BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > F30 19" wheel offset
Extreme Power House
      02-27-2012, 04:43 AM   #1
F30 Black Sapphire
Hong Kong
Drives: F30 328i Black Sapphire
Dear all,
Anyone can give me a hand.
I am still struggling I can use my old rims or not. I go thru the forum and found that the new wheel offset for 19" is
Front 8X19 offset 36
Rear 8.5X19 offset 47
My old rims are on my current E90 which is
Front 8.5X19 offset 32
Rear 9.5X19 offset 25
I am not sure is it fit or not. will the rear extend too much and rub? As I really want to keep my old rims.
Current : BMW F30 328i Blk Sapphire
Previous : BMW E30 325i/BMW E36 328i/E46 330i/BMW E90 335i (AW) MB SLK200
      02-27-2012, 06:02 AM   #2
ramonE90-NL
Netherlands
Drives: bmw F30 320iA
I've heard the attatchment bolts are thicker then the bolts on the E90. Thats why the E90 rims wouldnt fit the F30.
      02-27-2012, 08:49 AM   #3
E90Fleet
South Africa
769
Correct
F30 bolts are M14, like most new BMW models
E90 are M12
BMW if you are reading, I need a job, Please.
      02-27-2012, 10:49 AM   #4
USC2000
USC2000's Avatar
Drives: F30 328i M Sport
What does the bolt size have to do with the rims fitting?
2014 Alpine White 328i M Sport | M Performance Exhaust | M Performance Front Splitter | M Performance Carbon Fiber Spoiler | M Performance Grills | M Performance Pedals[/size]
______________________
      02-27-2012, 11:58 AM   #5
eric@helix
eric@helix's Avatar
Drives: 01 M Coupe, 08 135i, '12 328i
The holes in the wheels are too small to fit the new bolts.
      02-27-2012, 03:45 PM   #6
GTM_Challenge
GTM_Challenge's Avatar
Drives: E92 M3,X5M,F30 335
Send a message via AIM to GTM_Challenge
We test fitted some Volks on our F30 335 friday. The bolts fit through the holes fine. just FYI
      02-27-2012, 03:47 PM   #7
GTM_Challenge
Originally Posted by bp1996_335i View Post
Dear all,
The front should be able to fit no problem, but the rear is too aggressive unless you are running a smaller tire and more negative camber.
      02-27-2012, 06:11 PM   #8
USC2000
USC2000's Avatar
Never seen a rim spec that shows the measurements if the bolt holes.
      02-27-2012, 11:03 PM   #9
F30 Black Sapphire
Hong Kong
Dear All,
Thanks for all your information.
Yes, my concern is also the real as it maybe too aggressive.
Actually, my old rims were BBS LM-R, I'm not sure if the hole can fit for both M12 and M14? These information can hardly get from the internet.
As if I use the wheel calculator to compare with the BMW standard wheel, the result as follow.
10mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 28mm (Compare to style 397)
9mm MORE clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 35mm (Compare to style 401)
      02-27-2012, 11:44 PM   #10
Blake P
Kinda Like A Big Deal
Drives: F31 on order
Pics or it didn't happen!
      02-28-2012, 11:42 AM   #11
carlosalbertogui
Drives: bmw E91 facelifted by me
F30 offset please
yup
want to see some pictures indeed
offset of F30 ?????
offset oem E90 /E91 front is 34 and rear is 37 can be 34 if you have 8 inch whells on four....
F30 offset please
      02-28-2012, 11:46 AM   #12
carlosalbertogui
F30 my dear F31 LCI
Dear all,
hi not sure about F30 offset but i can tell you that
front are fine no problem
rear better use 20mm spacer and your good too go
you will have an offset of 45 pretty close to 47 so is a gogo
best luck
bolts always the same in diameter can be bigger in lenght but dont know
using the 20mm spacer should have bigger bolts in lenght
      02-28-2012, 11:57 AM   #13
carlosalbertogui
i found this dont know if its true
the F30 offset is 34 as E90
http://www.wheelfitment.eu/steekmaat...erk=BMW&type=3SerieE902005-2011)&merk2=BMW
      02-28-2012, 10:24 PM   #14
F30 Black Sapphire
Hong Kong
best luck
Hi there,
I think adding spacer is not a good idea, as the outer is already extend for 28MM. Adding spacer means extend more.
      03-05-2012, 02:38 PM   #15
carlosalbertogui
hi again
original bmw E90/E91 is 34 ront and 37 rear
so you can put the F30 whells
original f30 is 36 front and 47 rear
front is a go go no problems
rear you have to see if the tire hits the suspension if it touch you have to add a 10mm spacer on rears
know i get it
you want old rims on new
yes you can no spacer needed just see if you have under fender space
Package will stick out 22 mm (0.9'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset.
best regards
      03-06-2012, 03:31 AM   #16
rdtx516
Drives: 2007 E90
check if your old wheels have some room behind the paddding to be shaved down. if so, do it and should have min of 10mm to shave down which will increase your offsetts. don't gauge of oem as most goes way off from those numbers. I have mounted 9.5x19 et20 with 295/30/19 PS2 tires without rubbing. Also, camber -2 rears will give you additional room. Otherwise, go see Jay and have them open up your fenders and fit any wheels you want.
      05-08-2012, 09:46 AM   #17
mookie45
mookie45's Avatar
420
Drives: 2017 AW 340i M-Sport
Here are the offsets of the f30:
http://www.f30post.com/forums/showthread.php?t=685033
      05-08-2012, 11:50 AM   #18
HiTek
Info-Maniac
Drives: 2012 328i Sport
I don't want to hijack this thread, but it is on topic. I am in a unique position to get a set of:
BMW Staggered Vertini Luxury Wheels Matte Black Rims
Specifications;
Two Front - 20" x 8.5"
Two Rear - 20" x 10"
5 X 120mm Bolt Pattern
I should be able to get a great deal on them, but I need to know if they will fit. This whole larger lug bolt is getting me worried. I will NOT be able to take them back to the private seller. Any help would be appreciated! Thanks.
MW 328i Sport/Premium, Cold Weather & Tech Pkgs/Sport Auto. Trans/Variable Sport Steering/Xenons/Park Distance Control/M Performance Black Kidney Grills & Gloss Black Whiskers/Black Gloss roof Wrap/Dinan Exhaust/aFe Intake/JB4 w/ Bluetooth
      05-08-2012, 12:40 PM   #19
Blake P
Specifications;
What is the wheel offset?
      05-08-2012, 02:09 PM   #20
HiTek
Info-Maniac
20 X 8.5 - 130/5H
20 X 10 - 120/5H
That is all I could find on the website.
      05-08-2012, 02:14 PM   #21
Blake P
20 X 8.5 - 130/5H
20 X 10 - 120/5H
Assuming 130/5H and 120/5H refers to the bolt pattern, those are not the correct front wheels. BMW uses 5x120, which I believe is the same as those rears (120/5H). Otherwise, that's still not enough information to say whether the wheels will fit or not. You must have offset (or ET) information as well.
      05-10-2012, 06:38 AM   #22
HiTek
Info-Maniac
They are all 5 X 120 After speakin with the seller. Below are the measurements for the offset. The measurements are from the mounting surface to the back of the rim.
Front -8.5"- 6.125" (15.6cm)
Rear -10"-6.875" (17.5cm)
There are two 20mm aluminum spacers for the rear included if I require them.
f30 whee offset, f30 wheel offsets, f30 wheel specs, f30 wheels
