BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > F30 19" wheel offset
      05-10-2012, 12:33 PM   #23
Blake P
Kinda Like A Big Deal
Drives: F31 on order
Originally Posted by HiTek View Post
They are all 5 X 120 After speakin with the seller. Below are the measurements for the offset. The measurements are from the mounting surface to the back of the rim.
Front -8.5"- 6.125" (15.6cm)
Rear -10"-6.875" (17.5cm)
There are two 20mm aluminum spacers for the rear included if I require them.
If those measurements are correct, that makes both the front and rear offset ET47.625, which just might work. I'm not familiar with how much room is in the rear fenders, so you might want to ask LTBMW, since I think they're the only ones running extremely aggressive rear wheels and offset. The fronts will fit without any issue, though.
      10-03-2013, 12:51 PM   #24
Jonny79
Drives: BMW 320i
Alloy wheels offset
Hi Guys,
I need your advice on buying alloy wheels. I live in Austria and got my BMW F30 320i a few months back...have to switch to winter tyres in around 4 weeks.
I have been looking around to get complete winter tyres preferably 225/45 R18...the ones BMW sells are way expensive.
The ones I have found at few shops have rim offsets of 35mm whereas, BMW recommends 34mm for front and rears. Does that make any difference?
Thanks
      01-13-2014, 02:21 PM   #25
ocarioca1m
Brazil
Drives: 335i
Sorry for bringing this thread back to life.
Looking to buy a set of M5 reps sizes are Front 19x8,5 ET 35 Rear 19x9,5 ET37
I see they're a bit different from oem offset. Would that cause any problem?
Thanks
Current: 2012 335i Sport Melbourne Red
Mods: Jb4 / BMS Intake / Challenge HFC DP/ ER Charge Pipe / M-Performance Exhaust / Dinan Suspension /M6 19" Reps
Rip: 1M
      01-13-2014, 04:50 PM   #26
.BMW.
.BMW.'s Avatar
Sweden
659
Drives: BMW F11
Thanks
The front is perfectly fine. 9.5x19" ET37 rear is a bit aggressive, but nothing extreme.
What tire sizes do you plan to mount?
OEM 19" staggered tires 225/40-19 front and 255/35-19 rear will work with your offsets and fit nice on 8.5" and 9.5" wide wheels. If you want to go with a wider rear tire you might need to adjust camber.
      01-14-2014, 05:08 AM   #27
ocarioca1m
Brazil
Drives: 335i
I was thinking.
F: 8.5x19", 245/35-19
R: 9.5x19", 275/30-19
I could use some extra rubber jb4 and downpipe going in soon...
Suspension is stock.
Rip: 1M
      01-14-2014, 10:59 AM   #28
.BMW.
.BMW.'s Avatar
Sweden
659
Drives: BMW F11
275 rear will work on stock Sport Suspension. But the rear tire may visually be a tad bit outside the fender.
Here is a member with 9.5x19" ET35 and 275 rear:f30post.com
      01-15-2014, 04:32 PM   #29
paperplanes415
paperplanes415's Avatar
Drives: 2015 328i M Sport Wagon
Originally Posted by carlosalbertogui
Originally Posted by bp1996_335i View Post
Dear all,
Anyone can give me a hand.
I am still struggling I can use my old rims or not. I go thru the forum and found that the new wheel offset for 19" is
Front 8X19 offset 36
Rear 8.5X19 offset 47
My old rims are on my current E90 which is
Front 8.5X19 offset 32
Rear 9.5X19 offset 25
I am not sure is it fit or not. will the rear extend too much and rub? As I really want to keep my old rims.
hi not sure about F30 offset but i can tell you that
front are fine no problem
rear better use 20mm spacer and your good too go
you will have an offset of 45 pretty close to 47 so is a gogo
best luck
bolts always the same in diameter can be bigger in lenght but dont know
using the 20mm spacer should have bigger bolts in lenght
If you use a 20mm spacer the rear will turn into +5 not +45. A spacer pushes the wheel further out LOL.
      01-03-2015, 06:41 PM   #30
asaraiva
Drives: F30 320i
I am planning to use the same wheels (M5 reps) but still not sure if I get:
Front: 8.5x19 ET37 + 225/40-19
Rear: 9.0x19 ET44 + 255/35-19
or
Front: 8.5x19 ET37 + 235/35-19
Rear: 9.5x19 ET44 + 265/30-19
Any advice about those options?
      07-08-2015, 10:13 PM   #31
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
Drives: Audi, BMW, & RR...
I have a set of custom made BBS LM that I have installed on my E46 M3. I may be taking them off to install something different. Does anyone know if the specs below would work on an F31?
-Front: 19x8.5 ET32 / 245.35.19
-Rear: 19x10 ET25 / 275.30.19
If not would the OEM E46 M3 wheels work?
-Front: 19x8 ET47 / 225.40.19
Rears: 19x9.5 ET27 / 255.35.19
      05-30-2017, 08:48 AM   #32
Keepitbrutal
Drives: F30 328
Hello! Guys, help me pls!
Could u tell me if r18 8.5j et 13 with 225/45/18 will fit f30 with mpe -20 mm suspension?
I know that Avant Garde m310 r19 9.5j et 33 with 255/35 fit the rear axle ok.
Comparing to them my estimated setup goes +5 mm on the fender side.
So probably the rears gonna fit ok im not sure.
And ive got no idea about front wheels.
Hoping for ur help!
f30 whee offset, f30 wheel offsets, f30 wheel specs, f30 wheels
