BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > 328i economy. Post your figures here!
European Auto Source
      07-19-2012, 02:30 AM   #23
RobUK
RobUK's Avatar
Drives: 340i EBII
Only done about 500 miles in it but getting 36.5 (UK) mpg according to the OBC. 90% Comfort mode, 50/50 town/country lanes/short/long trips, don't use A/C much. Not too disappointed with that so far
340i in Estoril Blue
      07-19-2012, 08:34 AM   #24
TonyS
Drives: F30 335i
Don't forget guys that there's a difference between UK and US gallons. A UK gallon is approx 4.54 litres whereas a US gallon is approx 3.79 litres. Bear this in mind when comparing results - a US driver getting 30mpg is equivalent to a UK driver getting 36mpg.
      07-19-2012, 10:19 AM   #25
Puri1
Puri1's Avatar
Drives: F30 328i 2012
About 9.5l/100km or 24.76MPG.... that's what the car tells me but While filling my tank with 60l of gas I average about 550km which is close to 11l/100km or 21.38mpg.
Mainly driving on comfort mode 80% eco/sports 20%.
I did, on my last fillup solely drive on ecopro to test it out and well not much of a difference honestly, maybe 40 extra kms ...
2012 F30 328i, Alpine White on Black, Luxury, Premium + Exec. Package...
      07-25-2012, 10:59 AM   #26
Robertck
Drives: 328i Luxury Line
I'm getting about 10l/100km or 23.52MPG (US) from the reading on the OBC.
Should we be getting more than that? I thought the average rating was suppose to be 7.9l/100km city and 5.3l/100km hwy, and combined 6.7l/100km.
My drive to work about is about 9 km. About 4.5 hwy and 4.5 city.
Maybe that's the reason for the reduced fuel efficiency (Not driving long enough in one go?)
      08-10-2012, 06:17 PM   #27
VLing77
Drives: F30 328i Sedan N20
I have read that the BMW recommended premium unleaded (octane 91-92 USA) will give you the best MPG. You can run lower octane like regular (octane 89 USA) in the engine; because of the anti-knock sensors that retards ignition. But I would not! Lower octane will equate to lower MPG and possible problems over time.
I assume everyone is quoting MPG using Premium Unleaded (in the USA)..
      08-20-2012, 02:44 PM   #28
lukster
Drives: like a granny
my mix mode driving is around 25mpg. a recent roadtrip from los angeles to san francisco and back yielded 34.5mpg with cruise set to 80mph.
      08-20-2012, 09:21 PM   #29
steadymoddn504
Drives: e36 m3
12 BMW 328i  [0.00]
so far i'm getting 30-33 mpg per tank
the only thing in this world that gives orders is balls. You got that? Balls.
      09-05-2012, 02:18 PM   #30
scott@bmwhn
Drives: Msport X3
about 1000 miles on the odo/ just filled up my 4th tank
6-speed manual
drive in sport mode 80% of the time
usage is about 80% city & 20% highway
A/C always on
Start/stop disabled
9/5/12 - averaging 21mpg (i've noticed a steady improvement as I put the miles on & my driving behavior averages out)
11/19/12 - 4K on the odometer - one HPDE - 21.5mpg
-Scott
15' Msport X3 28i _Mperformance - ACschnitzer - H&R_
15' Sportline X1 28i _Mperformance - H&R - Recaro baby seat_
Previous:13' Msport 328i, 09' Msport 335i, 07' Msport 335i
      09-05-2012, 07:33 PM   #31
c3r2z8f30i
c3r2z8f30i's Avatar
22
Drives: 2016 X6 Space Gray
F30 14 gallons e92 16
I'm getting about 24mpg between city and highway. But I notice that I'm going to the pump at about 1 to 1.5 times a week. Has any notice how often your putting gas? I also notice that my f30 has 14 gallons on my e92 I had 16 gallons.
      09-05-2012, 07:39 PM   #32
L0UD0G
Drives: 2012 328i Sport
      09-05-2012, 09:29 PM   #33
RPM90
Drives: 340i M-sport AT
Fuel capacity is 15.8 gallons.
I just filled my 2nd tank in my 335i. It took 15.1 gallons, with a wee bit over "empty" on the gauge.
I don't know if the dealer filled it completely, but the first tank averaged about 22mpg, and that's will a new and tight engine. Very mixed driving, sport mode all the time, and mostly manual shifting the sport AT.
Tire pressures set at 35psi front, and 38psi rear.
BMW recommends 32frt and 35rr. Consistent highway driving above 100mph, or full capacity calls for 39frt and 41rr, for my 18" UHP Summer tires.
What PSI are you guys running?
I recommend upping both ends by 3 psi, from standard, for improved MPG and better tire wear, side benefit of a bit quicker steering response too.
      10-02-2012, 01:18 PM   #34
ScarecrowBoat
Zooombie attaaack!!
ScarecrowBoat's Avatar
Drives: 328
I averaged 37.6 mpg at 80-85 mph over a 200 mile trip. Getting around 25-27 mpg IN THE CITY.
Eco Pro on the long trip, comfort in the city.
      10-02-2012, 02:59 PM   #35
justinnum1
Drives: 2015 328i Msport 6mt
Over the life of the car i am getting 27.5
past few months on my commute to work i am getting about 38mpg.
Hope my 335 gets that well, i drive mostly in eco pro
F30 328i Alpine white/Coral red Msport 6MT, HK, Zenons, msport brakes, black grills and black side sills. mperformance exhaust
      10-12-2012, 12:50 PM   #36
edgarik
Drives: 328i Basic Auto
the computer average is about 23-24 with mixed driving. Just highway cruising I can do 30-35 easy.
      10-16-2012, 07:16 AM   #37
Deuk
Almost 40 years BMW driver
Netherlands
Drives: BMW 328i / F30
Drive my 328i mainly in Eco-pro. Checked a few times in the computer after returning from a trip and most of the times it showed 6,4 ltr to 100 km's, which is about what is promised in the brochure.
      10-16-2012, 04:37 PM   #38
MikeVictor
Australia
97
Drives: anything given a chance
mid-8's/100km mixed. Around 5L/100km on the highway, if not less.
I'm a fan of EcoPRO on the morning commute which probably helps too.
      10-16-2012, 07:21 PM   #39
hotsoup
Drives: R8
Sport/Normal/Eco = 20%/50%/30%
City/Highway = 80%/20%
I get about 23-24 mpg. Decent for gunning it at every traffic light I'm in front of.
      10-16-2012, 11:17 PM   #40
zibawal
Drives: 2012 X5D
Originally Posted by Gel214th View Post
The car is reporting about 16.6mpg in the information screens.
That is pathetic;( my m3 gives me 16.2mpg, on mixed driving 80-90% city. More so, I was driving a loaner 2012 528' supposedly N20, and it was up, down hill, close to 25 mpg;( I am confused;(
      10-17-2012, 11:25 AM   #41
Turbo00
Drives: 2013 328i M-Sport
I've been averaging about 30mpg on my daily commute (40 miles round trip, half backroads/half highway, of which 30% is stop/go). I had to take a trip up to boston yesterday (around 200 miles round trip), so I decided to see how well I could do. Car had about 300 miles at the start, and in Eco Pro I averaged 35.1mpg. It's worth noting that I was in traffic for over an hour; I think I could broken 36mpg without difficulty.
      10-17-2012, 03:01 PM   #42
BMWinGE
I was initially averaging about 25-27 MPG for my local driving, mostly winding roads up with some hills. The last 3 tanks I've averaged 29 MPG for the same route. Not sure if the increase is due to the engine breaking in more or the fact the temperatures have dropped so the AC is on less. Happy either way. Every trip I've taken my average is 33-36 MPG, but that is travelling at speeds in excess of 100+ MPH.
      11-15-2012, 09:06 AM   #43
matt1034
Drives: F30 335i, E92 M3, F10 528i
Originally Posted by SomeRandomer123
36mpg (UK) Comfort knocking about and 42mpg (UK) EcoPro on the motorway - not grannied at all!
2000mls
31.87 average on my last tank. It was 95% hwy.
      11-16-2012, 09:01 AM   #44
slmdgee
Usofstance
Drives: 328I 6SPD
getting 18mpg but i just got the car haha.
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance
United States Of Stance
