BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Would anyone trust this?
Closed Thread
      04-15-2012, 03:45 PM   #1
bcl0328
Drives: 2012 328i
http://www.bimmian.com/Xenoflo-Xenon...ab-description
These may be used to either upgrade your fog lights to HID or to upgrade your halogen headlights to HID.
      04-15-2012, 04:06 PM   #2
mapezzul
Special Agent
mapezzul's Avatar
Drives: Depends on the day!
Technically makes them illegal if I am not mistaken as they are not projector and do not have the ability to be leveled....
Personally I wouldn't touch these with a 20ft pole as they are not OEM and are not projector. I would get a set of Sylvania bulbs or the like and call it a day as at least that isn't messing with the electrics in a $45k car.
      04-15-2012, 05:20 PM   #3
JoeyO
Drives: silver car
You can't just replace the bulbs. The whole headlight assembly needs to be replaced for xenon lights.
      04-15-2012, 05:47 PM   #4
mapezzul
Special Agent
mapezzul's Avatar
Obviously that is not true- you can use and external ballast and xenon bulbs like in the OPs link. I was saying to use Silvania Silver Stars as they give off more white light and do not alter the wiring of the car at all.
A true "OEM" xenon would need ballasts, housings, relays and recoding amongst other things and I doubt the OP wants to go through all that expense and hassle based on his original question.
      04-15-2012, 06:32 PM   #5
bcl0328
Drives: 2012 328i
i don't want them for myself but was just curious in case anyone wanted them.
      04-15-2012, 09:35 PM   #6
JoeyO
Drives: silver car
Yea, you can do that if you want to take the half-ass approach.
      04-15-2012, 10:49 PM   #7
shoptb
shoptb's Avatar
Drives: 13 328i MSport EBII 8A
Even if you replace your fog lights with xenon ballasts, be warned that it may cause D-CAN errors. I swapped out my fog lights for a pair of xenon ballasts back in 2010, but it kept throwing fog light errors CONSTANTLY in the check control, so after 3 different sets, I finally just went back to the originals.
Delivered! --> '15 F33 328xi, 8SA, Glacier Silver with Coral, 403M-19", ZMM, ZPP, ZTP, ZDA, ZDB, ZCW, ZDH, 4M5
Past --> '13 F30 328i, 8SA, EBII, ZMM, ZPP, ZTP, ZLP, ZDA, ZCW, ZDH, BMS Stage 1
Past ------> '08 E92 335xi, 6MT, DGM w SDL, ZPP, ZTP, ZLP
      04-15-2012, 11:36 PM   #8
SD_E88
SD_E88's Avatar
Drives: 12' 135i E88 Black
Can't say I would trust a system that introduces a new power hungry ballast. I ordered my F30 with the standard lights. I'm regretting that a little because I like the look of the whiter xenon lights. My next step is going to be to purchase a set of the Sylvania SilverStar zXe bulbs. If I like them I'll replace all of the H7 bulbs with the zXe's.
Closed Thread
