BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Disabled control valve on 328i exhaust for better sound
      04-14-2012, 10:00 AM   #1
TEAShea
Drives: 2012 328i
I like exhaust sound. As you all know the 328i has almost none.
I disabled the control valve on the second exhaust pipe. It was even easier to do than on the prior generation car. This value is electrically operated instead of pneumatic. I had been concerned that I would have to cut the control stem or fuss with the wiring - but was concerned about throwing a code. Turned out to take exactly 30 seconds to disable mechanically.
BTW you can check to make sure the valve is open by feeling if the exhaust is coming out of the second pipe.
The bad news is that it made very little difference in sound.
So, now I am on to stage two of my options for getting a little more sound. I will keep you all informed.
Tom
      04-14-2012, 10:15 AM   #2
justinnum1
Drives: 2015 328i Msport 6mt
What did you do to disable it? What is stage 2?
F30 328i Alpine white/Coral red Msport 6MT, HK, Zenons, msport brakes, black grills and black side sills. mperformance exhaust
      04-14-2012, 10:44 AM   #3
EuroTunerz5
Drives: 2012 AW BMW 135i M-Sport PPK
I really like the manga flow sound on the Audi 2.0t and I suspect it would sound similar on ours.... It makes the 2.0 sound like a 6 cylinder.. Perhaps this is our solution to the problem?
2012 BMW 135i M-Sport PPK AW with Black Boston Leather- SOLD
2010 Acura TSX V6 Tech BSM
2003 Corvette Z06 TR "Widebooty"
      04-14-2012, 10:50 AM   #4
TEAShea
Drives: 2012 328i
To disable it, just remove the U shaped spring wire that connects the valve stem from the actuator.
      04-14-2012, 12:49 PM   #5
SomeRandomer123
SomeRandomer123's Avatar
England
189
Drives: F30 328i Luxury - Sport Auto
When would this 2nd (assuming inner) exhaust normally open out of interest?
Gone: 2006 BMW E60 520d SE 6MT
Gone: 2009 BMW E90-LCI 330d SE 6MT
Current: 2012 F30 328i Luxury 8AT
On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!)
      04-26-2012, 12:22 PM   #6
BMVeh
Drives: 2006 330i
i believe its when you are WOT
      04-26-2012, 02:51 PM   #7
ric124
ric124's Avatar
Jamaica
392
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
Do you think its the same for the 335? Could you post some pics? Like a mini DIY
      05-07-2012, 12:58 PM   #8
SomeRandomer123
England
189
It would definitely open then but is there other criteria like after 3000rpm for instance?
      08-19-2012, 04:08 PM   #9
1.fresh.f30.335
Drives: 2014 535xdrive M-Sport
just did this on my 335 today. if you use a screwdriver you can easily pop the spring wire out of place and then zip tie the flap open. I will post some pics this week.
'12 335i Sport Apline White w/black... Totaled
'14 535i xdrive M-Sport Carbon Black w/Mocha Nappa
      08-19-2012, 04:40 PM   #10
yjoonee
Drives: 2012 MW 328i Sedan
i wouldn't zip tie anything near the exhaust... use a paper clip instead?
      08-19-2012, 05:28 PM   #11
1.fresh.f30.335
zip tie isn't on the exhaust, its on the mount. I agree that a zip tie on the exhaust would be a problem. and a paper clip wouldn't be strong enough imo
      08-20-2012, 05:36 AM   #12
steadymoddn504
Drives: e36 m3
12 BMW 328i  [0.00]
1st mod and new to forum!
Just did this on my 328i and i also used zip ties. I only pried off the end of the U wire clip closest to the actuator and tied it down. dnt know if im supposed to unplug the actual wire thats connected on there also but for future references tying the clip in the up position opens the valve..correct me if im wrong or share your thoughts
make sure its real tight so it doesnt rattle. haven't gone for a test drive yet, but i will tomorrow n will be checking for faults/misc concerns and f/u if needed.
the only thing in this world that gives orders is balls. You got that? Balls.
      08-20-2012, 11:07 AM   #13
BRM6
BRM6's Avatar
Brazil
Drives: 328/335/M235i/M4 - Current M6
Sound clips would be nice and maybe a DIY?
      08-20-2012, 02:40 PM   #14
scott@bmwhn
Drives: Msport X3
I experimented with this but as stated it didnt seem to make much difference and if you dont secure the flap tight enough you'll get a horendous rattling
...interested to see what your "stage 2" is
15' Msport X3 28i _Mperformance - ACschnitzer - H&R_
15' Sportline X1 28i _Mperformance - H&R - Recaro baby seat_
Previous:13' Msport 328i, 09' Msport 335i, 07' Msport 335i
      08-21-2012, 03:14 AM   #15
's Avatar
61
Drives: ✚
I experimented this on my 335i as well (I know this is the N20 thread). No perceptible sound difference at all. Much ado about nothing really. I put it back to stock.
      09-28-2012, 08:24 PM   #16
pommes
Austria
Drives: M2 LLB 5/2016
My english is not the best (sorry), but i asked BMW Austria and the answear was
According to information from the competent colleagues with the silencer
Part number 18 30 2 293 769
during the fourth quarter of 2012, with each BMW partner ordered in Austria.
I hope you can also order the performance exhaust this year because the sound is not a 245 ps gasoline worthy
      10-03-2012, 05:55 AM   #17
loz3rxfreak
Drives: 2012 328i
i would like to see the same if possible
      10-08-2012, 06:47 PM   #18
edgarik
Drives: 328i Basic Auto
Where is the actuator located? Can anyone give instructions? I have a 2012 328i
      12-03-2012, 05:10 PM   #19
david borla
david borla's Avatar
Drives: 2004 VW R32
We just started work on Borla aftermarket exhaust options for the F30 328i. If there are any specific ideas you guys would like to see us include in our designs please let me know. Can't promise that we'll do everything that is asked but we'll certainly do our best for you. I am certain we can improve the sound and may even offer more than one sound option.
For those of you who have disabled the exhaust valve, did this cause a CEL?
      12-03-2012, 05:48 PM   #20
unintelligible
Computer Janitor
unintelligible's Avatar
Drives: '12 F30 328i
If you unplug the connector, it doesn't throw a CEL, but it does store a code... it came up using the BavTech scanner.
2012 328i Sport Line 6MT (Turned In)
2015 Ford Mustang GT Premium (Current)
      12-03-2012, 08:15 PM   #21
Rick4345
Rick4345's Avatar
Drives: 2017 M2 6MT LBB
The first thing would be to use the dual round rolled angle cut. I think a cat back system would work well. Another thought would be to ensure the mounting rods were just like the oem. I would also like to see all stainless with a lifetime guarantee. Magnaflow offers one on their system. I don't think the valve is a big issue. Just finding a place to tie the actuating motor to or having a mounting tab on the pipes would be nice. I had one of your systems on a 2004 Toyota Camry with the four cylinder. I loved it. I hope you make systems for the N20 and the N55 engines.
      12-06-2012, 03:55 PM   #22
david borla
Drives: 2004 VW R32
Thanks guys. Anything else please let me know.
