as the one that the N20 ran on...
      02-22-2012, 05:49 PM   #17
Maz335i
BMW 4 Life...
Maz335i's Avatar
Drives: 2015 SO M3 (on order)
Totally agree!!!
MODS: *** / M Sport + Performance / Meisterschaft / Challenge / MORR / more to come! ***
      02-22-2012, 05:53 PM   #18
GTM_Challenge
We should be able to put a 328 on the same dyno here hopefully in the coming weeks once some more 328s are around here for us to pick at. I'd like to see them compared to a 335 on the same dyno myself.
      02-22-2012, 05:57 PM   #19
bmrm396
Drives: 2016 F80 M3
tru, however with the f30 redesigned intake and exhaust its just an interesting point of note ... also more just to rest the minds after reading so many negative reviews on the 335 feeling "weaker" than before
      02-22-2012, 05:57 PM   #20
E46toF30
Freude am fahren
E46toF30's Avatar
Drives: '16 F30 340i M-Sport 6MT
The EAS Dyno results for the 328i returned 226 whp and 230 lb-ft torque which would translate to 265 hp and 270 lb-ft torque at the crank with a 15% drivetrain loss.
Based on this Dyno, the 335i puts out 59 more horses and 57 more lb-ft of torque. Still a lot more power but the gap is much closer than before. For people like me who prefer the power, sound, and feel of an I-6 will still go for the 335i for the extra $3000(Xenons are a must and it's standard with the 335i where on the 328i you have to shell out $4500).
You can't go wrong with either car though.
      02-22-2012, 05:58 PM   #21
92660
92660's Avatar
Drives: E90 335i LCI
Thats what i thought too
Idk why this surprises anyone or needed to be confirmed since its the same engine
      02-22-2012, 06:05 PM   #22
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Because this:
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook
Follow us on Bimmerpost Twitter
Subscribe to Bimmerpost Youtube Channel
2012 335i dyno, 3 series f30, 3 series f30 dyno, 3 series f30 forum, 3 series forum, 335i f30, 335i f30 dyno, 335i n55 dyno, 335i n55 dyno video, bmw 3 series forum, bmw 3-series f30, bmw 335i dyno, bmw dyno video, bmw f30, bmw f30 3-series, bmw f30 dyno, bmw f30 forum, bmw n55 dyno, bmw n55 dyno result, bmw n55 dyno results, bmw n55 dyno video, bmw n55 rwhp, bmw n55 underrated, bmw n55 underrating, f30 3 series dyno, f30 3-series, f30 3-series forum, f30 335i, f30 335i dyno, f30 335i dyno video, f30 dyno video, f30 forum, f30 forums, n55 335i dyno, n55 335i dyno video, n55 dyno, n55 dyno chart, n55 dyno graph, n55 dyno result, n55 dyno results, n55 dyno video, n55 rwhp, n55 underrated, n55 underrating
