BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Comfort Access Bootlid (Trunk Lid) Opening
Extreme Power House
View Poll Results: Comfort Access "Foot Under Bumper" Boot/Trunk Lid Opening
It Works Well 188 75.50%
It Doesn't Work Well 61 24.50%
Voters: 249. You may not vote on this poll
      05-03-2012, 11:14 AM   #23
DrivenByE30
DrivenByE30's Avatar
France
457
Drives: '12 F30 Lux 335i 6MT
gently kick and retract your feet....
the error people make is holding/hanging your feet there... No good...
      05-03-2012, 11:16 AM   #24
Zirenz2006
Zirenz2006's Avatar
Drives: X3 M40i Phytonic
never had an issue with it
Current: G01 M40i Phytonic Blue|Black with Blue Stitching
Retired: '12 F30 328i Sport Line Sapphire Black|Black-red, '09 E90 335i M-Sport AW|Oyster, '07 E92 335i Graphite|Saddle, '05 E60 545i TiAg|Black, '01 E46 325i Jet Black|Black
      05-03-2012, 05:36 PM   #25
kokopuffs405
Yup
kokopuffs405's Avatar
75
Drives: BMW?
2014 BMW M5  [0.00]
I got it down pat
Oh hello
      05-03-2012, 05:52 PM   #26
Elk
Drives: 2012 335i
Originally Posted by kokopuffs405 View Post
I got it down pat
It must be tricky with those little owl feet.
      05-03-2012, 06:01 PM   #27
E90Fleet
South Africa
1063
Originally Posted by sjohal View Post
It seems like the problem people are having is that they are treating it like a motion sensor is present under the middle of the bumper. Just waving around will not trigger it, and a forward kick underneath the bumper will not trigger it unless you pull the foot back (or out) as well. That seemed to work when I tried it on an F30.
Correct
The sensors need to sense the foot and leg going toward the bumper and then away from the bumper. It will then open the trunk
BMW if you are reading, I need a job, Please.
      08-28-2012, 10:09 PM   #28
Morton89
Drives: 2012 328i
I love that I have the knowledge of so many fellow 3 owners. Couldnt get it to work becuase I would leave my foot for a second so it could "sense it". BMW does things right. Quick "snap-kick" as it was described above and it pops open with zeal! Thanks guys
      08-28-2012, 11:03 PM   #29
Arktctr
Drives: 2014 328d MSport
Originally Posted by jgrasty View Post
If you use the right technique, it works very well.
+1
2014 328d MSport ED: 5/2/2014
2013 F30 Activehybrid3 MSport (Gone)
2012 F30 328i Sportline (Gone)
      08-28-2012, 11:10 PM   #30
TrueBlue12
TrueBlue12's Avatar
Drives: Imperial 328i
a wiping ur toe off under ur car motion works everytime.
      08-28-2012, 11:11 PM   #31
M AZING
Drives: E90 M3
I had the same problem when I got the car. Once I learned the right way of doing it, it has been working fine....
      08-28-2012, 11:19 PM   #32
ScheerSpeed
ScheerSpeed's Avatar
Drives: '13 F30 Estoril M-Sport 335i
Send a message via AIM to ScheerSpeed Send a message via MSN to ScheerSpeed
i couldn't get it to work
      08-28-2012, 11:54 PM   #33
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
Stick your foot under, and pull it back quickly; like you've hit the exhaust with your bare foot and it's burning like hell.
Works 100% of the time for me.
      08-29-2012, 01:05 AM   #34
TF30Z
TF30Z's Avatar
19
Drives: BMW 320D F30
If the rear end of the car is parked above the thing where it stops your wheels from backing in further in a parking spot, will your trunk open when you move the car away? It'll be quite embarrassing to have your trunk open when you drive off..
Has anyone tried this?
      08-29-2012, 03:40 AM   #35
JUSKIDN
JUSKIDN's Avatar
Drives: 2013 EBII 328i M Sport
does the sensor ever get dirty with road grime and need cleaning?
It's not illegal. It's frowned upon, like masturbating on an airplane.
      08-29-2012, 04:34 PM   #36
sr5959
Drives: 428GC M-Sport
Originally Posted by malc410326 View Post
+1 There's a learning curve....But once you get the technique down pat, you will wish all your vehicles had this feature!
+1
      08-29-2012, 04:59 PM   #37
GR8DAY
Drives: BMW 328i 2013
The first two days I got it, it was ok. But now, I kind of give up on it. Regardless of what I did (swipe my feet under the roundel etc with different speeds) did not work anymore.
      08-29-2012, 07:21 PM   #38
YeaF30
YeaF30's Avatar
Drives: 2012 328i Sport Line
At the PCD they told me the sweet spot is not dead center. Rather put your foot between the Roundel and the model badge (i.e. 328i, 335i...). It works flawlessly with the aforementioned swift motion kick.
2012 328i Sport Line - Alpine White / Coral Red :: ZPP :: ZPS :: ZCW :: 522 :: Dinantronics Sport :: MPE
      08-30-2012, 12:41 PM   #39
bobert
Drives: manual shift cars
I wonder if they moved the sensor for '13 (half joking) - at the Philly Auto Show in Feb and on a couple test drives, I was getting it to work maybe 75% of the time, but pretty much 0% on our new car after 3 weeks. They had told me just barely left of center, so maybe I'll go try moving to the right!
      08-30-2012, 01:34 PM   #40
YeaF30
YeaF30's Avatar
I can only assume that it is right of the roundel because most people are rightys ? I mean every time I have ever used it, I have never used my left foot.
      08-30-2012, 02:48 PM   #41
bobert
Bah - still won't work for me - and I have size 12 shoes.
      08-30-2012, 03:53 PM   #42
Frogman
Frogman's Avatar
You have the key fob on you when you try to do this, right?
It won't work otherwise...
      08-30-2012, 04:05 PM   #43
BigKutta
BigKutta's Avatar
62
Drives: 2012 528i
2012 528i  [0.00]
2012 BMW 528i  [0.00]
No because the key fob has to be behind the car
      08-30-2012, 04:06 PM   #44
BigKutta
BigKutta's Avatar
62
Drives: 2012 528i
2012 528i  [0.00]
IF YOU FOLLOW THIS, IT WILL WORK EVERY TIME:
The kick should be swift and right in the middle, HOWEVER, the retracting of the leg is even more important. Retract you foot as fast you you kick and the boot will open every time.
Mine has not failed once since I figured this out
