BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > N20 Engine roughness at idle
      04-28-2012, 10:57 PM   #1
glitched79
Drives: 2012 328i
Title says it all...
How much roughness is normal at idle for this engine?
My last car, a 2008 base MINI Cooper, had almost no vibration at idle with the A/C on, and only a little bit rougher without the A/C.
My new 328i is different. I can definitely tell that the engine is running. I wouldn't say it feels like there's something wrong - there's no warning lights or anything - but the engine definitely let's you know it's running.
Is this normal? Maybe it's the turbos?
      04-28-2012, 11:08 PM   #2
bcl0328
Drives: 2012 328i
direct injection
      04-28-2012, 11:11 PM   #3
glitched79
Drives: 2012 328i
Originally Posted by bcl0328
direct injection
But why? You'd think more advanced tech would result in greater smoothness.
      04-28-2012, 11:14 PM   #4
mfear
South Florida Elite
mfear's Avatar
Drives: E93 335i - Crimson Red/Black
Send a message via AIM to mfear
tht's just how it is
[2007 E93 335i 6AT | Crimson Red/Black Dakota | Premium | Sport | Heated Seats | iPod/USB | JB+ | 15% Tint | AngeliBright LED Halos]
      04-28-2012, 11:42 PM   #5
bimmerjph
bimmerjph's Avatar
Drives: 2002 BMW 325i
How does direct injection make it rougher? All that it is doing is changing where the fuel is injected into the engine.
      04-29-2012, 12:03 AM   #6
Elk
Drives: 2012 335i
Direct injection requires very high pressure in the fuel rails. The ticking sound is the injectors supplying fuel.
It should not idle rough, although the sound is not pretty. If you are concerned, go to the dealer and listen to another similar car to be sure everything is OK.
      04-29-2012, 08:58 AM   #7
TEAShea
Drives: 2012 328i
The engine has balance shafts and should be very smooth at idle. Mine is. However, there is considerable sound from the direct injection system. It makes it sound like a clackity-clack - like a diesel. All direct injection engines have this sound to some extent.
      04-29-2012, 08:59 AM   #8
TEAShea
Drives: 2012 328i
Direct injection does not make the engine rougher or vibrate more - just sounds like it.
      04-29-2012, 09:14 AM   #9
Q4P
Q4P's Avatar
Drives: Too Much
A 4 banger is a 4 banger... it doesn't matter how refined it is... it will still be a little rough at times... DI has little or nothing to do with how smooth the engine will operate. The Mini had a smaller displacement 4 so I could see that making a tiny difference but probably not enough to notice.
2jZ + RB26 + 4G63 + LS9 + N54 =
      04-29-2012, 02:34 PM   #10
derekh929
derekh929's Avatar
Scotland
266
Drives: AMG C63s Coupe & F56 JCW
Try R56 Cooper S it's like a tractor at idol but i still love it
      04-30-2012, 06:14 AM   #11
SomeRandomer123
SomeRandomer123's Avatar
England
189
Drives: F30 328i Luxury - Sport Auto
Isn't the 335i direct injected too? Well, it is, so why doesn't the N55 have a similar clackity clack noise?
My car is direct injected too...
Gone: 2006 BMW E60 520d SE 6MT
Gone: 2009 BMW E90-LCI 330d SE 6MT
Current: 2012 F30 328i Luxury 8AT
On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!)
      04-30-2012, 08:08 AM   #12
The X Men
Drives: 2013 X3 35i
One word, refinement.
      04-30-2012, 08:37 AM   #13
cstavaru
cstavaru's Avatar
165
Drives: 2009 335i M Sport Sedan 6MT
The 6 cylinder engines are more mechanically "balanced", there are more injection cycles per second so the clicks are more close together. Maybe that's what makes them seem to run smoother. My N54 sure does make all kinds of sounds, including clicks from time to time But it does idle very smooth. The oil used makes a big difference. The factory 5w-30 oil is very good, but - after warranty expires - switch to Motul 300v 5w-30 (twice as expensive and non-BMW approved) and the idle will be even smoother, with less sounds.
      04-30-2012, 10:49 AM   #14
SomeRandomer123
England
189
Hmm, my mum's Kia Cee'd 1.4 direct injection DOHC petrol has a very faint direct injection clackity clack to the point where it's damn near silent when warmed up. Is this because of less pressure than the direct injection system in the N20?
      04-30-2012, 03:41 PM   #15
jgrasty
jgrasty's Avatar
Drives: 2012 BMW 328i
2012 BMW 328i  [0.00]
The only time I feel vibration from the N20 engine is when it starts.
My instructor at the BMW CCA HPDE this weekend commented that he could not tell when the engine was on, after we put on the helmets. With the helmets off, we could hear the engine, but vibration was almost unnoticeable.
The car performed far better than the driver, BTW, at the HDPE.
      04-30-2012, 05:14 PM   #16
glitched79
Drives: 2012 328i
As I stated, the vibration isn't outrageous. I guess most people probably wouldn't even notice it. It's just definitely more noticeable than in my MINI.
      04-30-2012, 06:02 PM   #17
J Tiberius
J Tiberius's Avatar
South Korea
Drives: Imperial Blue Sport Line
I get no more vibration than I did in my e90. It def sounds like a 4 under heavy acceleration, but it is very quiet under normal driving and pretty much zero vibration (at least in mine, anyway).
2012 F30 328i, Imperial Blue, Sport Line, ZPP, ZPS, ZTP, Sport Auto, Heated Seats, Xenons, H&R Sport Springs, Michelin Pilot Super Sports
      04-03-2013, 09:45 AM   #18
Jax826
Jax826's Avatar
Drives: F30 328i
so did anyone get this fixed?
mine also vibrates when idle and I really don't think this is normal.
My friend has a 320D and there's no noticeable vibration when idles!
      04-03-2013, 02:14 PM   #19
rconti
Drives: Z3 M Coupe, NB Miata
It does. It just has 2 more of them per crank revolution so you don't notice the distinct clacks as much.
      04-03-2013, 02:26 PM   #20
Yay-Z
Shifting to Top Gear
Yay-Z's Avatar
Drives: E90 M3/E70 X5
It does. My 335i clacks at idle as well
2011 E90 M3 DCT
2013 E70 X5
