BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Surely DS is redundant...
European Auto Source
      04-10-2012, 01:47 PM   #1
SomeRandomer123
SomeRandomer123's Avatar
England
232
Drives: F30 328i Luxury - Sport Auto
On the Automatic Transmission cars, there has been a DS option for a while, as there is on most auto cars.
So moving the lever to the side to activate DS does the following:
Sharpens throttle response
Goes into a gear lower
Goes closer to the redline
Please add/remove/amend the above!
Putting the car into Sport mode also does all of the above, plus more, so what is the point in DS?
Thanks!
Gone: 2006 BMW E60 520d SE 6MT
Gone: 2009 BMW E90-LCI 330d SE 6MT
Current: 2012 F30 328i Luxury 8AT
On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!)
      04-10-2012, 01:56 PM   #2
bcl0328
Drives: 2012 328i
do you have the sport transmission? moving the lever to the left puts it in sport mode if you do.
      04-10-2012, 02:11 PM   #3
rohms3
Drives: 2015 Audi S4
Moving the lever to the left, regardless of transmittion puts you is DS
DS is JUST for the transmittion. It changes shift points, shifts faster etc
Sport mode changes the transmittion the same as DS, but also changes steering weight and throttle response.
So DS is not redundant. You can keep the car in Comfort for light steering and throttle, but get quicker shifting and higher shift points.
      04-10-2012, 02:21 PM   #4
SomeRandomer123
England
232
Yes, well, I will do when it comes!
      04-10-2012, 02:23 PM   #5
SomeRandomer123
England
232
I don't believe the shifts are quicker in DS. More severe possibly, but I don't believe they are quicker. Can anybody confirm this? I may be wrong!
Also, doesn't DS sharpen throttle response?
      04-10-2012, 02:32 PM   #6
rohms3
I can confirm that DS doesn't sharpen throttle response. The shifts are ceratinly quicker in M, I don't know about DS as I don't use it, but I would believe they are...
      04-10-2012, 02:33 PM   #7
ziggys101
ziggys101's Avatar
Drives: F06 640d MSport
DS also turns off start stop, so if im coming up to a junction where I know ill only stop for a split second i put the box in DS and once ive pulled away slip it back to the right.
      04-10-2012, 03:24 PM   #8
CasZy NL
CasZy NL's Avatar
Netherlands
17
Drives: M4 | X5 | Z1
2008 BMW X5 35d  [5.00]
2015 BMW M4  [5.00]
1991 BMW Z1  [5.00]
In DS it does sharpen throttle response, shifts later and stays longer in the same gear (also if you do not stay on the throttle). It is in attack mode.
      04-10-2012, 03:28 PM   #9
rohms3
On an F30, DS DOES NOT sharpen throttle response. Only changing the driving mode to Sport will.
      04-10-2012, 04:24 PM   #10
SomeRandomer123
England
232
You've said exactly what I'm thinking! It MUST sharpen throttle response! Surely! I know for a fact it does in the E9X series.
      04-10-2012, 04:25 PM   #11
SomeRandomer123
England
232
Really? That is EXTREMELY surprising! It MUST do!
      04-10-2012, 04:26 PM   #12
SomeRandomer123
England
232
Interesting! Didn't know DS was a inhibitor of Stop/Start.
      04-10-2012, 09:07 PM   #13
rohms3
Don't trust the person who has driven their car 2000 miles. You must be right.
      04-10-2012, 10:40 PM   #14
Fraggy
Fraggy's Avatar
Drives: 2016 M3
Yup, also sport mode will disable start stop as well.
2016 Alpine White M3
      04-11-2012, 04:44 PM   #15
SomeRandomer123
England
232
Haha fine I'll trust you, sorry! I just find that very surprising!
      05-01-2012, 12:32 AM   #16
Cam70
Drives: F30 328i
In the car I test drove (328i, Modern pack, with sports auto) the change to sport mode did not effect start stop.
Moving gear shifter to the left did, but even sports+ didnt effect the start stop function.
      05-01-2012, 02:11 AM   #17
Carnook
Drives: On Order
In DS if you use the paddle shifters it will stay in manual mode. In regular drive if you use the paddle shifters I believe it goes back to automatic after a certain number of seconds.
      01-19-2013, 04:38 PM   #18
Phamous
Phamous's Avatar
37
Drives: 2013 BMW 328i
So if you put your car in DS, you don't have to shift correct? Just put it in DS and drive the car the way you would in D?
Picked Up:2013 328i xDrive|Alpine White|Coral Red|///M Sport|
      01-19-2013, 05:13 PM   #19
zofinger
zofinger's Avatar
England
43
Drives: F30 335d MSport
I like this idea. Saves reaching for the ASS button - i hit the start/stop engine button by mistake once!
      01-19-2013, 06:23 PM   #20
David328M-Sport
Australia
62
I'm not using Sport mode at this time, so when I want a little bit more than Comfort offers, I push the lever to DS and go. Plus I show off to passengers about how the gear lever it flips back to its neutral position on its own from DS when I press Park.
Always gets a "wow" comment.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect. JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      01-19-2013, 07:31 PM   #21
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
Thanks!
Timing and Steering feel is in favor of the Sports mode dude!
SOLD: 2012 335i Mineral Gray
      01-19-2013, 08:57 PM   #22
SomeRandomer123
England
232
This thread is so out of date now. I posted this way before I got my car!! Can we let it die? All problems solved and some info not accurate and dated.
