BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > H&R Releases Lowering Springs for F30 328i and 335i
Extreme Power House
      03-17-2012, 09:04 PM   #89
Eric335
Eric335's Avatar
Drives: 2007 E92 SG 335i 6MT
2007 BMW 335i  [3.83]
Originally Posted by tpipta View Post
Worst photoshop ever.
LOL
      03-18-2012, 01:35 PM   #90
Tallest
Tallest's Avatar
Drives: '14 F11 530d xdrive
Originally Posted by longtran@ltbmw View Post
it is possible BMW private label their OEM from companies like H&R or Eibach. Maybe thats how they make em so fast?
don't know if HR is OEM anything, and at least for E90 Sachs was OEM for suspension I think. Someone more knowledgeable correct me perhaps.
530 Touring / Xdrive
      03-19-2012, 05:28 AM   #91
Anderw
Anderw's Avatar
Drives: M235i
Looks good with a little drop
      03-19-2012, 09:26 AM   #92
bananachipz
Drives: F30 Mineral Gray 335i
Originally Posted by HP Autowerks View Post
The stock struts and shocks can only control the stock rate springs at stock height at best. Any lowering or increase in rates, more rebound valving is needed, no question there.
I test drove a new F30 328i over the weekend and still find the compression damping to be too much and rebound damping lacking. Installing sport springs only is not an upgrade, but rather a down grade performance wise.
Coming from 14+ years in BMW suspension tuning...If going with springs only, struts and shocks with better valving is a must. Coilovers are usually match in terms of spring rates and valving so not only you get the looks you are after, the performance doesn't suffer either.
      04-27-2012, 08:45 PM   #93
onehungevo
Drives:
We need pictures of stock wheels and super sport H & R springs
      04-30-2012, 10:11 PM   #94
onehungevo
Drives:
FYI.... The super sport don't evenly drop the front and the back of the f30. The front sits higher.
      05-05-2012, 10:04 AM   #95
cardnation
Güten Täg
cardnation's Avatar
Drives: 91 E30 & 13 F30
Originally Posted by tuned2ride View Post
As per my experience reported in post #18 above, your concerns are exaggerated and unjustified. I had a great experience with my lowered suspension (Eibach) and stock dampers for 65000 miles. My handling is not ruined, neither my ride and the car is more enjoyable. Would do it again.
I'm glad I'm not the only one running around debunking this perpetual 'wives tale'.
I've personally had; springs only, springs w/(shocks/struts) and full coil-overs. Ride quality/handling is nearly identical in all aspects. With C/O having an edge.
What gets me is people will say things like "get Koni's with those Eibach springs, springs alone will be awful". WTF?
What makes the Koni's more compatible with the Eibachs that the OEM's? Do they have a magic configuration compatible with every ride height/spring rate combo?
      06-17-2012, 05:17 AM   #96
pkimM3r
pkimM3r's Avatar
-41
it would be pretty bad if the car is constantly bottoming out due to the shorter spring.
2012 328i springs, 2012 335i springs, 3 series f30, 3 series f30 forum, 3 series f30 springs, 3 series f30 suspension, 3 series forum, 328i f30 springs, 328i hr springs, 335i f30 springs, 335i hr springs, bmw 3 series forum, bmw 3-series f30, bmw f30, bmw f30 3-series, bmw f30 forum, bmw f30 lowering springs, bmw f30 springs, bmw f30 suspension, f30 3 series springs, f30 3 series suspension, f30 3-series, f30 3-series forum, f30 328i lowering springs, f30 328i springs, f30 335i lowering springs, f30 335i springs, f30 forum, f30 forums, f30 h&r springs, f30 lowering springs, f30 springs, f30 springs hr, f30 suspension, h&r springs, h&r springs f30, h&r springs f30 328i, hr springs, lowering springs f30, springs f30
