BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic Maintenance: Wash, Wax, Detailing, Repairs > So it happened, how do I fix a paint chip?
      04-12-2012, 04:14 PM   #1
bcl0328
Drives: 2012 328i
I hate those paint-chipping windshield-shattering dump trucks on the road. Already got a small chip in the paint. How can I fix it?
      04-12-2012, 05:06 PM   #2
bcl0328
Drives: 2012 328i
anyone ever use dr. color chip?
http://drcolorchip.com/select-produc...&submit=Submit
      04-12-2012, 05:55 PM   #3
KneeDragr
Drives: Planning 2015 ED :)
Ive used it, it fixes the color aspect but it does not fill it in depth wise.
      04-12-2012, 06:02 PM   #4
bcl0328
Drives: 2012 328i
there is barely any depth, i just want the color to match.
      04-13-2012, 07:50 AM   #5
KneeDragr
The non-metallic color will always match better. Nobody on here is going to know enough about your particular color unless you tell us the color of your car.
      04-13-2012, 09:04 AM   #6
E90Fleet
South Africa
769
Your BMW dealer can sell you a little touch up paint and clear coat paint kit, if that what you want.
They also have a larger BMW chip repair kit with small sanding and polishing compounds
BMW if you are reading, I need a job, Please.
      04-13-2012, 09:16 AM   #7
KneeDragr
The Dr. Colorchip will *likely* look better than the simple touch up paint. The reason why is the touch up paint usually beads up and forms a lump where the paint chip was. The Dr. Colorchip quickly bonds to the paint, and allows you to wipe it off with a pad that is dampened with a paint sealant.
Now if you want to go all out, the sanding/polishing kit is the way to go. Basically you apply the touch up paint and let it form a lump. Then come back later and wet sand it flush with the paint, then polish out the sanding marks. The result should be nearly flawless.
Personally I dont have a lot of faith in myself taking sand paper to my car finish, so I use the Dr. Colorchip.
      04-13-2012, 09:26 AM   #8
shoptb
shoptb's Avatar
Drives: 13 328i MSport EBII 8A
You can get a quality clear-bra on the front of your car. Got mine 2 years ago, and not a chip on my baby. The peace of mind is worth the cost, plus bugs and stuff just wash off so much easier.
And for those that say the line is so noticeable...it's all about the quality of the material and the installer....look for yourself....
Delivered! --> '15 F33 328xi, 8SA, Glacier Silver with Coral, 403M-19", ZMM, ZPP, ZTP, ZDA, ZDB, ZCW, ZDH, 4M5
Past --> '13 F30 328i, 8SA, EBII, ZMM, ZPP, ZTP, ZLP, ZDA, ZCW, ZDH, BMS Stage 1
Past ------> '08 E92 335xi, 6MT, DGM w SDL, ZPP, ZTP, ZLP
      04-13-2012, 09:46 AM   #9
KneeDragr
Did you get the mirrors also?
      04-13-2012, 01:24 PM   #10
bcl0328
Drives: 2012 328i
alpine white
      04-13-2012, 01:27 PM   #11
KneeDragr
alpine white
Have they offered that color before 2012? Id check on other forums to see if anyone with that color has had success with a a particular product.
      04-13-2012, 02:38 PM   #12
onehungevo
Drives:
Dr. Colorchip worked great on one of my old cars that had metallic paint. I was afraid it would be a little dark where I applied the touch-up but I couldn't find it after applied. If you want to fix the depth you apply more than one coat. I wouldn't mess with trying to sand it. If it's really large I would bring it to a paint shop and have them try and fix it.
      04-13-2012, 02:40 PM   #13
onehungevo
Drives:
The clear bra works great. Having no rock chips on your car driving in Columbus is saying something. There are a ton of large trucks that drive through there.
      04-13-2012, 06:03 PM   #14
bcl0328
Drives: 2012 328i
this shop wanted $690 to do a full clear bra, including mirrors.
      04-13-2012, 06:13 PM   #15
Red Bread
Drives: My wife's car
This is a trick question right? I can see that in both pictures quite clearly and on the headlight sprayers. I'd rather have a few rock chips and not have to see the clear bra every time I approach my car, but understand why folks go either route.
I'm detail obsessed and have a four year old Jet Black car that I don't find that hard to keep nearly swirl free, just for reference.
As for fixing Alpine White, it should be easy, it's a single stage paint, just buy the touch up paint, use a tooth pick to fill the hole with color, one drop at a time, let it dry over night, add a drop and then fill the hole slightly over level with the clear coat and then wet sand it level with a 2000 wet block. Even for a large chip, you should be able to fill the entire thing and have it sanded in under a week.
      04-13-2012, 10:15 PM   #16
shoptb
shoptb's Avatar
I didn't say it was invisible, but to me, that's a really good job considering that I don't have to worry about rock chips, bugs, other annoyances. I agree that if one is detail-obsessed and has the time to keep a jet black car swirl free....you're probably ok without the clear bra. I wish I was that patient!
      04-14-2012, 10:14 AM   #17
SCBimmerKid
SCBimmerKid's Avatar
24
Drives: Mineral Grey F30
My sister's dad (long story) had a Gallardo that had the clear bra on the front, applied by someone in Columbus, and it was great for about two years and then weirdly began to get a little hazy, and bugs became MUCH harder to remove from the bra than the actual paint. Have you experienced this at all?
*NO LONGER ON ORDER* '12 328i Mineral Grey Metallic w/black leather/aluminum&black gloss trim/ZSL/ZPP/Xenons
      04-14-2012, 11:06 AM   #18
shoptb
shoptb's Avatar
Wow, that's interesting. No, I haven't experienced that...and if I did, I probably wouldn't be so positive about the clear-bra. I got mine installed by an independent guy (Julius Poa) from over in Dayton....he's apparently one of the best in Ohio. It's been almost two years, and no swirls/haziness yet. I wonder how much difference the actual type of material used accounts for that?
      04-14-2012, 11:29 AM   #19
KneeDragr
There are dozens of different versions of the film they apply. Some of it is really cheap and yellows after 6 months of daily driving. Other stuff lasts 3+ years, but its always going to have some UV degradation over time.
      04-14-2012, 01:56 PM   #20
SCBimmerKid
24
Hmmm, I think it was applied by MAG when he bought it. It wouldn't surprise me if they put on some cheap stuff. However, it was FAR from cheap to apply.
      04-14-2012, 02:36 PM   #21
JoeyO
Drives: silver car
You guys in the south don't know what it's like to maintain a car in mint condition here above the snow belt. From Oct to April, you car is constantly subjected to rocks and pebbles left behind by the snow trucks. Many cars (not mine, of course) look like they have a cancer or pox of the front end. Totally disgusting, especially on black cars. Clear bras aren't perfect, but they're definitely the lesser of two evils.
      04-15-2012, 01:33 PM   #22
Jan van Zyl
Namibia
Drives: 2011 X3 (F25) x-drive 2.0D
I have an Alpine white X3. Developed a few stone chips. Visited a reputable panel beater - and was fortunate that they repaired an Alpine white BMW the previous day. They gave me for free a "Cutex" bottle of paint which I then applied with the Cutex brush. He warned that it is a water based paint that may eventually wear off after repeated washing. Then will need to be re-applied. Sofar I didn't need to reapply though. Immediately after application the color seems "different" to the rest of the paint - after drying it is the same though. It does not fill the depth defect - this I may have done professionally before selling. The overall result quite satisfactory though. Hope this helps.
