BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Photo, Video, Media Gallery, Journals > Glacier Silver with painted reflectors..
      04-13-2012, 07:42 PM   #23
's Avatar
61
Drives: ✚
Jeez. Silver looks hot.
      04-13-2012, 07:44 PM   #24
bl@ster
bl@ster's Avatar
25
Drives: 2012 328i
Dayom! That car is smokin.
      04-13-2012, 09:40 PM   #25
matt_435xi
matt_435xi's Avatar
Drives: F36 435xi M-Sport
Send a message via AIM to matt_435xi
Originally Posted by yerffejleahcim View Post
Congrats! Nice to see a silver F30. Please post more pics when you can. Rear and interior please.
i have posted rear and interior shots, enjoy!
'15 435xi GC Glacier Silver w/coral red leather & ash wood trim/ZM2/ZDA/ZLP/ZPP/ZTP/park assist/HK sound/hot seats/27% tints/DINAN stage 1/DINAN exhaust/carbon fiber side mirrors/carbon fiber rear spoiler/19" e46 M3 CSL wheels
*RETIRED* 2012 335i [f30] | 2009 z4 35i [e89] | 2007 335i coupe [e92] | 2001 325Ci [e46] *RETIRED*
      04-13-2012, 09:43 PM   #26
dmontic71
dmontic71's Avatar
Drives: 2012 F30
Originally Posted by matt_335Ci
although AZ doesn't require a front license plate, and i ordered after that nasty front bulge was standard issue, i am still unhappy with the front fascia of the F30. i have had several BMWs and NONE of them have these horrible dimples, i assume for states that require plates, on the front bumper!
i guess the 2015 F30 LCI will take care of these.
Mine has those same dimples....
2012 F30 328i, Melbourne Red, Premium, Sportline, Steptronic, Xenon, Harmon Kardon.
      04-13-2012, 10:35 PM   #27
RASHID007
Drives: 2014 535d X-Drive
Wow. Just wow. Congrats that's gorgeous. Enjoy it in good health!
      04-13-2012, 10:55 PM   #28
matt_435xi
matt_435xi's Avatar
thx! Glacier Silver is a great color.
      04-13-2012, 11:44 PM   #29
yerffejleahcim
yerffejleahcim's Avatar
92
Drives: '16 F80 M3 Alpine White
Wow! Makes me drool. Love Glacier Silver even more. Thanks for the pictures!
Michael
2016 F80 M3 Alpine White / Sakhir Orange / DCT
      04-13-2012, 11:50 PM   #30
matt_435xi
matt_435xi's Avatar
Originally Posted by TiAg330i View Post
Painted reflectors are such an improvement on the F30. Nice job. More photos please!
enjoy!
      04-14-2012, 02:22 AM   #31
PrinceBarin
Drives: 440i
Gorgeous looking car Matt. Love the clean look of the front end now that the reflectors have been painted.
Presumably you don't have to fix a front licence plate in AZ? Wish the UK was the same.
      04-14-2012, 02:27 AM   #32
matt_435xi
matt_435xi's Avatar
thx PrinceBarin! no front plates required in AZ, now that is a reason to move across the pond.
      04-14-2012, 08:22 AM   #33
Zirenz2006
Zirenz2006's Avatar
Drives: X3 M40i Phytonic
Looks so much cleaner with the painted reflectors
Current: G01 M40i Phytonic Blue|Black with Blue Stitching
Retired: '12 F30 328i Sport Line Sapphire Black|Black-red, '09 E90 335i M-Sport AW|Oyster, '07 E92 335i Graphite|Saddle, '05 E60 545i TiAg|Black, '01 E46 325i Jet Black|Black
      04-14-2012, 12:37 PM   #34
matt_435xi
matt_435xi's Avatar
i have received a lot of questions about the installation of the painted reflectors. i have attached a pic of the reflectors before installation, as you can see there is a pull tab in the corner. around the reflector is a strong adhesive, so you will pull the tab and remove the sticker covering right before you install.
step 1
Drive around for a little while and let everything get hot. (This will make it MUCH easier to remove the reflector). to install you must turn your steering wheel so that your wheel is pointing toward the inside of your car; exposing the front side wheel well. then remove a couple of screws holding the wheel well. after you remove a couple you will be able to pull it back enough to get behind the wheel well.
step 2
Use "Goo-Gone" / 3M remover / "Oops"... now, apply the 3M remover to the outside of the reflector around the edges and also behind the reflector, behind the bumper. I used "Oops" and just squirted it all around the reflector and it worked like magic. from behind the reflector pry around the factory reflector and also press on it from the outside of the car.
step 3
Now, just SLOWLY push the reflector in (from outside the bumper). Start from the left of the reflector and work your way to the right, slowly pushing the reflector in. You can repeat step 2 as many times as you want to loosen up the 3M tape even more. after it removes wipe down any excess goo gone, get it dry on the inside of the opening. finally, pull the tab on the new painted reflector and press into place - obviously it is installed from the inside of the car. reinstall the wheel well and then repeat on the other side.
      04-14-2012, 01:27 PM   #35
Zirenz2006
Zirenz2006's Avatar
Did you take any pics of the install? I remember on the E92 you didn't need to remove any screws in the wheel well.
      04-14-2012, 01:37 PM   #36
matt_435xi
matt_435xi's Avatar
sorry i did not take pics.
you are correct, i had an e92 and the reflector was not behind the wheel well. the F30 is similar installation as the e92, but you have to get behind the wheel well.
      04-14-2012, 01:41 PM   #37
dmontic71
dmontic71's Avatar
Drives: 2012 F30
+ no Co2 emmissions tax!
      04-14-2012, 02:17 PM   #38
emtrey
emtrey's Avatar
41
Drives: 16 M235IX, 06 Carrera S, 335i
when I did this on my E46 M-3, the reflector was on a spring clip. does this appear to be spring loaded ?
To clarify, you used the OOPS on the OEM reflector to loosen its factory adhesive then pushed it out from behind. Is the pressure on the front side from the opposite side you are pushing out from behind.
Love the look. Hope to do the same when my AW 335 arrives.
      04-14-2012, 02:20 PM   #39
matt_435xi
matt_435xi's Avatar
it is not spring loaded or have any clips, it's just held on with adhesive.
push from outside of the car and the reflector will fall behind the bumper.
      04-16-2012, 07:03 PM   #40
okolisr
okolisr's Avatar
Drives: '15 435i xDrive Msport 6MT
The painted reflectors look fantastic.
Is there any way to accomplish something similar (at least get rid of the ugly yellow/amber color) while still keeping the car legal in the USA? The problem is not so much the possibilty of a ticket, or failing a safety inspection, rather it's the potential liabilty in an accident.
      04-16-2012, 07:14 PM   #41
matt_435xi
matt_435xi's Avatar
liability in an accident? i can't think of a situation where the painted reflector can be used against you in court? that is like saying illegally tinted windows would make you liable in an accident because you couldn't see as well...because of the darkened glass.
you must be either an Engineer (like me) or a Lawyer.
      04-17-2012, 08:46 AM   #42
BMWark
BMWark's Avatar
Drives: 2005, X5,Black/Black
I have a silver one on the way, but didn't get gray inside. (Black) I sure like the look of your gray.
Order: 13 Mar 2012, F30 328i Luxury, Silver, Black.
      05-05-2012, 04:43 AM   #43
longtran@ltbmw
longtran@ltbmw's Avatar
317
Drives: 2011 Toyota Tundra
congrats matt, that color looks awesome.
      05-05-2012, 06:39 AM   #44
AlpineF30
vrooom
Drives: Alpine White 328i Sport
if your f30 is black or white, can't you just plastidip the reflector?? itll be much easier and you can remove it on the spot if you ever get shit from the cops
