BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Solution to headrest not going down
      04-27-2012, 08:57 PM   #1
blindmule
Drives: 2012 F30 335i sport
Don't bother with the dealer.
You need a thin strong plastic piece about 10cm x 5cm. I used a safety tag from a children's car seat. Like the ones from a new mattress or a sofa. It needs to be thin and strong.
Tilt the seats way back.
Take the headrest off.
Both holes have a horizontal pins.
Fold the plastic piece in half length wise twice so it's about 10cmx1cm.
Put the plastic in the hole half way by the pin that does not have the release button.
This will block the teeth of the headrest from engaging the pin.
Put the headrest poles back. Push the button and slide all the way down.
Pull plastic out. Voila!
Do not use a metal tool as it may scratch your bimmer. Do not use thicker plastic as it will create too much pressure. A chip bag wrapper will likely work. The material should not tear or strech easily.
I'm 5"9 and am more comfortable with the headrests all the way down. Thanks RxCritical for guiding me to the fix.
      04-27-2012, 09:45 PM   #2
RxCritical
Drives: 2012 535xi
No Problem! The plastic is a good idea. I just used what I had available and was very, very careful!!
Glad something worked for you! I'm 5'9" also and like the headrest down.
headrest
