BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > E90 none CA key problem
      04-12-2012, 02:43 PM   #1
Beamin
Drives: Black 06 330i Sport
Did my research and could not find much of an answer for the keys that arn't easy access. I just bought an 06 E90 330i, I noticed that I cannot unlock the car unless I am about 5 feet away from it. I figured the key is 6 years old.....is this just BMW or should it work from a further distance. I've been on long trips recently so if it is rechargeable then there is a problem. I love the windows/sunroof down feature but I cant use it because I find myself standing outside of the car waiting for everything to go down. What is the cheapest way to fix this problem?
Thanks,
Beamin'
      04-12-2012, 02:47 PM   #2
E90Fleet
South Africa
1068
Hi
Wrong forum, but here goes.
Does the car have tint ?
This is usually the cause of this problem.Metallic tints interfere with the key signal, causing you to have to be very close to the car. Non-Metllic tints work fine
BMW if you are reading, I need a job, Please.
      04-12-2012, 04:28 PM   #3
Grumpy514
Grumpy514's Avatar
Drives: 14' 535i
New battery.
      04-13-2012, 04:20 AM   #4
E90Fleet
South Africa
1068
Originally Posted by Grumpy514 View Post
New battery.
The non-CA key has a permanent battery that is charged when you insert it into the key slot. You cannot change it.
